Old 08-25-2014, 02:37 PM   #1
puma
crew chief
puma's Avatar
Drives: Race car FR-S
driveshaftshop bolts, is it safe?
i have installed an aluminum DSS driving shaft but the flange is a lot thicker than the stock one, is it safe to reuse the stock bolts even if there is like half the thread not used on the nut?
puma is offline   Reply With Quote
Old 08-25-2014, 02:46 PM   #2
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
That looks like enough thread engagement to me as long as they are not lock nuts and thus not utilizing the locking part at the top of the nut.
Old 08-25-2014, 03:13 PM   #3
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
How does that bad boy feel?
Looking into getting the same thing.
Carlitoz3 is offline   Reply With Quote
Old 08-25-2014, 03:43 PM   #4
IceFyre13th
IceFyre13th's Avatar
Drives: Mazdarati
How much would it cost to go get new bolts and do it right compared to how much will it cost you when it fails.....?
IceFyre13th is offline   Reply With Quote
The Following 6 Users Say Thank You to IceFyre13th For This Useful Post:
Anthonytpt (08-26-2014), Captain Snooze (08-26-2014), flippy (09-12-2014), G-Man (08-25-2014), number1Tango (09-12-2014), Tcoat (09-12-2014)
Old 08-25-2014, 04:39 PM   #5
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
+1 I'm intersted as well!
kmbkk is offline   Reply With Quote
Old 08-25-2014, 04:48 PM   #6
ZionsWrath
Thanks
ZionsWrath's Avatar
does it torque to spec?
Old 08-25-2014, 04:53 PM   #7
kodyo
Drives: Scion FR-S
When we do bolting in industry, we try to have at least 2-3 threads above the end of the nut. What you have would not be considered acceptable.
kodyo is offline   Reply With Quote
The Following 5 Users Say Thank You to kodyo For This Useful Post:
flippy (09-12-2014), Tcoat (09-12-2014), Turbo (08-11-2019), woode (09-12-2014), wu_dot_com (08-26-2014)
Old 08-25-2014, 05:09 PM   #8
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
That would not fly on aircraft. 2-3 threads through the nut. I had a similar problem with my driveshaft. I ditched the stock washers and used loctite red, which is a pretty hokey fix, getting the right bolts would be the right thing to do. Holds fine but might be a PITA if you have to rotate your driveshaft.
industrial is offline   Reply With Quote
The Following User Says Thank You to industrial For This Useful Post:
VacantSky (08-26-2014)
Old 08-25-2014, 05:57 PM   #9
Akari
Drives: 2013 DGM BRZ
Go spend $4 on bolts, that's not safe at all.
Akari is offline   Reply With Quote
Old 08-25-2014, 07:13 PM   #10
puma
crew chief
puma's Avatar
yeah the thing is to find bolts with a grade high enough for the job. I don't have such a shop around.
I must admit i didn't even think about taking the washer off, that would give me something like 2 threads in addition.
Old 08-25-2014, 07:38 PM   #11
King Tut
NASA SpecE30 Racer
King Tut's Avatar
You don't have a local hardware store with grade 8 bolts and nuts? I would go with a longer bolt, nut, and a lock washer if you are worried.
Old 08-25-2014, 07:55 PM   #12
kodyo
Drives: Scion FR-S
They aren't standard bolts. They are partially threaded so shear load isn't taken through the thread. You'd probably be ok to use a little loctite and remove the washer if it gives you enough engagement.
Old 08-25-2014, 08:57 PM   #13
Thorpedo
The SquadWhisperer
1 big vote for NOT acceptable.
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion
2017 Bluenose Autosport Club Overall Rallycross Champion
Powered by Great North Performance, Jani-King Canada, and OK Tire.
Thorpedo is offline   Reply With Quote
Old 08-25-2014, 09:07 PM   #14
White64Goat
Nope. Replace with correct length. Probably grade 8 if I had to guess.
Safe to run 5w-30 oil? NON-VTEC Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 47 03-12-2017 12:01 AM
DriveShaftShop Carbon DS - Vibration! Ray_32 Engine, Exhaust, Transmission 49 09-18-2014 09:46 PM
Two bolts for front camber safe? eSOLOR Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 07-21-2014 10:22 PM
Aftermarket camber bolts safe? was385 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 04-19-2013 11:30 AM
Be Safe! Mr. J BRZ First-Gen (2012+) — General Topics 21 11-21-2012 05:46 PM
