Old 08-15-2014, 07:14 PM   #5181
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
Originally Posted by Boofneenee View Post
Gotta love that crap. The guys at IFT will review and offer support regardless if its a base or custom map. Either you installed it wrong or their is something wrong with their idle data
Bill was contracted by innovate to provide the tune, when you buy the carb setup he is not under obligation to provide support, technically innovate is.
mikalem is offline   Reply With Quote
Old 08-16-2014, 09:43 AM   #5182
8686
8686's Avatar
Drives: 86
Gentlemen,
I will be joining the league soon. My tuner shop is in the installation process now.
He have a question. What type of oil he should use for the supercharge?
Thank you in advance
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
Old 08-16-2014, 10:22 AM   #5183
sam69
Drives: GT 86
Red Line 75w90 NS or the equivalent oil in Mobil 1 full synthetic.
I believe NS stands for none slip which is the same as LSD oil .
sam69 is offline   Reply With Quote
The Following User Says Thank You to sam69 For This Useful Post:
8686 (08-16-2014)
Old 08-16-2014, 07:08 PM   #5184
stevo585
Drives: White 2014 BRZ
Originally Posted by DeliciousTuning View Post
I am no English major that is for sure. Need to work on my grammer. Lets' try that again...
It may not be a fair match up, being most people may want to compare the ESC to a non-intercooled Innovate 75mm setup. From what we have seen most customers seem to run the Stage 2 package and usually go with a smaller pulley.
Your damn right its not fair lets see a innovate stage 1 base kit vs the ESC base kit.
I understand though you have a business and reputation to uphold. We can end it here. I've already seen the charts
stevo585 is offline   Reply With Quote
Old 08-16-2014, 07:11 PM   #5185
stevo585
Originally Posted by Calum View Post
I just really liked seeing a rotrex kit and the sprintex kit dyno's from the same tuner and same dyno.
Thats already been shown right? In the supercharger comparison thread.
Under 4k goes to the sprintex with the intercooler.
Above that Rotrex and Vortech both rocket away.
Old 08-16-2014, 08:36 PM   #5186
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
No. That thread showed the CARB innovate tunes VS custom tuned centrifugals. The CARB tunes for the centrifugals don't rocket away from the innovate. They're more along the lines of "catching up" at the high end and maybe pulling slightly ahead at the top.
Sellout is offline   Reply With Quote
The Following User Says Thank You to Sellout For This Useful Post:
xjohnx (08-17-2014)
Old 08-16-2014, 10:41 PM   #5187
stevo585
Haha ok I stand corrected then. I'll go back and look.
On a side note it is interesting than no OEM uses a centrifugal SC (that I know of).
Old 08-17-2014, 06:44 AM   #5188
Calum
That Guy
Drives: 2013 asphalt FRS MT
If you look at the graph, the sprintex kit isn't loosing anywhere, it's just making much more off peak.
Koenigsegg uses rotrex.
Old 08-17-2014, 06:58 AM   #5189
Calum
That Guy
Just to make it easier to see for anyone interested.
The Following User Says Thank You to Calum For This Useful Post:
Old 08-17-2014, 03:00 PM   #5190
stevo585
Cool Really!? Ok one car
The Following User Says Thank You to stevo585 For This Useful Post:
Calum (08-17-2014)
Old 08-17-2014, 07:21 PM   #5191
MINOCIN
MINOCIN's Avatar
Drives: Asphalt 2013 FR-S
For the guys & gals out there running Delicious Tuning's latest 8.59 tune. Have you noticed any sluggishness/delay in your throttle response after updating? I've been running on 8.59 for almost a week now and I'm wondering if anyone else has noticed the same thing or if it's just me.
Now before I continue I want to make it clear that while I may be complaining a bit, I offer it as constructive criticism. My intention is not to be negative and in no way am I upset. In no way should my criticism be seen as an attempt to blemish Delicious Tuning's reputation and work. I have the utmost respect for Bill and I truly appreciate his dedication to this platform and to his clients. A lot of us Innovate guys run on a Delicious tune because we know that they are awesome, and with that I would like to share my experience so far with the 8.59 tune.
After reflashing the ecu I have noticed the following:
- exhaust rasp has been minimized
- somewhat vague throttle response
- revs will hang/float
- at idle with no load on the engine, revving will cause the rpms to abruptly drop to 500 and then jump back to 1,000 before settling back to 800 rpm (normal idle rpm)
- smooth up/down shifts are executed more easily
- Engine breaking is a little less effective
- the car feels smoother (more casual) overall when driving around town and on the freeway
I have a manual transmission. Before installing the SC I used to rev the car out to over 5,500 rpm almost all the time. Mainly because it was fun and also because I wanted to stay clear of the torque dip. After the SC I would normally short shift below 4,300 rpm. Mainly too avoid the raspy exhaust note and also because with the extra torque down low I didn't really have to rev it out anymore. With the 8.59 tune I now rev the engine out to around 5,000 rpm. Mainly because it sounds good again and also because the car doesn't feel as fast as it used to.
