Old 08-15-2014, 01:50 AM   #71
fooyc
fooyc's Avatar
Drives: GT86-JDM
dezoris,
that ur oil press on the gauge? if so it seem abit low?
fooyc is offline   Reply With Quote
Old 08-19-2014, 10:36 PM   #72
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
9k RPM of sweet oil pressure!
http://instagram.com/p/r5sBnItvc5/
Thanks,
Phil Grabow
Element Tuning is offline   Reply With Quote
The Following 3 Users Say Thank You to Element Tuning For This Useful Post:
2013GTRNate (05-01-2015), blackfireball5 (08-20-2014), DriftEm (08-19-2014)
Old 08-21-2014, 04:46 PM   #73
mike the snake
The video doesn't play for me.
Old 08-21-2014, 05:23 PM   #74
Gords_zenith
Gords_zenith's Avatar
Drives: WRB BRZ Sport Tech
Thanks,
Phil Grabow
OMG I watched that a dozen times - so awesome! The sound, speed, the way the revs climbed, and of course 9k rpm redline on a FA20. Well done!
Gords_zenith is offline   Reply With Quote
Old 08-21-2014, 07:39 PM   #75
Element Tuning
Yeah she sounds sweet! We just needed to work our magic on the motor.
Old 09-18-2014, 12:19 PM   #76
stonenewt
Drives: BMW 120d
For reference where's the best places to pick up the oil pressure (& oil temp) on this engine?
stonenewt is offline   Reply With Quote
Old 09-18-2014, 02:51 PM   #77
mike the snake
Just watched the video. Wow! I think I'm going to have to go for the built block here soon.
Thanks,
Phil Grabow
Old 08-19-2015, 08:35 AM   #78
pepe
Drives: gt86
Originally Posted by HRTROB View Post
Sure. I bought these parts:
http://www.rallysportdirect.com/Suba...il-Galley-Plug
http://www.rallysportdirect.com/Suba...ey-Plug-Gasket
Then I hooked them up to the port beside the compressor
Take note that the OEM Subaru oil gallery plug is threaded for 1/8 PT sensors.
You can probably use the stock oil pressure sensor location. It's pretty useless anyway. By the time the warning light turns on, the damage has already been done. It's the sensor below the oil filter housing, the one with the disconnected connector in the photo:
Been driving around with the stock oil pressure sensor disconnected. No CELs. I believe it's a simple switch that grounds itself to the block when there is no pressure detected, illuminating the warning lamp on the cluster. Hope this helps.
One question, if the oil pressure sensor factory, bad measurements? or you may ECU bad readings? If this does not work for snesibles sensor measurements, could be replaced by good sensor in that position for external gauge? It would be possible to connect cable and cable ECU external sensor gague the same?
one could try to connect to external gauge oil pressure sensor for readings best?
pepe is offline   Reply With Quote
Old 08-23-2015, 05:11 AM   #79
pepe
Drives: gt86
Could you tell me which are temperature and oil pressure adequate job in this car? thank you
Old 09-09-2015, 06:25 PM   #80
dirtbike250x
dirtbike250x's Avatar
Drives: '13 FR-S Ultramarine
So instead of starting a new thread I'd figure I post here. Question is, I have a oil pressure gauge and now have an idea of my pressures.
On a cold start with rough ambient temp of 90F with 0W-20 pressure is between 90-100 after normal street driving in this temp the gauge drops to around 6-8psi at idle. Is that normal? Seems awful low to me, and after a 20min track session can bounce around 4psi.
I know I will not be running 0W-20 with these temps and most certainly not on the track anymore, just want to make sure my gauge is reading correctly.
Gauge is tapped in at the galley plug by the compressor.
2013 FR-S Ultramarine
-TRD Catback, UEL Header and Tune, Blitz Drop in Filter, Mishimoto Silicone Intake tube, Mishimoto Oil Cooler, 17x9 w/245/40/17 PSS, RS*R Coilovers custom track alignment, Check out my YouTube for more track videos https://www.youtube.com/channel/UCA9...O1T2Q3xu4m4bYQ
dirtbike250x is offline   Reply With Quote
Old 09-09-2015, 06:34 PM   #81
byun
byun's Avatar
Drives: 2015 BRZ CWP
I'm tapped in to the same spot with a Prosport premium pressure sender hooked up to the P3cars vent gauge.
Running Amsoil 5w30
my idle pressue is around 28psi and on track at redline I was at 55psi w/ temps at 215. cold start pressures are around 100psi
I am running the AVO Turboworld oil cooler.
Attachment 119843
byun is offline   Reply With Quote
Old 09-09-2015, 06:43 PM   #82
dirtbike250x
Running Amsoil 5w30
Is that idle pressure at full operating temp. I only drop down low after extended driving in hotter climate.
Old 09-09-2015, 07:41 PM   #83
byun
byun's Avatar
Yea, full operating temp and oil at about 196. Even after coming off track with the oil temps at 220 I was still at 25psi
Old 09-09-2015, 08:18 PM   #84
dirtbike250x
Ok thanks hopefully someone will be able to chime in with 0W20, but now I know what to look for when I bump up to the 30 weight.
Stock clutch+flywheel+pressure plate+ ACT lightweight flywheel & pressure plate PineappleFriedRice Transmission and Driveline 0 11-08-2013 04:54 PM
Mid range really lacking goli5oda Electronics | Audio | NAV | Infotainment 4 08-19-2013 10:27 AM
Range on a tank of Gas! crank Southern California 28 02-10-2013 04:04 PM
Cruising Range? skoodge Scion FR-S / Toyota 86 GT86 General Forum 4 05-25-2012 02:31 AM
UK Price range £25-£32k!? ZeeSpeed Scion FR-S / Toyota 86 GT86 General Forum 56 11-27-2011 02:11 PM
