Drives: red frs
Non traditional intercooler layouts?
anyone trying anything other than a fmic setup?
havent seen any water cooled or v mount style setups yet.
Drives: 2003 Subaru Outback
I feel like a front mount is the most logical position for a intercooler given the coldest air is on the bottom - for front mounted engines anyway.
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
(=^・ェ・^=)
Drives: 2013 FRS, '08 GSXR 600
Someone do a top mount and a subie style hood!
Drives: red frs
thats all well and good if you car doesnt have heat issues like ours. the air from the fmic in now hot air flowing over a radiator and possibly and oil cooler. not to mention shortening some of the rediculously long intercooler pipe runs that on our kits.
Pegasus White
Drives: 86
No space under there for a top mount or any other style.
Long piping? Looks about the same length as most front mounts
Driving: Pegasus White Manual GTS 86.
That Guy
Drives: 2013 asphalt FRS MT
Nameless hinted at a v mount, but certainly hasn't said anything concrete.
Drives: 2013 Firestorm FR-S
I think, at some point, the temperature of the air going over the intercooler isn't AS important as the fact that SOME air is going over the intercooler. Top mounts have a tendancy to heat soak faster, being mounted on top of an already hot engine. I've seen some interesting split intercoolers on Audis, but our car isn't engineered in such a way to make that possible. A V-mount would be cool, but how would it actually mount without a custom front engine cage (ditching the factory bumper beam and front assembly almost completely ala Greddy D1 FRS).
I'd think with an A/W setup, you have a little more freedom in where to mount said heat exchanger, but mostly because the lines running to it are so much smaller. You could do a rear mount setup (in the haunches over the rear wheels) but then you'd have to engineer scoops to get air to it. Unfortunately, front mount seems to be the easiest, most cost effective way to get the job done. Isn't that why most cars have the radiator mounted low and up front, to collect as much air as possible? |
Drives: Sterling BRZ Ltd
I think a V-Mount would be awesome on a BRZ. It would be a lot of work but I believe just about anything can be done. I built a V Mount in my GR STI.
Drives: red frs
The rad support unbolts so that is a no cut affair. Hood is easy to make an opening in to extract heat and I believe battle version or someone has a tube beam...
It obviously wouldn't be an over the counter solution, but there should be someone willing to try. |
#10 |
Drives: fr-s and tc2
here ya go.
#11 |
NASA SpecE30 Racer
What turbo kit is that? I think a V mount setup would be really easy on this car. It would come with a new top support since it can be unbolted.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#12 |
Troll Feeder
Drives: boosted scion tc.
Looks like a greddy kit with a personal touch.
Looks to be next to the greddy tc2 as well. |
#13 |
Drives: FR-S 10 #103 AT
Someone do water/air damnit.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
#14 |
Drives: red frs
i was thinking the avo kit with a v-mount similiar the smax car i posted up top would be easy.
almost no plumbing involved so the spool time would be instant. |
| How bad is turbo without intercooler? | mid_life_crisis | Forced Induction | 50 | 06-23-2013 12:57 PM |
| 2010 Les Paul Traditional $1700 | ExWhyZer0 | Miscellaneous | 5 | 03-11-2013 06:03 PM |
| Another turbo with but water to air intercooler | ahaghshenas | Forced Induction | 8 | 09-24-2012 02:22 AM |
