Old 08-25-2014, 01:32 AM   #631
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by cuddefred View Post
Hi Shiv, having an issue with the OFT I recently received and sent an email on Sat if you could take a look at it please. Cheers. Grahame
I won't be in the office until tomorrow (Monday). Also, for fastest response, please email sales@vishnutuning.com instead of me. Robert and Garret will respond very quickly. Depending on my daily schedule which often involves out-of-office testing, my response time is often much longer
Shiv@Openflash is offline   Reply With Quote
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
cuddefred (08-25-2014)
Old 08-25-2014, 01:35 AM   #632
cuddefred
Drives: Black 86 GT
No worries, that's the email I sent it to so I am sure they will get back to me before too long
cuddefred is offline   Reply With Quote
Old 08-25-2014, 01:38 AM   #633
Shiv@Openflash
Drives: 2013 FRS
Yep... you should hear back from them tomorrow. It's still Sunday night in this hemisphere
Old 08-25-2014, 02:24 AM   #634
cuddefred
Drives: Black 86 GT
Are you telling me that you guys have some time off and don't work 24/7/52?
Old 08-25-2014, 03:22 AM   #635
steve99
Drives: FT86
Originally Posted by nomad View Post
Hi guys, how come the MAF Scaling for v2.01 Stg2 EL 91 pump gas and EL E85 are different. I thought MAF scaling are always the same regardless of what types of fuel you are running. I'm confused, anybody with knowledge please explain. Thank you
As their is no flex fuel sensor tthey make some compensations to the maf scale
Old 08-25-2014, 03:24 AM   #636
steve99
Drives: FT86
while you waiting have a read of the OFT TIPS link below you never know your luck the answer may be there
The Following 3 Users Say Thank You to steve99 For This Useful Post:
cuddefred (08-25-2014), DC2R (08-25-2014), Shiv@Openflash (08-25-2014)
Old 08-25-2014, 03:45 AM   #637
JS86
I have an A01G Stage 1 93 USA octane V2xx map if you want it. But from memory you were on an earlier ROM
Just flashed it and its nice MAF Scale, AFR's, Knock Fuel trims all good very little to adjust
the tables you need to copy are these 36, when you do compare you will see some missing tables this is because if the differences between the defined tables between ROM series
Primary Open loop fuelling
Front Oxygen Sensor Scaling
CL Fuelling Target Compensation A (load)
CL Fuelling Target Compensation B (load)
Throttle tip In enrichment A
Throttle tip In enrichment B
A/F Learning #1 Limits
MAF Sensor Scaling
Base Timing A
Base Timing B
Knock Correction Advance Max A
Timing compensation (IAT)
Timing compensation Per Cylinder A
Timing compensation Per Cylinder B
Feedback Correction Retard Value
Fine correction Rows (RPM)
Fine correction Columns (Load)
Fine correction retard value
Advance Multiplier (Initial)
Requested Torque A (Accelerator Pedal)
Rev Limit (fuel cut)
Idle Speed Target A
Idle Speed Target B
Idle Speed Target C
Idle Speed Target D
Idle Speed Target E
Idle Speed Target F
GDI Firing Angle Cold Idle
GDI Firing Angle High load Cold
GDI Firing Angle High load Hot
GDI Firing Angle Low Load Cold
GDI Firing Angle Low Load Hot
Intake Cam Advance Angle Safe AVCS
Intake Cam Advance Angle Normal AVCS
Exhaust Cam Retard Angle Safe AVCS
Exhaust Cam Retard Angle Normal AVCS
Open a ZA1JxxxG ROM in Romraider and the ZA1JD00G V2.04 modified ROM use the ROM image compare function in RomRaider to compare the images . Copy all the required tables to your old 700G 1.5x tune ROM and save.
This is all your responsibility though :-)
Hey Steve99,
Do you mind sharing your updated A01G V2xx ? would save me the pain from comparing maps and potentially effin it up.
JS86 is offline   Reply With Quote
Old 08-25-2014, 04:26 AM   #638
steve99
Drives: FT86
Originally Posted by JS86 View Post
Hey Steve99,
no problem mate as long as the stock rom in your oft is AO1G it will be fine and remember to use the Openflash defs if you want to edit it it has LC and FFS
PM me your emial and i will send it soon dont have it on the phone :-)
Old 08-25-2014, 05:13 AM   #639
cuddefred
Drives: Black 86 GT
Already did this cheers Steve but don't think the answer is there. When I plugged the tablet in for the first time, after flashing my Ecutek tune back to stock, I tapped 'read' from the ecu and the box was coloured, it seemed to read fine but after doing it, it was grey, as was the 'write' box and I got the message 'mode file not found, cannot create tuning file' and couldn't do anything at all. I assume it is something to do with Ecutek tune but thought I should check with the Vishnu guys to see how to resolve it and I'm not in a rush to flash this new one cos I have the header on order as well.
Old 08-25-2014, 05:37 AM   #640
steve99
Drives: FT86
Ok, whats happened is
1. Ecutek stock tunes are not 100% stock, the tune tables and program is but ecutek hides some licience data in the ROM as well
2. OFT has read you stock rom which is not 100% stock, the read has gone grey as its sucessfully read the rom. so it wont read another.
3. the write has gone grey as the oft has worked out your stock rom is not 100% stock as a result it will not build a tune file from its database format tunes ie .dev file it is shipped with as it uses your stock rom as a base to build tune.
4. fix is to download the 1.5x full format .bin tunes from openflash site unzip, delete the database format tunes in oft using OFM, then load up the required tune .bin full tune files to match your calid of stock rom.
As the oft now has a full tune rom to work with it will just check the calid and vin matches and its happy to flash.
If you were on calid D00G you would need the V2x tunes .
cuddefred (08-25-2014), DC2R (08-25-2014), xxBrun0xx (08-25-2014)
Old 08-25-2014, 08:27 AM   #641
cuddefred
Drives: Black 86 GT
Cheers Steve, you are a bloody legend mate! Followed your instructions and worked like a dream. Too late to take it out now but will be interesting to compare it to the Ecutek tune tomorrow. Thanks buddy.
Old 08-25-2014, 09:11 AM   #642
Cockatoo
TALLY FT86
Cockatoo's Avatar
Drives: 2014 FR-S Monogram -- SBD Turbo --
Add another to the bogging issue.... Only thing that changed was adding OFH and moving to OTS 2.0 with that change. I was running E85 1.59 like a champ prior to adding the Header, but had to switch to 93otc because E85 ran out in my area.
The bogging feels exactly how the shitty Injen intake felt like. I'm running stock intake. Gonna wait for this tank of gas to run out in case it was some bad gas or something (Shell V) then do a ECU reset.
Cockatoo is offline   Reply With Quote
Old 08-25-2014, 09:21 AM   #643
steve99
Drives: FT86
log your long term fuel trim LTFT see if its high at idle or where the bogging occurs. like over 10% if so you may just need to touch up the maf scaling.
Don'tbother resetting ECU it wont help, read below FLASHING-RESET-LEARNING
Old 08-25-2014, 10:03 AM   #644
Cockatoo
TALLY FT86
Cockatoo's Avatar
OK. Ill see if I can get some logs later today, I just went out to the parking lot and let it idle for 10 minutes, and the LTFT settled on 1.56%
OpenFlash Tablet v1.42b maps now available Shiv@Openflash Software Tuning 159 09-13-2016 12:29 AM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 05:23 PM
OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted Shiv@Openflash Software Tuning 142 07-22-2014 10:21 PM
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) Shiv@Openflash Software Tuning 255 02-15-2014 04:43 AM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
