Old 08-27-2014, 03:10 PM   #29
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
There is no replacement for displacement.
Forced induction is the replacement for displacement!
billwot is offline   Reply With Quote
The Following 4 Users Say Thank You to billwot For This Useful Post:
ftc~brz (08-27-2014), lantsalot (09-02-2014), Marchy (08-27-2014), sklimo (08-27-2014)
Old 08-27-2014, 03:12 PM   #30
ftc~brz
Done
Drives: WRB BRZ
^ If you get bored you are driving it wrong!
i only drove it wrong once.
ftc~brz is offline   Reply With Quote
The Following 3 Users Say Thank You to ftc~brz For This Useful Post:
#maverick# (08-27-2014), civicdrivr (08-27-2014), sklimo (08-27-2014)
Old 08-27-2014, 03:33 PM   #31
AH yes I have seen the pictures!
Old 08-27-2014, 04:04 PM   #32
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
I think OP is curious not why it is weak overall, but ratio of tq to hp is so low, at least that was my inital thought. my ka24de 240sx has as much or more torque than hp, which is why I liked it over the sr20, with the lower torque higher hp. I take his question to mean: why aren't they more even 180hp/180tq. I could be pulling this out of my ass, but I believe it is because this block has a square bore(same bore to stroke).
Displacement counts for power, but the design also determines what type of power. With an 86mm bore and 86mm stroke It makes for a balanced bottom end which is good for high revs. But for good low end torque, you need more leverage. To maintain the same size engine, if the stroke goes up, the piston size has to go down. If the stroke was longer, that would mean that the rods would have to be longer and or the crank lobes would have to be pushed out away from the center line. This would throw the balance out at higher rpm's but would provide a longer lever. With more leverage you get more torque, but less balanced, so it will spin slower top end, thus lower hp. Also increasing stroke would mean needing more crank case room, and taller cylinders, which would mean a wider engine. We already have to jack up the engine to change the spark plugs, so I do't know how much wider they could make it. I wouldn't mind sacraficing a little higher rpm's for more bottom end umph, because I DD, and almost never get over 5k rpm's. That's my assessment anyway.
...Or, you can always say "it is low hp but it is a BOXER engine". Again, if they give you a knowing look and go "ah yes that makes all the difference" then you confirm that they don't know sh*t about cars.
lol, a guy at work liked how the car looked, and did the whole it must be fast thing. I told him not really, but it has a low center of gravity due to the boxer engine.. he replied boxer engine! So that thing is basically a Porsche!
Phantom ESC, OFH, OFT, K&N Drop in
Target70 is offline   Reply With Quote
Old 08-27-2014, 04:24 PM   #33
stonenewt
Drives: BMW 120d
On a different engine I worked out that when you started exceeding something around 120meters/min of piston travel at high loads for extended periods nasty (e.g. flat out for 10-15 seconds or so) things started happening for long term bore/piston/engine life. Interestingly 86mm bore @ 7000 rpm = 120.4m/min of piston travel.
I also discovered that as you increased the piston travel you widened the power band as a % of maximum revs. The thing is the area under the torque graph stayed more-or-less the same so you had a wider power band with less peek power. Easier to drive with but not as fast.
I have no idea if this is a universal concept or specific to that particular engine. I was wanting to made engine which was high-revving but had a wide power band.
What'll make more power a 2l turbo engine at 1 bar boost or a 3l turbo engine at 1 bar boost?
stonenewt is offline   Reply With Quote
The Following 2 Users Say Thank You to stonenewt For This Useful Post:
tahdizzle (08-27-2014), Target70 (08-27-2014)
Old 08-27-2014, 04:35 PM   #34
ftc~brz
Done
Drives: WRB BRZ
Markymore novellas errrywhere
The Following User Says Thank You to ftc~brz For This Useful Post:
sklimo (08-27-2014)
Old 08-27-2014, 04:54 PM   #35
DarkSunrise
DarkSunrise's Avatar
As a rule of thumb, most well-tuned NA cars will have roughly 75-80 lbs-ft torque per liter.
So for a 2.0 L car, you're looking at 150-160 lbs-ft torque.
- FR-S/BRZ, 151 lbs-ft
- S2000, 153 lbs-ft
- RSX Type-S, 141 lbs-ft
For a 2.4 L car, you're looking at 180-192 lbs-ft torque.
- Civic SI, 174 lbs-ft
- Jeep Cherokee, 171 lbs-ft
- Santa Fe Sport, 181 lbs-ft
For a 2.5 L car, you're looking at 188-200 lbs-ft torque.
- 986 Boxster (2.5L), 181 lbs-ft
For a 3.4L car, you're looking at 255-272 lbs-ft torque.
