Drives: 16' WRX
Installed Cusco Catch can wrong? Running lean
Hey guys,
I think I migh of installed my cusco catch can wrong because it threw a CEL. I took it to the dealership and they told me the car was running lean because of the catch can, I'm thinking I installed the can wrong? could anyone help me fix this? Thank You |
#2 |
Drives: 2013 DGM BRZ, 2020 C8 Corvette
since you didn't provide any photos or additional info to go on, if you remove it and return it back to stock, and you don't throw a CEL, then you probably installed it wrong.
My DGM BRZ vid: https://www.youtube.com/watch?v=0OL9OhxexAA
My car journal thread: http://www.ft86club.com/forums/showthread.php?t=43402 |
#3 | |
Drives: 16' WRX
![]() http://imgur.com/La4ShDp http://imgur.com/EUVNOVz http://imgur.com/W7Xynf1 Last edited by goshem; 08-11-2014 at 06:48 PM. |
#4 |
Señor Member
How did you use the OEM hose to fit the cusco tube fit? If you put the cusco hose over the stock hose which is over the pcv valve outlet then i would guess you are getting a vacuum leak there.
1974 TA22 Celica
2013 86 GT |
#5 | |
Drives: 16' WRX
Well I used the little v-clamp clips over the cusco hose to tighten it up with the OEM ones in it and made sure it's a tight fit. Not sure if you can understand what I'm saying. If I'm having a vacuum leak will the CEL come on again? The dealership deleted my CEL so so far there's no CEL. |
#6 |
Drives: 13 White MT FR-S
definitely a vacuum leak. The same thing happened to me after a tiny split in the hose appeared
#7 | |
Señor Member
If you have a vacuum leak and it is running lean it would throw a CEL.
1974 TA22 Celica
2013 86 GT |
#8 |
Drives: 16' WRX
yup that's exactly how I set it up, good job on the mockup lol. Now it's not throwing the CEL, I actually tightened up the v-clamp more.
#9 |
Drives: 16' WRX
Can anyone link me the adapter that I can buy to fit the Cusco hose properly to the pcv outlet
#10 |
Drives: 2025 BRZ, ex-2012 GT86
I can:
http://www.ft86speedfactory.com/cusc...-tank-731.html The pic and the name is wrong but the part # and price is right. I bought&installed it and it works well. |
#11 | |
Sarcastic SOB
Bought some 3/8" fuel line tubing (2' for $6), cut a 1" piece and fit it into the Cusco tubing. Slid it on the PCV and done.
#12 |
Drives: 16' WRX
thanks guys! appreciate the help
#13 |
Drives: 16' WRX
alright, so I tightened all the hose clamps up and I found the culprit.
![]() anyone know how to fix this? I'm pretty sure it's between the bolts that's leaking, I hear a whizzing sound there and when I close it with my fingers it goes away. |
#14 |
Sarcastic SOB
Teflon plumbing tape applied on the threads, then screw the fitting back in place. Make sure the tightening nut is tight.
| Catch cans: what are you running? | Apex Chase | Engine, Exhaust, Transmission | 144 | 08-14-2014 07:17 AM |
| Is my Cusco catch can correctly installed? | wbradley | Engine, Exhaust, Transmission | 9 | 02-24-2014 09:49 PM |
| running lean | EZWood | Engine, Exhaust, Transmission | 26 | 10-18-2013 12:53 PM |
| Slip+CEL = Bank1 running lean? | Trashed675 | Issues | Warranty | Recalls / TSB | 11 | 03-28-2013 10:53 PM |
| Dealership Installed Wrong Spoiler | Snowblind | Scion FR-S / Toyota 86 GT86 General Forum | 57 | 02-15-2013 05:57 PM |
