Old 08-15-2014, 12:18 PM   #1
Scalzo
Scalzo's Avatar
Drives: Asphalt FRS <3
Huge leak in intercooler
So I finally figured out why its been sluggish and why i couldn't find the boost leak.
the intercooler has a huge hole top right side,
Now what?
New intercooler or fix it?
FYi i have fa20club before going to shits.
Scalzo is offline   Reply With Quote
Old 08-15-2014, 12:26 PM   #2
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
TTIWWP
Do you have a good aluminum welder you trust to fix it?
Old 08-15-2014, 12:26 PM   #3
enjetek
Drives: 93.5 supra t & prius
nice, at least you found the problem. how bad/big is the hole? id say get a new one if its that bad...how did you get a hole also? bad install? if it wasnt you that installed it make whoever did it cover it...
enjetek is offline   Reply With Quote
Old 08-15-2014, 12:36 PM   #4
2pt5RS
Berz
I'd say replace the intercooler.
2pt5RS is offline   Reply With Quote
Old 08-15-2014, 12:38 PM   #5
Scalzo
Scalzo's Avatar
I think it was just a rock that might have hit it... :/ too many people touched my car could Also be the cause of that..
King tut I do have friend that is a very good welder . If I hve to get a new intercooler he will be making the new pipes for me and I could also fix the fa20club MAF by moving it down more with the new pipes
Old 08-15-2014, 02:25 PM   #6
mike the snake
I had a hole in my intercooler on my last car from hitting a deer or a stick or something. It was where one of the veins joined the side tank.
I scuffed the area up with emery paper and fixed the hole with JB-Weld.
Not sure how big your hole is, but this worked fine for me.
Also, it should be no problem for any good welder to fix.
Old 08-15-2014, 02:28 PM   #7
stugray
Drives: 2013 GBS BRZ Limited
Post a pic. You can solder aluminum with a torch and $10 worth of rod from harbor freight
Old 08-15-2014, 03:00 PM   #8
Jesse@JDLAutodesign
Jesse@JDLAutodesign's Avatar
Drives: 2013 Raven Black FRS
Post a pic...You would be surprised what can be fixed...I've fixed some pretty mangled things before.
Jesse@JDLAutodesign is offline   Reply With Quote
Old 08-15-2014, 03:02 PM   #9
Scalzo
Scalzo's Avatar
I don't have access to take a picture yet I brought it to prime motoring from coming back from vacation ...
My buddy will look at the intercooler Monday I'll post a picture then
Old 08-15-2014, 07:28 PM   #10
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Ask yourself; what would Tony do?
Answer, continue with build and turn up boost to negate sluggish feeling. Because that'll fix all your problems!
New intercooler though. Dont wanna have a weld spot where it might burst again.
Old 08-15-2014, 08:47 PM   #11
Scalzo
Scalzo's Avatar
Lmfao^^
Tony = useless probably will tell me my intercooler has a leak because of tuning
Old 08-16-2014, 03:36 AM   #12
BadBRZ
Drives: Subaru
Ihave a brand new never used fa20crap intercooler i'll sell you, direct swP for the one you have
BadBRZ is offline   Reply With Quote
Old 08-16-2014, 03:59 AM   #13
Kuros
Drives: 2014 FRS Raven. 2011 sti red (gone)
pics please!
Kuros is offline   Reply With Quote
Old 08-16-2014, 09:17 AM   #14
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Was it pitting because of corrosion in the endtanks?
I've seen a local FA20club kit (mind you there is not salt/snow here), that the endtanks are really badly corroded because of the cheap steel used for them.
Non traditional intercooler layouts? Shit Luck Forced Induction 80 11-01-2015 08:33 PM
WTB: Innovate Intercooler upgrade J.C. Want-To-Buy Requests 0 07-18-2014 06:52 PM
PRE Intercooler stage 2 TC kit almost ready BRZPDX Northwest 57 04-04-2014 07:42 PM
How bad is turbo without intercooler? mid_life_crisis Forced Induction 50 06-23-2013 01:57 PM
Another turbo with but water to air intercooler ahaghshenas Forced Induction 8 09-24-2012 03:22 AM
