Old 05-01-2014, 02:56 PM   #1
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
Oil Pressure Range
See bottom of this post for peoples results.
Original Post:
Hey all,
I've been searching for a few days for an exact answer but I haven't been able to find anything conclusive.
What is a normal range for oil pressure for our engines stock? How about with an oil cooler and a turbo?
What is a healthy range that the oil pressure should stay between at all times?
Below is the template everyone should follow to report oil pressures.
  • Oil brand, type, and weight
  • Mods such as oil cooler, boosted, or stock
  • Sensor location
  • Location (Country, State, ect)
  • Ambient Temperature
  • PSI at 180F, 190F, 200F, 210F at idle
  • PSI at each 1k RPM once car is warm
  • Max PSI seen at redline once car is warm
Optional:
Pictures, videos, ect.
Results will be posted here.
blackfireball5 is offline   Reply With Quote
Old 05-01-2014, 03:51 PM   #2
Dezoris
Dezoris's Avatar
Originally Posted by blackfireball5 View Post
Hey all,
Yes, I want this answer too.
The Following User Says Thank You to Dezoris For This Useful Post:
blackfireball5 (05-01-2014)
Old 05-01-2014, 08:16 PM   #3
Gords_zenith
Gords_zenith's Avatar
Drives: WRB BRZ Sport Tech
I would hazard a guess that our cars are spec'd for a viscosity of ~7 cST @ 100C, based on the fact that the stock 0W-20 is rated for that. So in saying that, our cars run hot when being beat on, that raises the temp up to 110-120-130 degrees celsius, so from that I would conclude that the stock 0W-20 at those temps drops to a viscosity rating of ~4-5 cSt which in my mind is not good. but if ya want to keep using the OEM Mobil 0W-20, that I would think having a thermostatically controlled oil cooler would be good investment.
see my post:
http://www.ft86club.com/forums/showthread.php?t=63955
EDIT: this doesn't tell you what pressure you will get, but will give you an idea of what oil you should run based off temp to ensure oem designed oil pressure is maintained.
Gords_zenith is offline   Reply With Quote
The Following 2 Users Say Thank You to Gords_zenith For This Useful Post:
blackfireball5 (05-02-2014), flippy (09-21-2021)
Old 05-02-2014, 01:14 AM   #4
blackfireball5
Thanks for your post. I personally am using amsoil 5w-30, with an oil cooler and the fbm kit. I'm ordering an oil pressure gauge soon and wanted to know what kind of psi i should be looking for at each end of the spectrum.
Wheelwell Profile
Use code TWW-BOO5TED when shopping at Wheelwell to receive 10% off your order.
Old 05-02-2014, 11:44 AM   #5
Oh, I'd say that if you got a gauge that would read between 5 and 85 psi, you would catch the entire range.
Old 05-02-2014, 11:53 AM   #6
blackfireball5
Oh ok perfect! I was looking at a gauge that maxes out at 100psi and I didn't know what kind of an operating range our motors hit. Thanks!
Still would like to know healthy limits as well though.
Old 05-02-2014, 12:44 PM   #7
I've read where the minimum is about 7 psi and the operating range is about 10 psi for every 1,000 rpms.
......just from what I've read ..... I've nevered measured it.
blackfireball5 (05-02-2014), Sportsguy83 (01-13-2017)
Old 05-02-2014, 10:11 PM   #8
getbent
Drives: 2013 FR-S Blue MT
You need a 150psi gauge. The oil pump goes into full bypass at 125psi. I routinely see 100-125psi on cold start with a low load on the engine.
I typically see about 1 bar per 1k rpm at operating temperature (90-100C) with 0w-20.
2013 Scion FR-S | 6MT | UltraMarine
getbent is offline   Reply With Quote
The Following 3 Users Say Thank You to getbent For This Useful Post:
blackfireball5 (05-03-2014), JazzleSAURUS (06-27-2016), jcw99 (12-24-2014)
Old 05-03-2014, 04:45 AM   #9
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Cold start, i get about 8.9 bar (129 psi)
Idling at normal operating temperature, oil pressure would around 1.3-1.5 bar
5w30, Perrin oil cooler, Defi Advance CR oil pressure gauge hooked up to the oil gallery port beside the AC compressor
HRTROB is offline   Reply With Quote
The Following 2 Users Say Thank You to HRTROB For This Useful Post:
blackfireball5 (05-03-2014), jcw99 (12-24-2014)
Old 05-03-2014, 08:46 AM   #10
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
Rob,
Help me out with the install when I get my oil pressure gauge!
Tye300 is offline   Reply With Quote
Old 05-03-2014, 09:28 AM   #11
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Originally Posted by Tye300 View Post
Rob,
Sure thing! It's an easy DIY
The Following User Says Thank You to HRTROB For This Useful Post:
Tye300 (05-03-2014)
Old 05-03-2014, 01:08 PM   #12
blackfireball5
Thanks guys! Looks like I'll need the 150psi gauge!
Good thing i didn't jump the gun! I already bought my defroster vent pod so I'm gonna pick up a Guage. :-)
Wheelwell Profile
Old 05-03-2014, 04:08 PM   #13
Dezoris
Dezoris's Avatar
Yo can you post up what parts you used for your gauge? That would be very helpful.
Old 05-03-2014, 05:27 PM   #14
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Sure. I bought these parts:
http://www.rallysportdirect.com/Suba...il-Galley-Plug
http://www.rallysportdirect.com/Suba...ey-Plug-Gasket
Then I hooked them up to the port beside the compressor
Take note that the OEM Subaru oil gallery plug is threaded for 1/8 PT sensors.
You can probably use the stock oil pressure sensor location. It's pretty useless anyway. By the time the warning light turns on, the damage has already been done. It's the sensor below the oil filter housing, the one with the disconnected connector in the photo:
Been driving around with the stock oil pressure sensor disconnected. No CELs. I believe it's a simple switch that grounds itself to the block when there is no pressure detected, illuminating the warning lamp on the cluster. Hope this helps.
The Following 4 Users Say Thank You to HRTROB For This Useful Post:
blackfireball5 (05-05-2014), Bonburner (03-30-2021), BRZ68 (05-03-2014), jcw99 (06-26-2016), rb6freak (06-04-2014)
Stock clutch+flywheel+pressure plate+ ACT lightweight flywheel & pressure plate PineappleFriedRice Transmission and Driveline 0 11-08-2013 04:54 PM
Mid range really lacking goli5oda Electronics | Audio | NAV | Infotainment 4 08-19-2013 10:27 AM
Range on a tank of Gas! crank Southern California 28 02-10-2013 04:04 PM
Cruising Range? skoodge Scion FR-S / Toyota 86 GT86 General Forum 4 05-25-2012 02:31 AM
UK Price range £25-£32k!? ZeeSpeed Scion FR-S / Toyota 86 GT86 General Forum 56 11-27-2011 02:11 PM