- 981 Cayman S, 273 lbs-ft
For a 6.2L car, you're looking at 465-496 lbs-ft torque.
- C7 Stingray, 465 lbs-ft
And so on. Moral of the story is, if you want more low-end torque, go bigger (or go FI).
2022 BRZ Build
2013 FR-S Build
The Following 2 Users Say Thank You to DarkSunrise For This Useful Post:
ftc~brz (08-27-2014), Marchy (08-27-2014)
Old 08-27-2014, 05:26 PM   #36
Tromatic
The greatest part of this car is learning to drive it around it's limitations. People who complain about the stock car have a PEBSWAS (Problem Exists Between Steering Wheel And Seat) problem. Or, as has been said one or twice, "you bought the wrong car."
Nick Ienatsch's "The Pace" applies to this car as well as bikes. People who's only answer is "MORE POWER" (fun as that is) generally suck at the basics.
ETA: I'm starting to think the designer(s) of this car really put one over on Corporate. They managed to put into production a car that is totally opposite of almost all cars in production (not counting real "supercars), a vehicle that requires, and rewards, real driver involvement. I've said before that the FR-S is a throwback, and a small taste of "supercar". I have had a number of cars, some crappy, some very nice. The FR-S is the most awesome little car of all. I literally love mine. Young dudes who have this as a first car have no idea how great it really is.
What exactly is a driver's car?
The Following 6 Users Say Thank You to Tromatic For This Useful Post:
bedabi (08-31-2014), Demandred7 (08-27-2014), ftc~brz (08-27-2014), Pkush (11-26-2014), Quentin (08-27-2014), UNREAL (05-22-2021)
Old 08-27-2014, 05:31 PM   #37
lol, a guy at work liked how the car looked, and did the whole it must be fast thing. I told him not really, but it has a low center of gravity due to the boxer engine.. he replied boxer engine! So that thing is basically a Porsche![/QUOTE]
Ya that T makes a big difference! Never thought of that before maybe when I said "boxer" people were hearing "boxTer". They may have been smarter then I gave them credit for after all.
Old 08-27-2014, 05:49 PM   #38
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Or that most Porsche's have boxer engines.
Old 08-27-2014, 06:04 PM   #39
Target70
Target70's Avatar
I had to google it just now to make sure I hadn't typed it out wrong . it's actually boxSTer. As I'm cheap and broke, I never looked into porsche cars so all that I knew was that they had flat engines, I think/thought it was usually a flat 6. I was unaware of the whole boxer / boxster thing.
The Following 2 Users Say Thank You to Target70 For This Useful Post:
ftc~brz (08-27-2014), Tcoat (08-27-2014)
Old 08-27-2014, 06:16 PM   #40
Tromatic
Just slap an RB kit on your Boxer, viola! Boxster!
The Following User Says Thank You to Tromatic For This Useful Post:
Old 08-27-2014, 07:05 PM   #41
Target70
Target70's Avatar
with the danger of going wildly off topic, I'll say that i bought this car with the intention to modify it for more power, and I do not feel like I bought the wrong car. It was either put a turbo kit on my 240, then go about replacing the open diff/axles, the 15" 4 lug spendles/wheels/rotors brakes, the cooling system, fuel pump.. etc, etc.. and end up with a dented, faded, rattley, worn out 2500lb 350hp car with no ac, and a busted rear defroster. Or I could finally break down and by a new similar platform/weight car and spend the same or less money modding it, and have a higher performance, cleaner, more reliable car, I can enjoy for the next 20 years.(if I live that long)
The Following User Says Thank You to Target70 For This Useful Post:
Old 08-27-2014, 07:06 PM   #42
strat61caster
Typically, the layout has cylinders arranged in two banks on either side of a single crankshaft and is sometimes known as the boxer, or horizontally opposed engine.
[ame="http://en.wikipedia.org/wiki/Flat_engine"]Flat engine - Wikipedia, the free encyclopedia[/ame]
Boxer engines got their name because each pair of pistons moves simultaneously in and out rather than alternately, like boxers clashing their gloved fists together before a fight
http://en.wikipedia.org/wiki/Flat_engine#Boxer_engines
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
ftc~brz (08-27-2014), Target70 (08-27-2014)
uberstupid
Lug Nut Torque Lunatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 07-30-2014 07:45 PM
Torque Pro sav AFRICA 33 08-27-2013 07:31 AM
500 hp & 550 lb/ft torque ? yes please LS13 Scion FR-S / Toyota 86 GT86 General Forum 3 06-17-2013 12:48 PM
What torque dip? pdreams Engine, Exhaust, Transmission 44 11-12-2012 06:56 PM
Torque App ZetaVI Other Vehicles & General Automotive Discussions 4 12-02-2011 12:22 AM
