Old 08-13-2014, 09:03 PM   #491
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
If you rearly keen you could do you own rom. compare a V1.5 C series with V2 C series then Copy all table changes to your series ROM then send to shiv to save him some work
I'd do this if I had a very specific procedure to follow!
Old 08-13-2014, 09:09 PM   #492
Fleischwagen
Drives: 2013 BRZ, 1979 Scirocco 16v
Well I sorted my issue out, turns out I didn't realize I had the wifi turned off on my PC laptop in which I run the manager and the software level of my tablet was wayyyy low. Once it updated it just by plugging it in and rebooting the program, all was golden.
PS, the new 2.03 93 map is waaay more smooth, better low end drivability. Still have some learning to go though. IAM still pegged at 1.00 which is good
I just ordered a Tomei UEL so we'll see how the stage 2 version feels compared to stage 1.
Fleischwagen is offline   Reply With Quote
Old 08-13-2014, 10:21 PM   #493
Lytheum
Drives: 2013 BRZ Premium 6MT
Originally Posted by Vanilla View Post
This has happened to me twice as well..stage 1 93 oct tune.
I have had it bog a few times on stage 1 93. Felt like I was starting in the wrong gear almost or traction control was killing power. Once I got to 7 or 8 mph they car felt normal again. Also glad I didn't get hit making a left into traffic.
2013 Subaru BRZ Premium 6MT -STOCK!
Lytheum is offline   Reply With Quote
Old 08-13-2014, 10:30 PM   #494
steve99
Drives: FT86
Writing an exact proceedure takes a long time, its not straight forward as the defined tables differ between tunes. Ill have a look if i get time , shiv should have them out soon anyway
Old 08-14-2014, 02:08 AM   #495
clintavo
Originally Posted by Turdinator View Post
My guess is the cold start routine is causing your issues. Generally speaking you shouldn't floor it during warm up or at such a low RPM. As Kodename47 suggested, full throttle below 2.5k is not a great idea. If you need to accelerate from that low an rpm at least slip the clutch little to bring the revs up. Its not a V8.
It has been fully warm each time it happened. I don't floor it at low rpm as a matter of course, but every once in a while, a situation calls for it; no time for a clutch pop when you're about to be hit.
I'll get a log of it.
clintavo is offline   Reply With Quote
The Following 2 Users Say Thank You to clintavo For This Useful Post:
d1ck (08-14-2014), Turdinator (08-14-2014)
Old 08-14-2014, 08:21 AM   #496
d1ck
Drives: Black 2013 FRS
My car was up to running temp as well. I can make it happen any time by applying heavy throttle at low rpm. I haven't tried to find the threshold yet.
d1ck is offline   Reply With Quote
Old 08-14-2014, 08:23 AM   #497
troek
troek's Avatar
Drives: 2012 Toyota 86
Yeah you guys need to log this and post it. Lets see whats going on
troek is offline   Reply With Quote
Old 08-14-2014, 10:02 AM   #498
TM
TM's Avatar
Drives: DGM BRZ 6MT
Three days into my first tank of E85. I finally experienced the difficulty in cranking the engine on cold starts that everyone was talking about. 57°F and did not start up the first time; barely made it the second time.
TM is offline   Reply With Quote
Old 08-14-2014, 10:13 AM   #499
xxBrun0xx
xxBrun0xx's Avatar
Drives: 2014 WRB BRZ Limited
So your car noticeable bogs every time your car starts moving from a dead stop? I understand bogging in a high gear, but not in low gears...
xxBrun0xx is offline   Reply With Quote
Old 08-14-2014, 11:31 AM   #500
d1ck
Yes. If I apply heavy throttle below 2000RPM the car bogs very badly and starts bucking.
The Following User Says Thank You to d1ck For This Useful Post:
JB86'd (08-14-2014)
Old 08-14-2014, 08:37 PM   #501
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
First Run with V2.0, literally 2 miles after flash
http://www.datazap.me/u/tonystewart/...log=0&data=1-3
I removed the FA20Club.com CAI.
New setup is Perrin Inlet Hose, K&N Air Filter, HKS Intake Duct, Stock Intake box.
The car drives smoother and quieter.
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
The Following 2 Users Say Thank You to tonystewart For This Useful Post:
flippy (08-15-2014), JB86'd (08-14-2014)
Old 08-14-2014, 09:26 PM   #502
Mungbean
Hey guys, probably a noob question, but how do you know which tune to use based on your mods?
Mungbean is offline   Reply With Quote
Old 08-14-2014, 09:31 PM   #503
steve99
Drives: FT86
read the OFT TIPS link below
Old 08-14-2014, 09:40 PM   #504
ALB
It's a lot simpler than it seems. If you don't have an aftermarket header, use stage 1. If you have an aftermarket header use stage 2 appropriate for your header's tubing length design. For the version 2.x tunes, use the tune appropriate for the fuel type you purchase (or lower)
Only exception is that you can use stage 2 EL E85 tune on a stock header running e85
ALB is offline   Reply With Quote
OpenFlash Tablet v1.42b maps now available Shiv@Openflash Software Tuning 159 09-13-2016 12:29 AM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 05:23 PM
OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted Shiv@Openflash Software Tuning 142 07-22-2014 10:21 PM
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) Shiv@Openflash Software Tuning 255 02-15-2014 04:43 AM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
