Old 08-20-2014, 03:40 PM   #1
TStafford
TStafford's Avatar
Drives: 2015 FR-S Ultramarine Metallic
OFT where do you put it when logging?
The best I have come up with is to hang it over the console. Would love to be able to see it. Any cleaver ideas?
TStafford is offline   Reply With Quote
Old 08-20-2014, 03:42 PM   #2
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
thats what i do.
The Following User Says Thank You to zc06_kisstherain For This Useful Post:
raven1231 (08-21-2014)
Old 08-20-2014, 04:02 PM   #3
lucid215
i have mine mounted with a gps holder i got from best buy
lucid215 is offline   Reply With Quote
Old 08-21-2014, 02:12 AM   #4
clintavo
Wedge it between the driver's seat thigh bolster and center console?
clintavo is offline   Reply With Quote
Old 08-21-2014, 08:09 AM   #5
wparsons
wparsons's Avatar
I half wrap the wire around the e-brake handle and leave it resting on the console by the seat belt buckle.
flickr
Old 08-21-2014, 08:17 AM   #6
VacantSky
The Angry Brit
VacantSky's Avatar
Drives: 1991 E30 318iS
I wish the screen was brighter on it...
VacantSky is offline   Reply With Quote
Old 08-21-2014, 09:23 AM   #7
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
If you check out my build thread (in sig) I have a review of the iMagnet mount that I use. I believe Shiv uses something similar but perhaps at a different location. I find the little triangle window works pretty damn well.
1Cor10:23 is offline   Reply With Quote
The Following 2 Users Say Thank You to 1Cor10:23 For This Useful Post:
DAN_BRZ (08-21-2014), menikmati (08-21-2014)
Old 08-21-2014, 09:38 AM   #8
TM
TM's Avatar
Drives: DGM BRZ 6MT
I do the same as @1Cor10:23
Originally Posted by TM View Post
I use the same iMagnet mount that I use with my phone for the OFT.
TM is offline   Reply With Quote
The Following 3 Users Say Thank You to TM For This Useful Post:
1Cor10:23 (08-21-2014), Garrett@Openflash (08-21-2014), raven1231 (08-21-2014)
Old 08-21-2014, 09:53 AM   #9
raven1231
over the console however now that I have seen the I magnet I will be doing that!
Old 08-21-2014, 11:06 AM   #10
menikmati
Drives: 2015 BRZ, 2005 STI, 2024 Type R
I will be looking into this mount, thanks.
menikmati is offline   Reply With Quote
Old 08-21-2014, 11:57 AM   #11
TStafford
TStafford's Avatar
Yep that was what I was looking for. Thanks
Old 08-21-2014, 12:11 PM   #12
TStafford
TStafford's Avatar
Just thought of something. Gotta detach before opening the door?
Old 08-21-2014, 12:59 PM   #13
1Cor10:23
1Cor10:23's Avatar
Yup, if you leave your cable taut. If you leave some slack, you can actually open the door.
I left no slack as I always unplug OFT after I'm done driving since it has no on/off switch. If it had a switch, I'd reconfigure my cable.
Old 08-27-2014, 03:54 AM   #14
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Aren't you guys worried that heat or sunlight will eventually damage your OFT? I personally keep it in my garage in a shelf until I need it. Would really suck if it broke and you needed to flash stock.
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
Ecutek logging Andreas83 Software Tuning 3 07-09-2018 10:57 PM
ECU LOGGING BRZ GT 86 FRS - what to look for the basic’s steve99 Software Tuning 59 12-15-2017 02:05 PM
OP2 logging discussion AdrianG Software Tuning 37 10-06-2017 01:41 PM
ECUTEK Logging pdreams Engine, Exhaust, Transmission 5 02-05-2013 10:06 AM
