Old 07-09-2014, 03:07 PM   #57
SCHN3LL
Drives: '13 GBS BRZ
Just went to the corn juice a few days ago. Loving it so far.
For anyone on the fence, my advice...
SCHN3LL is offline   Reply With Quote
The Following 2 Users Say Thank You to SCHN3LL For This Useful Post:
DAEMANO (07-15-2014), DC2R (08-11-2014)
Old 07-09-2014, 04:09 PM   #58
steve99
Drives: FT86
Originally Posted by mmmcambelsoup View Post
@steve99 brought my car to an exhaust shop to check for any leaks. They found a slight leak where overpipe/header and header itself. Tightened that up and ltft during idle did drop a little from 14.06%. I'll keep monitoring to see if it drops below 10%.
Might be worth trying a new gasket, you only get one shot compressing them, then they just leak a few weeks later.
mmmcambelsoup (07-09-2014)
Old 07-15-2014, 06:59 PM   #59
DAEMANO
Time Traveller
Originally Posted by gonzo View Post
what's the cheapest e85 compatible oil for those of us in the USA?
Don't know what the cheapest is but I run Amsoil Signature Series
Old 08-12-2014, 12:02 AM   #60
DC2R
Drives: 2014 Scion FR-S
I'm at under a quarter tank. Really want flash Oft tune on fill up. Almost due for second oil change. First done at 1200 miles. Got then to schedule me again for 6500 miles. Feel like I already paid for the dealer oil changes do why not use then right? Maybe I can use special e85 oil in between dealer changes...
Sent from my GT-N5110 using Tapatalk
DC2R is offline   Reply With Quote
Old 08-12-2014, 12:08 AM   #61
DC2R
From what I understand SN rated oil is for 2011 and newer cars. This spec also covers e85?
This would mean that dealer oil is e85 safe??? I'm a few beers in so I may be misinterpreting.
Old 08-12-2014, 01:31 AM   #62
Kronos
Kronos's Avatar
Drives: Asphalt FR-S MT
+1 I'm curious as well
Kronos is offline   Reply With Quote
Old 08-12-2014, 02:09 AM   #63
steve99
Drives: FT86
According to specs SN rated oil should be E85 bio fuel compatable compatable.
I change mine to one that specificly states it is E85 compatable, just to be sure
Old 08-12-2014, 09:11 AM   #64
DC2R
This would lead me to believe that dealer oil is fine. I think they gave me on a 5k interval. Night be able to get away with just their oil changes. Of course I will have to fill with 93 even I take it in due to catless header(alcohol smell)
Sent from my SM-N900T using Tapatalk
Old 08-12-2014, 08:14 PM   #65
DC2R
Just flashed
The Following User Says Thank You to DC2R For This Useful Post:
Kronos (08-12-2014)
Old 08-12-2014, 10:44 PM   #66
Turdinator
Señor Member
Turdinator's Avatar
Originally Posted by s2d4 View Post
You won't be able to go back...
I tried, couldn't do it..
This is what worries me. I know once i try it i won't want to go back and I'll be annoyed anytime i can't fill up with E85.
1974 TA22 Celica
2013 86 GT
Old 08-12-2014, 10:48 PM   #67
s2d4
s2d4's Avatar
Just fill up whenever you see one, I get about 450km per tank on E85 on my driving habits, hasn't been an issue in finding E85 at all and you probably have more E85 stations in Melbourne than perth.
Old 08-12-2014, 11:17 PM   #68
DC2R
EDIT:
Don't want to rag on it until safe.
Ok so I put some miles in it after filling up.
Then I flashed.
Then I drive light throttle about five to ten miles.
At idle STFT is at around 0. LTFT is about -2.
Guessing there is still petrol in tank....
Old 08-18-2014, 02:42 AM   #69
Turdinator
Señor Member
Turdinator's Avatar
EDIT:
Then I flashed.
I believe its once your lfts have settled and they are below 10 either positive or negaitive you'll be fine. It is safer when they are negative as it means you have been running rich. I wouldn't worry about the trims at idle, even on petrol mine vary wildly.
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
DC2R (08-19-2014)
Old 08-18-2014, 05:18 AM   #70
steve99
Drives: FT86
EDIT:
Then I flashed.
Check your Long term fuel trims over entire rpm range once its below 10 at low med and higher rpm it good to go. as per first post steady partial throttle driving speeds learning ie closed loop fueling mode.
Short term fuel trim will always vary depending on load.throttle ect.
DC2R (08-19-2014)
Stock FR-S Tune Just Done Zach3794 Engine, Exhaust, Transmission 67 11-05-2017 02:01 PM
stock BR-Z, much detonation during shifts: tune? elefunkd Engine, Exhaust, Transmission 69 07-26-2013 04:20 PM
Anyone have a stock tune from Visconti? Bleevin CANADA 3 07-03-2013 01:01 AM
My Initial (all stock) BRZedit tune mad_sb Engine, Exhaust, Transmission 6 02-16-2013 12:20 PM
Save stock tune with ecutek? gdrider77 Engine, Exhaust, Transmission 7 01-06-2013 12:50 AM
