Old 06-24-2014, 10:29 AM   #43
Cockatoo
TALLY FT86
Cockatoo's Avatar
Drives: 2014 FR-S Monogram -- SBD Turbo --
Yep, I have some Redline sitting right here when the time comes
Cockatoo is offline   Reply With Quote
Old 06-24-2014, 01:28 PM   #44
Cockatoo
TALLY FT86
Cockatoo's Avatar
Here we go...
The Following 2 Users Say Thank You to Cockatoo For This Useful Post:
edeekeos (06-24-2014), Kronos (06-24-2014)
Old 06-24-2014, 10:45 PM   #45
s2d4
s2d4's Avatar
Originally Posted by Cockatoo View Post
Here we go...
You won't be able to go back...
I tried, couldn't do it..
The Following 2 Users Say Thank You to s2d4 For This Useful Post:
Cockatoo (06-24-2014), Superhatch (06-24-2014)
Old 06-24-2014, 10:52 PM   #46
Superhatch
AIM4APX
Superhatch's Avatar
Drives: 2013 WRB BRZ Limited
heh. I was worried about that. I'm about 5k into my e85 tune and it feels stronger than ever. Perrin intake for now is my only engine mod. oft header, Perrin resonated exhaust, shorter rear end, light driveshaft and flywheel and this will feel perfect I think.
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
Superhatch is offline   Reply With Quote
Old 06-24-2014, 11:02 PM   #47
s2d4
s2d4's Avatar
I wouldn't bother with the CBE, driveshaft or flywheel yet unless it is just for sound or lightness feel.
Stock exhaust with cat warm up removed using romraider/OFT is free, not loud and clearly has rumble.
The money you saved from drive shaft/flywheel/cbe, you could definitely get the esc on e85 with money to spare.
Old 06-24-2014, 11:02 PM   #48
Kronos
Kronos's Avatar
Drives: Asphalt FR-S MT
You and I sir, have the exact same plan
It just sounds like the perfect recipe
Kronos is offline   Reply With Quote
The Following User Says Thank You to Kronos For This Useful Post:
Old 06-24-2014, 11:31 PM   #49
poptopclk
Drives: Scion FR-S 10 Series
not worried on oil
I have 2200 miles and just did flash 2 tanks ago. I'd say a couple thousand miles won't make any big difference on oil changes.
However, oil is cheap so I will change sooner rather than later. Will use an ethanol rated oil from here on out.
ONLY, down side is fuel consumption. I get about 100 less miles per tank then again a fill-up is 10 bucks cheaper.
I'd rather have the performance. The engine loves this fuel/tune combo
poptopclk is offline   Reply With Quote
The Following User Says Thank You to poptopclk For This Useful Post:
lucid215 (08-12-2014)
Old 06-26-2014, 09:13 AM   #50
Necric
Originally Posted by mmmcambelsoup View Post
This is probably beating a dead horse, but what are normal (LFT's & AFR) at idle, cruise & WOT?
I'd like to know this as well.
Also would investing in some better injectors help at all?
Necric is offline   Reply With Quote
Old 06-26-2014, 10:15 AM   #51
steve99
Drives: FT86
LTFT less than 10%
LTFT is fueling error does not indicate if injectors maxed out.
you would need to look at injector pulse width and duty cycles and max flow rates ect to work that out
AFR under load should be near whats in Open loop fuel table
At WOT AFR around mid 12 midrange, high rpm low 12 high 11 on E85
Stock injectors ok for NA E85 , probably going need replacing if going FI on E85 with larger capacity.
The Following 3 Users Say Thank You to steve99 For This Useful Post:
EffaressNOOB (08-02-2016), Necric (06-26-2014), sydious (05-30-2015)
Old 06-26-2014, 07:43 PM   #52
Cockatoo
TALLY FT86
Cockatoo's Avatar
This is so crazy... Over the past two days I've literally heard the E85 killing the crickets!!
I went from a steady swarm of crickets, to a handful of crickets, and now after today I think they might be gone.....
The Following User Says Thank You to Cockatoo For This Useful Post:
MyNave (04-03-2017)
Old 06-26-2014, 09:15 PM   #53
steve99
Drives: FT86
Additives in some E85 suppress crickets, usually alchol will fire them up like with 10% alchol fuels, but it appears with most E85 the additives possible some form of lubticant kills them off.
Dont worry they will return one you go back to a 10% petrol blend
The Following 2 Users Say Thank You to steve99 For This Useful Post:
MyNave (04-03-2017), skye67 (07-12-2014)
Old 07-07-2014, 09:13 PM   #54
mmmcambelsoup
mmmcambelsoup's Avatar
Drives: FR-S 10 series
@steve99 w/ catless header recently installed, and e85 map stage 2.
idle = (afr 14.69, ltft 14.06%, adv mult 1.00)
cruise = (afr 14.69, ltft below 10%, adv mult 1.00)
wot = (low/mid 12's, ltft below 10%, adv mult 1.00)
... why is my ltft so high during idle? Do I have a leak w/ my new header?
mmmcambelsoup is offline   Reply With Quote
Old 07-08-2014, 02:41 AM   #55
steve99
Drives: FT86
Are the fuel trims always positive or always negitive
is this you first tank of e85
if they are always negitive it the tune compensating for low e% ie high petrol.
the trims will be close to zero near e70 ot their abouts
as the e% varies with e85 the fuel trims will wander to compensate. as no flex fuel sensor ,
looks ok
you rearly need to go back to petrol and then look at you fuel trims and if they were still 10% or so do maf scaling when on petrol ( second tank )
the afr at cruise idle will be in 14 as you see but under load it should be in 12 to 13, and high rpm high load low 12 maybe high 11.
the o2 sensor doesnt know your on e85 so its reading ok as its just calibrated to read petrol stoich 14.7
what were you fuel trims like on petrol ? not unusual to see 5 to 8% on petrol on a non scaled maf
mmmcambelsoup (07-09-2014)
Old 07-09-2014, 11:34 AM   #56
mmmcambelsoup
@steve99 brought my car to an exhaust shop to check for any leaks. They found a slight leak where overpipe/header and header itself. Tightened that up and ltft during idle did drop a little from 14.06%. I'll keep monitoring to see if it drops below 10%.
Stock FR-S Tune Just Done Zach3794 Engine, Exhaust, Transmission 67 11-05-2017 02:01 PM
stock BR-Z, much detonation during shifts: tune? elefunkd Engine, Exhaust, Transmission 69 07-26-2013 04:20 PM
Anyone have a stock tune from Visconti? Bleevin CANADA 3 07-03-2013 01:01 AM
My Initial (all stock) BRZedit tune mad_sb Engine, Exhaust, Transmission 6 02-16-2013 12:20 PM
Save stock tune with ecutek? gdrider77 Engine, Exhaust, Transmission 7 01-06-2013 12:50 AM