It's difficult for me to explain, I feel like there is a larger disconnect now between the accelerator and the engine. The car feels slower and less responsive. Revs don't build up as quickly as they used to.
It's eerie. My right foot and butt tell me that the car is slower, but when I look at the speedometer I see that I'm actually running at a high speed. So even though I think that the car feels slower, my speed says otherwise.
I don't really care if I am indeed going a bit slower or not. Taking the car to redline when jumping on the freeway is still fun and I can never get enough of that twin screw whine, but there is just a bit less drama in driving the car now. The car feels like it has been dulled down a bit. I feel somewhat disconnected and out of sync with the car.
Does anyone else feel the same way? Maybe I just need to drive it more and over time I will get used to it, but I can't help myself from fretting over the feeling that the car feels less responsive.
GFR - aka my build thread
"They don't think it be like it is, but it do." -Oscar Gamble
MINOCIN is offline   Reply With Quote
The Following User Says Thank You to MINOCIN For This Useful Post:
DeliciousTuning (08-18-2014)
Old 08-17-2014, 07:27 PM   #5192
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
Put the car in map 3 or 4 and tell me your throttle response sucks. Map 1-4 progressively makes the throttle more sensitive. Map 4 makes heel toe downshifts stupid easy now and the new tune altogether is a huge upgrade from the last.
If you wanna test the effectiveness of the throttle progression on each map just change maps while you're driving at a constant speed and you will feel the difference.
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
The Following 2 Users Say Thank You to CK_Bladesmith For This Useful Post:
DeliciousTuning (08-18-2014), MINOCIN (08-17-2014)
Old 08-17-2014, 08:39 PM   #5193
MINOCIN
MINOCIN's Avatar
I was thinking something similar except that I live in California, so maps 1 & 2 are for 91 octane and maps 3 & 4 are for 93 octane. Maps 2 & 4 are said to be the same as 1 & 3 respectively, but with auto blip enabled. Unfortunately there isn't a gas station nearby with 93 octane gas to test maps 3 & 4. I do have Torco accelerator fuel additive. I normally like to save that for my first track sessions of the day though. I find it cheaper than having to fill up on 100 octane at the track. One tank of Torco and a half tank of 100 are usually enough to last all day at the track.
Anyway, when I say I was thinking something similar I was thinking that perhaps the maps could be adjusted so that one map would be for casual drivers (I mean driving) and the other would be like a sport mode with sharper throttle response. I was not aware that these settings were already included in the new tune. If so then that is great to hear. I don't recall noticing any changes in throttle response before with the old tune between maps 1 & 2, but the car did perform better on maps 3 & 4 at the track with the higher octane fuel.
Also, I'm not saying that the throttle response "sucks". Nothing at all about this new tune sucks. The throttle just feels a bit vague and less responsive compared to before, but if switching to map 2 gets rid of this slightly disconnected feeling then that would be awesome.
Ok, I just went back and reviewed the Delicious Tuning thread and I found that you are most likely right about the different map settings.
The latest Innovate Supercharger version is 8.65 and includes the following updates
1. Smoother acceleration from a dead stop
2. Smoother power delivery under partial throttle low RPM
3. Smoother power delivery under quick throttle changes at high RPM's
4. Better cold engine low end acceleration
5. Works on our 69mm pulley and up to 80mm pulleys (91 through E85)
6. Completely Updated to RaceROM Version7
7. Accelerator Trim Options (Soft, Standard, Aggressive, Drag)
If map 1 is soft, map 2 standard and so on, then I wonder why the decision was made to make soft the default map? Better fuel economy perhaps or do most 86 drivers really prefer a softer responding car? Also, I wonder what this means for me and those like me who have maps for different fuel settings. Are the soft thru drag accelerator trim settings applied the same way as for those who only use one type of fuel? That's a question that I can pm Zach about or even ask on the Delicious Tuning thread though.
Regardless, thanks for the response I appreciate it
Like I said in my original post, I wasn't trying to be negative. I apologize if it came out that way. I just didn't know and now I do
Thanks!
The Following 2 Users Say Thank You to MINOCIN For This Useful Post:
CK_Bladesmith (08-17-2014), DeliciousTuning (08-18-2014)
Old 08-18-2014, 08:23 AM   #5194
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
I only have two maps....
I do feel that in the lower rpms it does feel a little sluggish. It doesn't feel like it pulls as hard. Higher rpms are very good and smoothness and drive ability were improved. I'll have to look into getting the other throttle response maps.
From a stop it's easier to get off the line but they may have hurt the 2nd or 3rd gear, too lazy to downshift, pull from low rpm.
2013 BR-Zed, Innovate Powered, Delicious Tuned, Zeltus Cooled. Build Thread
www.GT86Mounts.com
calispec is offline   Reply With Quote
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
