View Poll Results: What color of Series.Blue did you opt for?
Blue 176 55.70%
White 140 44.30%
Voters: 316. You may not vote on this poll
Old 08-13-2014, 12:58 PM   #225
x1UP
One & Done (AOZORA)
x1UP's Avatar
Drives: '15 Series.Blue BRZ (WRB)
Originally Posted by football751 View Post
Does the manual state to keep the RPMs that low for the first 1000 miles? You can't even make 70 mph under 2500 rpms. I think you're good to shift fairly normal at 3k-4k rpms, I'd just avoid flooring or redlining it.
Nothing in the manual states anything like that, I just get a feel for the engine and it seems like it wants me to shift already at around 2K, so I do.
"I have the need....the need for speed! - Maverick (Top Gun)
x1UP is offline   Reply With Quote
Old 08-13-2014, 01:05 PM   #226
football751
Drives: n/a
I think you need to open it up a bit and see how it feels. From my experience (at 3800 miles now) the shifter and synchros broke in so the shifts feel better, but the engine responds pretty much the same as the day I bought it. I think it's a characteristic of the high-revving boxer engine. If I'm driving in 2nd at 20 mph around 2700 rpm it does feel like it wants me to shift, but if you're accelerating you want to push past that into 3k-4k rpms at least until you shift. In higher gears cruising speed is in the 3k-4k rpm range. The engine has a tendency to knock below 2k rpms (IRRC).
football751 is offline   Reply With Quote
Old 08-13-2014, 01:10 PM   #227
x1UP
One & Done (AOZORA)
x1UP's Avatar
I've always thought it was at around 3k-4k to shift, but maybe it's because i'm only at around 50 miles? I think i'll try to open it up more, but I'm always second guessing that i'm hurting the engine by not shifting when it wants to, as I stated above.
Old 08-13-2014, 01:40 PM   #228
Speed2th
I love my series blue brz
Speed2th's Avatar
Drives: 2010 335d
I dont follow the shift indicator, speeds are too low for those gears and could cause knocking and unrewarding driving experience. I usually shift at 3-4k
Speed2th is offline   Reply With Quote
Old 08-13-2014, 01:42 PM   #229
fungizmos
fungizmos's Avatar
Drives: 2015 Series.Blue, Mx6, Rx-7
Hi,
Bet you are happy to be back from vacation to play with your new car!
So you are talking about the shift indicator when you enable the display of the current gear indicator?
That will be a recommendation for fuel economy that is triggered on sensor/vacuum levels. It is adaptive so if you are driving harder you will see different shift points.
Just try and keep it under the recommended max rpm and vary your speed/driving methods until 1k and you will be fine.
2500 miles already here
-Will
--Will
fungizmos is offline   Reply With Quote
Old 08-13-2014, 01:45 PM   #230
football751
Drives: n/a
With how engines are built these days I think you'd have to do something pretty serious to damage the engine in the first 1000 miles. Just think of all the cars that are bought new but with 50-100 miles on them from test drives. You know they were worked pretty hard during those test drives, I doubt anyone thinks about the engine breakin period when test driving a car.
Also, I think "when the car wants to" is pretty subjective. Are you basing that on the engine noise and how it's responding to the throttle? I find it doesn't want to hang out in 1st or 2nd gear, as this isn't a Corvette that can do 60 mph in 1st. But pushing it into 3k-4k rpms during the breakin in 1st or 2nd isn't going to hurt anything.
Old 08-13-2014, 01:48 PM   #231
Rota
Rota's Avatar
Drives: 2015 Series.Blue BRZ
Is it just me, but while i'm breaking in the car to 1000 miles (i'm at 50 miles only I think), but the engine forces me to shift into such a low RPM range (usually around 2K-2500 rpm) and the ranges are so short.
For example,
1st 0-5
2nd 5-15
3rd 15-25
4th 25-35
So on and so forth.
Am I missing something here or is it just me? Please don't roast me. Any explanation would be appreciated.
I was told to keep it below 4k RPM for the first thousand miles. You're shifting way too early.
Rota is offline   Reply With Quote
Old 08-13-2014, 01:52 PM   #232
cameronjones239
cameronjones239's Avatar
Drives: 2015 Subaru BRZ Series Blue
Around 15mph per gear, is what I'm doing if I remember right. Keep in mind the sound tube makes the interior sound louder than it really is.
cameronjones239 is offline   Reply With Quote
Old 08-13-2014, 02:59 PM   #233
quality_sound
Drives: '15 BRZ Series.Blue
Shift indicator? I haven't seen that in mine.
quality_sound is offline   Reply With Quote
Old 08-13-2014, 03:42 PM   #234
x1UP
One & Done (AOZORA)
x1UP's Avatar
I've realized that and i've just started to open it up a bit more by shifting in the 3k area.
It feels more more precise and better than it was yesterday. I've set the indicator at 3k just in case and the car feels great.
Just tested it out by driving around on a freeway and it was reliving.
Old 08-13-2014, 03:49 PM   #235
metier
Drives: 2015 Subaru CWP Series.Blue
You can go into the settings and turn it on, in the ODO/TRIP
Odometer
Trip meter A*1
Trip meter B*1
Setting screen for tachometer indicator needle movement function when starting the vehicle*2
Setting screen for the shift position indicator and shift-up indica- tor*2 (vehicles with a manual transmission)
*1:Pressing and holding the “ODO/TRIP” switch will reset the trip meter that is currently displayed.
*2:Only displayed when the engine switch is in the “ACC” or “LOCK” position (vehicles without a keyless access with push button start system), or when the push-button ignition switch is in “ACC” mode or turned off (vehi- cles with a keyless access with push button start system).
page 189 in the manual
metier is offline   Reply With Quote
Old 08-13-2014, 04:02 PM   #236
Toca
I have a shift light and indicator for 3.5k. It works really well when I try not to break past 4k limit. I'm at about 1500 miles in and shifting is not as rough as before and everything is way slicker.
Toca is offline   Reply With Quote
Old 08-13-2014, 04:04 PM   #237
Toca
Originally Posted by metier View Post
You can go into the settings and turn it on, in the Multi Display
Odometer
Trip meter A*1
Trip meter B*1
Note that you have to do this when your car is NOT MOVING...otherwise, the shift light indicator won't show up. Well, it makes common sense to do this when you're NOT driving...but I tend to mess around with the buttons in my car while I drive, haha.
Old 08-13-2014, 05:16 PM   #238
trinxified
Drives: Subaru BRZ Aozora Edition
So how do you actually turn it on? The shift indicator and it shows you what gear you're currently in?
I couldn't understand what the manual says about it...
trinxified is offline   Reply With Quote
2015, brz, heuburger, series.blue
Subaru USA's New 2015 BRZ Series Blue with STI Parts has a Placebo Effect…. vh_supra26 BRZ First-Gen (2012+) — General Topics 393 07-30-2014 01:27 AM
10 series vs. 2015 fr-s initialrt Scion FR-S / Toyota 86 GT86 General Forum 33 06-28-2014 10:40 PM
2015 FR-S or discounted 2013 10 Series? bostnwhalr Scion FR-S / Toyota 86 GT86 General Forum 29 06-12-2014 10:19 PM
(10-SERIES) Any way to disable blue LED on emblems? R4PT0R-X Cosmetic Modification (Interior/Exterior/Lighting) 0 05-27-2014 10:46 PM
