Old 08-11-2014, 04:57 PM   #43
CSG Mike
CSG Mike's Avatar
Originally Posted by sw20kosh View Post
My cruising IAT is always 10 deg warmer than ambient. I am guessing either because:
1. ptuning air filter is in engine bay
2. oil cooler is in front of IC
Both of those conditions apply to the JR kit, but the JRSC places the filter in the same relative location as stock; it gets direct airflow from the hole where the stock intake snorkel used to be.
Old 08-11-2014, 06:12 PM   #44
sw20kosh
Drives: 2013 Black FR-S
Your oil cooler is not in front of the IC is it? I thought it was behind the IC.
Old 08-11-2014, 09:05 PM   #45
Dezoris
Dezoris's Avatar
You guys running oil pressure gauges now as well?
I stopped tracking the car longer than 20 minutes after watching pressures drop into the 43-44PSI range (7000RPM)when oil temps hit 240F.
Old 08-11-2014, 09:10 PM   #46
CSG Mike
CSG Mike's Avatar
Oh oops. I read that wrong. Yes, the EOC is behind the FMIC.
Old 08-11-2014, 09:55 PM   #47
Sleepless
Sleepless's Avatar
Drives: 2016 FR-S
Do you have oil pressure numbers that you could share? Graphs?
Sleepless is offline   Reply With Quote
Old 08-12-2014, 01:00 PM   #48
Dezoris
Dezoris's Avatar
Can't really do any logging since gauge is independent using oil gallery plug. (Testing on two different gauges.)
But I have been doing a long ass video about comparing the S2000 vs the 86 platform which has including about 10 hours of hard street driving and now track.
After about 200F you start seeing 55-60PSI at 7000RPM
After about 210F you start seeing 49PSI at 7000RPM
After about 220F you start seeing 43-45PSI at 7000RPM
After about 230F you start seeing 40-45PSI at 7000RPM
After that, I had my two testers never rev past 6000RPM, on the track session is over.
Now with that said, I have two UOA after long track days showing no metals. But I think at least for me, I am going to hang up any longer sessions with this car going forward because of this.
The Following 4 Users Say Thank You to Dezoris For This Useful Post:
CSG Mike (08-12-2014), juliog (09-07-2014), Pat (08-12-2014), Sleepless (08-13-2014)
Old 08-12-2014, 01:54 PM   #49
CSG Mike
CSG Mike's Avatar
Tfi.
Old 08-12-2014, 02:09 PM   #50
Dezoris
Dezoris's Avatar
Tfi.
Thanks for invite or info? Seen it both ways.
If its invite, we live in the wrong states and you already know which is better.
Old 08-12-2014, 02:23 PM   #51
CSG Mike
CSG Mike's Avatar
Maybe you should move here
Old 08-12-2014, 08:49 PM   #52
sw20kosh
Um so what was I getting at 260+ F oil temps? 30 psi? What is considered a dangerous range?
Don't people who track their stock 86's see 280+ F oil? The must really be in the danger zone for oil pressure then?
Old 08-12-2014, 10:02 PM   #53
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
The problem with oil temps and pressures are not usually immediate results. Can you run your oil that hot a few times during a weekend and then dump the oil afterward? Yup. Will your motor blow up immediately? Probably not. However if you do it long enough eventually you will have long term bad effects on the engine.
Similar to say a mechanical rear limited slip differential combined with sticky tires. Will it blow the rear end immediately and in a spectacular way? Probably not. Is it bad for it long term? You bet.
Similar goes for Oil and Coolant temps. Long term effects will be bad.
-Mike Paisan
Maintaining, Modifying and Educating TriState Enthusiasts since 2001.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
The Following User Says Thank You to AZP Installs For This Useful Post:
CSG Mike (08-13-2014)
Old 08-13-2014, 12:09 AM   #54
Dezoris
Dezoris's Avatar
If you are seeing low 40s it's time to back off.
-Mike Paisan
Basically yes.
If you track, get a gauge, set an alert for 40PSI if you hit it that, stop if you care about the longevity of the bottom end.
The Following 2 Users Say Thank You to Dezoris For This Useful Post:
CSG Mike (08-13-2014), glamcem (09-07-2014)
Old 09-07-2014, 01:31 AM   #55
sw20kosh
@CSG David
You mentioned you were looking at 20 row series 9.
Well mkivsoopra and I installed 25 row series 9 setrabs.
Did the 6.5k rpm 3rd gear on freeway for 20 mins in 70 F ambient. Couldn't get it above 207 F.
Did the same for 5 mins on a mountain pass (still freeway) to stress the motor even more. Saw it max out at 220 F. Coolant never went above 203 F.
A month or so ago I did this same test with the 13 row series 6 and a few weeks before that a 7" Mocal laminova. Saw 260 F in less than 10 mins on flat freeway in same 70ish ambient.
The Following 8 Users Say Thank You to sw20kosh For This Useful Post:
AZP Installs (09-07-2014), CSG Mike (09-07-2014), dradernh (09-07-2014), glamcem (09-07-2014), mkivsoopra (09-07-2014), MyRx (09-07-2014), rb6freak (09-07-2014), unsurety (09-08-2014)
Old 09-07-2014, 02:38 AM   #56
RehabJeff86
RehabJeff86's Avatar
Drives: 2013 WhiteOut FR-S
Super efficient oil cooler
Sent from my iPhone using TapatalkfQ
2013 Scion FR-S whiteout
2012 Porsche Panamera S carbon grey
2008 Range Rover Sport SS black - sold
2004 BMW M3 alpine wies - sold
RehabJeff86 is offline   Reply With Quote
HKS Oil Cooler Kit - Keep those oil temps down. - Photos FT-86 SpeedFactory Engine, Exhaust, Transmission 23 08-10-2015 03:08 PM
Robi-Cooler Install....Oil Temps under 180??? Deep Six Engine, Exhaust, Transmission 28 08-07-2014 12:30 PM
Oil Temps Fish Eagle AFRICA 13 07-22-2014 05:53 PM
Robispec Radiator/oil cooler NEW $800 or trade for NEW FB oil cooler kit. mike the snake Engine, Exhaust, Bolt-Ons 1 01-31-2014 05:46 PM
