Old 07-22-2014, 11:45 AM   #141
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
Originally Posted by alexisfire02 View Post
I'm at about 5000 ft elevation. Put the 335 on a dyno last night with 80mm pulley.
It was generating about 14 lbs of boost. My built motor is a 10.5:1.
I am going to try it this week with a 75mm pulley.
Using e85 and was seeing about 280 whp.
Great even torque line starting at just under 300rpm.
I have another frs with a gtx30r and until nearly 6600rpm
The 335 has more torque and power. The turbo of course leaves it behind in whp after that
The 210 can do about that on e85 @ 12psi IIRC (CR is probably the main factor there). Do you know what the post charger IATs were? I am assuming no matter how big the blower is you are still going to generate about the same amount of heat by compressing that air. Efficiencies and peek MAF might come into play at higher rpms and higher boost.
What do you think is possible with that blower and a built motor? How much boost do you think it can hold?
2013 BR-Zed, Innovate Powered, Delicious Tuned, Zeltus Cooled. Build Thread
www.GT86Mounts.com
calispec is offline   Reply With Quote
Old 07-22-2014, 12:08 PM   #142
xwd
Do you have a plot you can share?
It's a big supercharger, I would expect it to be good to 20+ PSI on this motor. Biggest issue would be combating the additional heat generated at high boost. I haven't been real impressed by the integrated IC.
Old 07-22-2014, 12:37 PM   #143
alexisfire02
Drives: 2013 Pearl White FRS
Iat were about 140 to 145. I have an aluminum intake manifold that I think needs a heat wrap.
Turbo car is still 12.5
Yes, I meant 3000 rpm.
Also I'm on an auto, so the torque converter starts slipping around 7100 I believe.
I think we should have left the cr stock.
The elevation change lowered boost more than expected. And the bigger heat exchanger and pump seem to have helped a lot with the iat, they were about 190 in Miami
alexisfire02 is offline   Reply With Quote
Old 07-22-2014, 01:39 PM   #144
xwd
So this isn't a Sprintex kit with the manifold, you are just adapting the 335 to a custom setup?
I think if you are running E85 I would keep the CR stock or maybe 11.5:1 until you get into big turbo numbers.
Old 07-22-2014, 01:41 PM   #145
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
I think he meant to say intake. Not intake manifold. Granted the intake manifold is aluminum but it is still the same one from Sprintex that they provide with this kit. At least that's what it looks like from the pic in his build thread.
Dustin is offline   Reply With Quote
Old 07-22-2014, 01:43 PM   #146
xwd
Thanks, I hadn't looked at his build thread.
Old 07-26-2014, 12:48 AM   #147
alexisfire02
Trying to order smaller pulley... Probably be 3 weeks minimum before I can get around to getting this done and back onto a dyno...
Old 07-30-2014, 11:27 AM   #148
wsites
Drives: 08 STI|15 BRZ|95 L Coupe
But remember he is at 5,000ft... So that might be a factor??? On a side note, does anyone know when the heck sprintex is releasing the 335? I'm getting anxious...
Originally Posted by cantholdanymore View Post
People wants moar pawar
Kit provides moar pawar
Kit needs engine build to support moar pawar.
People call it fault
wsites is offline   Reply With Quote
Old 08-04-2014, 02:17 PM   #149
mid_life_crisis
Drives: FR-S 10 #103 AT
Why do you think that? Isn't it a locking converter? Why would it start to slip?
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 08-11-2014, 08:04 PM   #150
jet86
Mad Sciontist
jet86's Avatar
Drives: gt86
I got my 335 upgrade
Sent from my SM-N9005 using Tapatalk
jet86 is offline   Reply With Quote
Old 08-11-2014, 08:16 PM   #151
Dustin
Twin Screw You
Dustin's Avatar
Nice. I'm hoping they send some units over to the states some time soon. Sprintex USA still doesn't have an ETA on them.
Old 08-12-2014, 12:18 AM   #152
alexisfire02
Originally Posted by Dustin View Post
Nice. I'm hoping they send some units over to states some time soon. Sprintex USA still doesn't have an ETA on them.
Anyone try just buying the 335 blower from them? Or an authorized dealer selling the 335 for Minis? Use the 210 manifold and build the rest?
Old 08-12-2014, 12:23 AM   #153
Dustin
Twin Screw You
Dustin's Avatar
I called and asked. The guy I spoke with said the intake casting that bolts to the back of the blower is different. I could try to have something made but don't know how feasible it would be.
Old 08-12-2014, 12:27 AM   #154
alexisfire02
I've never seen a 210 but i the reason they decided to try the 335 is it fit.
Abbey Motorsport Sprintex SC updated Dyno plots Mark@Abbey m/s Forced Induction 49 02-15-2017 11:13 PM
Khorne's - AUDM Red 86 GTS Sprintex Khorne Member's Car Journals 53 08-31-2014 09:44 AM
Sprintex or Vortech, which setup has more potential? Turbowned Forced Induction 328 09-14-2013 11:09 AM
Abbey Motorpsort GT86 Sprintex installation Mark@Abbey m/s Forced Induction 18 09-07-2013 04:11 AM
Sprintex Supercharger Sneak Peak!!! invisage Forced Induction 52 03-03-2013 06:11 AM
