Old 08-17-2014, 02:29 PM   #561
Wepeel
Drives: '13 BRZ Ltd
Stage 2 UEL 93 - knock parameters look decent, although seems to peg full rich at 5k+
http://www.datazap.me/u/wepeel/oft-s...zoom=2307-2541
Wepeel is offline   Reply With Quote
Old 08-17-2014, 03:38 PM   #562
355rockit
Drives: Sci FR-S, Fer F355, Toy Highlander
Just getting back from Monterey Car Week returning to San Diego. ODT v2 91 octane stage 2 tune gave me a bit over 33 MPG. Nice!
355rockit is offline   Reply With Quote
Old 08-17-2014, 05:01 PM   #563
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Originally Posted by solidONE View Post
This is with a catted header? Dang... What about just using the secondary cat on the front pipe instead?
I not sure I understand, is this good or bad?
The current setup is a FA20Club EL Catted Header, Perrin Overpipe, Nameless Catted Front Pipe with Helmholtz Resonator, Stock Exhaust, Perrin Tips
The catalytic converter is huge and according to Mr Brown it flows very well.
If I knew it wouldn't drone and the noise was acceptable I'd install this.
Still new in the box. Sure weighs less, lol
Would the performance difference be noticeable?
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 08-17-2014, 09:11 PM   #564
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
I know one sure way to find out. lol
Seems to be good whatever you have on there already, but I've not looked at enough different setups to know for sure. Only guessing from the looks of your MAF voltages and your ignition advance. (As much as 1.5* of advance more than @weepeel's log at certain parts of the range.) Of course there is no substitute for back to back dyno pulls. You can always try to play with virtual dyno if you have a nice flat road to test on safely.
Old 08-17-2014, 10:46 PM   #565
tonystewart
Installing it is easy, lots of wiggle room installing the pipe, it's the reinstallation of the cat if things don't work out. It took an hour to find a sweet spot for that cat where it or the pipes downstream didn't rub anything.
I'll let her put some miles on the tune and datalog later this week, late at night
What setting Primary Open Loop Fueling should I have in the 6000-7400 range at 1.1 1.2 1.3 load?
Old 08-17-2014, 11:22 PM   #566
solidONE
solidONE's Avatar
In my logs I've found that in cool 70* temps AFRs were 0.2 richer than target, but in 100*f temps it would go 0.2 leaner than target approximately. To be safe and to avoid having the AFR go leaner than 12.5:1, I set the target AFR at around 11.9-12.0 at those ranges. Although I'm sure there will be some variation form car to car. I believe more power could be had at AFR's at or leaner than 12.5:1 at the risk of being more knock prone particularly in hot weather.
Also, our O2 sensor is really not a true wideband. So, again, I'd like to error on the richer side of things.
Old 08-17-2014, 11:42 PM   #567
solidONE
solidONE's Avatar
I wonder what causing you not to hit that last bit of advance that tony seems to be hitting... it's the same ignition table, there is no knock, and IAM is at 1. why?
Old 08-18-2014, 12:13 AM   #568
twmade
Drives: GT86
Originally Posted by Td-d View Post
Mail me the rom so I can make a Romraider definition as well.
Sent you pm
twmade is offline   Reply With Quote
Old 08-18-2014, 03:43 AM   #569
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Originally Posted by twmade View Post
Sent you pm
Thanks - Steve already sent it through.
Td-d is offline   Reply With Quote
Old 08-18-2014, 07:22 AM   #570
xxBrun0xx
xxBrun0xx's Avatar
Drives: 2014 WRB BRZ Limited
Anyone running this stage 2 tune (EL or UEL) with stock header back? Curious how well it runs out of the box and how loud it is. Not sure if I want to do headers yet or wait a while, but gains are pretty impressive
xxBrun0xx is offline   Reply With Quote
Old 08-18-2014, 09:14 AM   #571
Silver Ignition
APEXHNTR
Silver Ignition's Avatar
Drives: 10 Series FR-S #1867
Originally Posted by phobos512 View Post
I had one for my phone and bought a second for my OFT. Phone one is adhesive mounted to dash, OFT one is the suction arm in that link (allows me to use in other cars). I stick it to the fixed window on the door. Works great. OFT weighs nothing so there's no issue. I'm not the only person that uses this style of mount - got the idea from this forum actually.
any chance you can snap a pic of it installed with the OFT mounted?
2013 Sc10n FR-S 10 Series
#1867 of 2500
in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer]
Silver Ignition is offline   Reply With Quote
Old 08-18-2014, 09:59 AM   #572
Wepeel
Drives: '13 BRZ Ltd
I see about 0.5 degree difference? I didn't log my IAT but I'm almost sure it was about 75. Also, he is running the EL map and I am running UEL - not sure if the timing requirements are different.
Old 08-18-2014, 11:01 AM   #573
tonystewart
Do you mean stock exhaust after the header? Half of it is stock.
After the catted EL header, I'm running a Perrin Overpipe, a catted Nameless Front pipe with Helmholtz Resonator, and the rest of the exhaust is stock.
The Following User Says Thank You to tonystewart For This Useful Post:
xxBrun0xx (08-18-2014)
Old 08-18-2014, 12:15 PM   #574
tonystewart
Is the Wideband O2 kit available from OpenFlashTablet?
OpenFlash Tablet v1.42b maps now available Shiv@Openflash Software Tuning 159 09-13-2016 01:29 AM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 06:23 PM
OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted Shiv@Openflash Software Tuning 142 07-22-2014 11:21 PM
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) Shiv@Openflash Software Tuning 255 02-15-2014 05:43 AM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 09:45 PM
