Old 08-19-2014, 08:26 PM   #15
vhx1
Drives: 06 AP2 S2000
Originally Posted by CSG David View Post
Lol owning both has its perks.
WERD!!!
vhx1 is offline   Reply With Quote
The Following 2 Users Say Thank You to vhx1 For This Useful Post:
CSG David (08-19-2014), CSG Mike (08-19-2014)
Old 08-19-2014, 08:30 PM   #16
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
Is your s2000???
It also means I'm broke.
Boost for boost using the same exact blower and PSI, there's a 100hp difference. LOL
Wait a minute, how much boost are you talking about 4psi???
Jaden
Jaden is offline   Reply With Quote
Old 08-19-2014, 08:33 PM   #17
CSG David
CSG David's Avatar
Jaden
10 PSI. Actually there's a ~120hp difference, but I detuned for about 80-90hp difference. Both are on the same dyno and that S2k was being tuned in the summer while the BRZ was tested in the winter (which really doesn't make that much of a difference on that dyno).
Either way, both cars has its perks. Both are proven to work well on track. Both are capable of lapping excellent lap times given the right conditions and @CSG Mike driving.
The Following User Says Thank You to CSG David For This Useful Post:
Sportsguy83 (08-20-2014)
Old 08-19-2014, 08:38 PM   #18
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
boosted S2000 > boosted GT86 > S2000 > GT86 > Ford Pinto
mit_peid is offline   Reply With Quote
The Following 3 Users Say Thank You to mit_peid For This Useful Post:
BRZ21 (09-01-2014), CSG Mike (08-19-2014), Sideways&Smiling (12-15-2014)
Old 08-19-2014, 08:44 PM   #19
CSG David
CSG David's Avatar
The aero is better on the 86. Stock vs. stock, the 86 will keep up with the S2000 (gap won't change) from 100-130mph. Other than that, the 86 has a hard time pulling on an Integra GSR from freeway speeds. The real benefit of the 86 platform is in the corner. You'll be surprised at how much you'll gain with such a low drag body and stable platform. It's incredibly easy to drive an 86 over the S2000.
The Following 4 Users Say Thank You to CSG David For This Useful Post:
glamcem (08-20-2014), Maowc (08-28-2014), mit_peid (08-19-2014), Sportsguy83 (08-20-2014)
Old 08-19-2014, 08:58 PM   #20
CSG Mike
CSG Mike's Avatar
This happened in Mexico.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
buddy32 (08-20-2014), gramicci101 (08-19-2014), Sportsguy83 (08-20-2014)
Old 08-19-2014, 09:02 PM   #21
DAEMANO
Time Traveller
Based on that pull, I bet a TP on the s2k would effectively eliminate the advantage...
Interestingly enough unlike the 1.0 dump pack (battery setup) gasoline powered car in the video, my car has the 1.5x dump upgrade + E85. A TP equipped S2K would still get walked.
Old 08-19-2014, 09:10 PM   #22
CSG Mike
CSG Mike's Avatar
Well, if you're on E85, why not E85 the S2k and increase the redline a bit
Old 08-19-2014, 09:16 PM   #23
CSG Mike
CSG Mike's Avatar
Jaden
@CSG David's gonna hate me. I keep telling people he's a lot faster than he lets on on this forum...
Old 08-19-2014, 09:34 PM   #24
DAEMANO
Time Traveller
Because this isn't a discussion about equivalent mods. Even if it was, E85 does more for my FI FR-S than a NA S2K. This is more a demonstration of how easy and cheap it can be to makeup the power gap ($2k+2hrs) that can bring '86 owners to the same conclusion that Dezoris found. S2k is nice, I'm glad you like it so much. However if sold in today's dollars (inflation adjusted) would be around $45k. For that reason in my mind the cars shouldn't be compared. It's like comparing an S2K to a 2015 Boxster. It's simply another price class of car. In the case of the the 3, I'd take the FR-S and a few thousand in mods over either because I don't want a 2 seat roadster, I especially didn't want a 10ish year old daily driver (S2k) and I dont want to spend $60k+ (Boxster) on something I'm going to beat on. The '86 is simply a terrific and practical modern platform.
