Old 08-14-2014, 10:47 PM   #505
DC2R
Drives: 2014 Scion FR-S
Tony, how you holding up after the crash?
Sent from my SM-N900T using Tapatalk
DC2R is offline   Reply With Quote
Old 08-15-2014, 01:20 AM   #506
PMok
Codename: Stitch
PMok's Avatar
Does anyone else have this problem? I have a 900C (US 6MT) Cal ID.
using OpenFlashManager v1.10. and unmodified, freshly downloaded OTS ROMs.
No problem selecting and loading v2.03b ROMs for Stg 2 EL E85 to the tablet.
But whenever I try to select v2.03b Stg 1 91 oct 900C it won't let me, says "file is not compliant". In fact I tried all the Stage 1 91 oct ROMs none of them will let me load.
If I select Stage 1 93 oct 900C then it loads fine. I want to load the Stg 1 91 oct 900C but that is the one that won't work.
Perhaps something is wrong with the ROM file for the 900C 91 oct?
@Shiv@Openflash
I would say its a small oversight and the D00C in the rom has not been changed to 900C so the OFT will see it as compliant with your 900C stock file, shiv will fix it in a " flash"
You can fix it by making you own 91 tune . Open the 93 tune in RR then compare with the 91 tune copy the table changes, think their is only one changed the ignition advance tabe, copy the 91 table to the 93 tune then save as 91 tune and your done
well i gave it a shot but even after loading the new XMLs I can't seem to load and edit the tunes myself with sufficient confidence that it is safe. I'm getting a bunch of mismatch and checksum errors in RomRaider when opening the files so I don't think I can trust it. I would much rather have Shiv and his team address this issue and release a proper 91 oct tune file for the 900C.
@Shiv@Openflash @Robert@Openflash @Garrett@Openflash
Old 08-15-2014, 01:30 AM   #507
cnk
Drives: '13 DGM BRZ Limited
You'll always get the checksum errors when opening up the files. The checksum is corrected by OFT Manager when you upload the map to OFT. Shiv stated this earlier.
The Following 2 Users Say Thank You to cnk For This Useful Post:
Shiv@Openflash (08-15-2014), steve99 (08-15-2014)
Old 08-15-2014, 04:11 AM   #508
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Hi guys
v2.04 map folder is now available for download. We just added support for some new 2015 non-USDM ROMs. More will be added soon.
Changes:
(8/15/13):
v2.04b
-Add tuned ROM support for ZA1JD00G (EU 6MT) and ZA1JA2A (DOM 6MT) Calibration IDs.
-XML files for ZA1JD00G and ZA1JA2A have also added to v2.04 XML folder. Launch control and Flat-Foot Shift is not implemented yet.
Enjoy!
Cheers
shiv
Shiv@Openflash is offline   Reply With Quote
The Following 4 Users Say Thank You to Shiv@Openflash For This Useful Post:
flippy (08-15-2014), steve99 (08-15-2014), troek (08-15-2014), Wayno (08-15-2014)
Old 08-15-2014, 04:35 AM   #509
troek
troek's Avatar
Drives: 2012 Toyota 86
I should have no problem flashing za1ja2a on my car(originally za1ja1a)?
troek is offline   Reply With Quote
Old 08-15-2014, 04:41 AM   #510
steve99
Drives: FT86
Should be ok mate but if it wont load I have a trick that might do it :-)
troek (08-15-2014)
Old 08-15-2014, 04:48 AM   #511
troek
troek's Avatar
alright im about to give it a shot right now, just getting home.
Old 08-15-2014, 05:11 AM   #512
troek
troek's Avatar
yeah, no dice. says selected file is not compliant
Old 08-15-2014, 05:49 AM   #513
Ondreiko
RWD addicted
Ondreiko's Avatar
Drives: BRZ 6MT OFT OFH
Originally Posted by Shiv@Openflash View Post
Hi guys
Changes:
(8/15/13):
v2.04b
Enjoy!
Cheers
shiv
Hi Shiv!
Desperately waiting for v 2 for A00G please
Ondreiko is offline   Reply With Quote
Old 08-15-2014, 06:57 AM   #514
AP756
Drives: GT86 Toyota
>> -Add tuned ROM support for ZA1JD00G (EU 6MT) and ZA1JA2A (DOM 6MT) Calibration IDs. <<
YES :-). Will try tonight.
AP756 is offline   Reply With Quote
Old 08-15-2014, 08:10 AM   #515
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Pretty well, just wish the "experts" weren't so misinformed
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
The Following User Says Thank You to tonystewart For This Useful Post:
DC2R (08-15-2014)
Old 08-15-2014, 08:45 AM   #516
tonystewart
What is the trick?
Old 08-15-2014, 09:10 AM   #517
steve99
Drives: FT86
Originally Posted by tonystewart View Post
What is the trick?
not really a trick involves a hex editor and manipulating CALID
Old 08-15-2014, 11:26 AM   #518
Mungbean
read the OFT TIPS link below
Thank you sir!
According to Shiv, I should use the "OTS OFT300 map" for my vortech setup.
I downloaded all of the map packs from the OFT site but don't see it. Am I missing something here?
Mungbean is offline   Reply With Quote
OpenFlash Tablet v1.42b maps now available Shiv@Openflash Software Tuning 159 09-13-2016 12:29 AM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 05:23 PM
OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted Shiv@Openflash Software Tuning 142 07-22-2014 10:21 PM
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) Shiv@Openflash Software Tuning 255 02-15-2014 04:43 AM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