The Following 2 Users Say Thank You to DAEMANO For This Useful Post:
AVodka14 (08-19-2014), samisons (09-04-2014)
Old 08-19-2014, 09:59 PM   #25
AVodka14
AVodka14's Avatar
Drives: 2013 Raven FRS MT
Looks like boost, suspension, exhaust, and wheels/tires will be a must for me next year. Warranty will be up and student loans paid off. Turbo time baby!
Oh and hopefully the single temp harness to swap to dual climate control. Fisher price knobs look tacky. All else is fine.
AVodka14 is offline   Reply With Quote
The Following 2 Users Say Thank You to AVodka14 For This Useful Post:
CSG Mike (08-20-2014), JB86'd (08-21-2014)
Old 08-19-2014, 10:05 PM   #26
Jaden
Road-hole
It's not comparable because of something else too...
He's not even close to the redline on the FRS... 6600 rpm versus 8100 is the reason for the power difference.
Decrease the rotating mass on the twin and up the redline and it will do the same...
I had originally written something completely different(in the post that I asked if he was only running 4 psi) because that just didn't make any sense whatsoever.
The power that you can generate with a given FI compressor is directly related to how much air you can push(volume, not PSI) and how much timing you can run.
He's right, the e85 would definitely help out the 12.5:1 twin more than the 11:1 s2K because you can only advance the timing so much on either one. You can advance the timing more, while maintaining minimal detonation on the S2K because of the lower CR on pump gas, so you can't advance it as much more on E85 as you can with the twin because the twin can't be advanced as much on 91 as the S2K can.
IOW, you're able to advance the timing on the twin a greater amount when you switch to E85 from 91 than you can switching the S2K to E85 from 91.
With a 7400 natural redline on the twin, you should be able to reduce rotating mass via a lighter flywheel and harmonic balancer and up the redline to say 7800 and they will be much closer to each other on the same levels of boost.
When you put them both on E85 and can approximate the same timing advancement along with that, they should be almost identical in power levels for the same boost, (with the same compressor being used).
In my original post before I edited it, I asked which S2K engine he had, the 122CI or the 132 because that will make a difference too.
The more cubic inches, the more air it can gulp per revolution.
Now I've simplified this here, there are other differences involved, the VVT in both engines is different and the tune's utilization of it will vary the power levels too, so as I had said in the original unedited reply...
I'm talking out my ass here, with no direct tuner experience with the engines of either of these cars (yet) so take it for what it's worth, but on paper, the disparity should be no where near what they're seeing...
Jaden
p.s. notice that those dyno maps look almost identical until ~5400 rpm at which time they both slightly dip and then the S2K's goes right along that same initial slope but the twin's slope changes, my guess would be that that is where the timing advancement changes for the twin versus the S2K...
Wait a minute, now I'm confused, are BOTH of those maps for the S2K????
Then where is the map for the twin that is 100hp shy of the S2K????
The Following User Says Thank You to Jaden For This Useful Post:
AVodka14 (08-20-2014)
Old 08-19-2014, 10:09 PM   #27
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
86 vs S2k... Owned both.
I love that feeling.. you know that feeling, that one feeling you come to know and love.
That feeling that brings you so much joy and happiness about the 86.
That feeling of...
Walking out to your car and the seats are still in it.
PRO86 | WTCC | STL
The Following 7 Users Say Thank You to rice_classic For This Useful Post:
BirgeyT1 (08-26-2014), Chee-Hu (08-21-2014), CSG David (08-20-2014), Dezoris (08-20-2014), glamcem (08-20-2014), mfbmike (08-20-2014), noodlebaka (08-21-2014)
Old 08-19-2014, 10:21 PM   #28
thill
That feeling of...
Haha, nicely played!
Dezoris | FR-S Build | Supercharged & More Dezoris Member's Car Journals 329 03-21-2016 04:48 PM
The curse strikes again Blood BRZ First-Gen (2012+) — General Topics 22 04-23-2013 02:08 PM
This is what i get for going in on my day off (curse strikes again) wrxgoose Scion FR-S / Toyota 86 GT86 General Forum 62 03-28-2013 08:02 PM
CSG BRZ playing with the big boys...Boosted NSX, DNA Motoring S2000, and a Ferrari... CSG Mike BRZ Photos, Videos, Wallpapers, Gallery Forum 1 02-12-2013 09:51 AM
The Curse Strikes. Again. SubieNate Scion FR-S / Toyota 86 GT86 General Forum 46 02-08-2013 03:47 PM
