Old 10-29-2013, 06:48 AM   #1
keen as
keen as's Avatar
Drives: 86 GT MT
Sprintex Upgrade - announced on facebook - coming soon
From Sprintex Facebook
"Coming soon... Intercooled 335 Plus 86/FRS/BRZ Supercharger system. Available as a kit or an upgrade for existing 210 systems.
If you have a built engine and supporting systems this is the next step in building the ultimate ride."
keen as is offline   Reply With Quote
The Following 9 Users Say Thank You to keen as For This Useful Post:
B L U E S L A T E (10-31-2013), Calum (10-29-2013), diss7 (10-29-2013), EmeraldMalta (11-06-2013), Sonolin (11-05-2013), tech4pdx (10-30-2013), Turbowned (11-05-2013), whataboutbob (10-31-2013), xwd (11-01-2013)
Old 10-29-2013, 06:53 AM   #2
diss7
Drives: AE86, 2x GT86, TE27
I was wondering when they were going to announce this. I foresee a flood of cheap stage 1 kits for sale. Luckily I just sold mine, what a convenient coincidence.
diss7 is offline   Reply With Quote
Old 10-29-2013, 06:57 AM   #3
diss7
FYI now that it's announced. Bullet are developing this kit, and will be the sole distributor for it.
At least, that's what they told me a month ago.
They also said that for the cost of the upgrade, they advised it better to sell stage 1 kit, and buy stage 2 kit. Although, that was assuming that you could get your money back minus a few hundred for stage 1.
The Following User Says Thank You to diss7 For This Useful Post:
keen as (10-29-2013)
Old 10-29-2013, 07:18 AM   #4
vgi
Drives: frs
You mean for AU that is? For US it's at least going to another year know how fast Innovate moves.
Btw, having read your detailed explanation on why you sold the kit I assume you won't be getting this, right?
vgi is offline   Reply With Quote
Old 10-29-2013, 07:27 AM   #5
diss7
I won't be getting it. It's more a case of that I found out about this kit coming out, so realised that if was going to bail on my kit, it was best to do it straight away before this one was announced.
Old 10-29-2013, 08:09 AM   #6
ft_sjo
Drives: GT86
This upgraded kit isn't going to appeal to many people. The cost difference between bolting on the current offering (either stage 1, or stage '2' charge-cooled) and this upgrade is going to be massive - "if you have a built engine"..
We're talking $10k+ for this conversion.
Old 10-29-2013, 08:53 AM   #7
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Is it a completely different inter cooler and intake manifold?
industrial is offline   Reply With Quote
Old 10-29-2013, 09:00 AM   #8
ft_sjo
Drives: GT86
I don't know for sure. In a conversation I had with Sprintex months ago, they confirmed this larger unit shared the same bolt pattern and pulley position as the smaller unit. They confirmed that a different inlet elbow would be required to clear the chassis bracing, which the photo above now shows.
I don't know anything specific to this new offering, other than it's going to be expensive as a complete turnkey solution with an engine build! No doubt some people will try it out on a stock engine. Sprintex have some concerns over valve springs, even on the current kit.
Old 10-29-2013, 09:13 AM   #9
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Let's blow some more hot air into this engine
The Following User Says Thank You to SmsAlSuwaidi For This Useful Post:
King Tut (10-29-2013)
Old 10-29-2013, 11:22 AM   #10
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
At low RPM though bro.
Old 10-29-2013, 11:27 AM   #11
SmsAlSuwaidi
Boosted
About that life eh?
Old 10-29-2013, 11:29 AM   #12
sw20kosh
Drives: 2013 Black FR-S
There is no need to have an engine build to run a larger blower. Run a the appropriate amount of boost and timing for your particular fuel and you are set with a blower that flows more at a lower rpm and blows much less heat into the motor.
The bigger blower does not bolt to the current manifold
The Following User Says Thank You to sw20kosh For This Useful Post:
charged86 (12-12-2013)
Old 10-29-2013, 11:30 AM   #13
swift996
swift996's Avatar
It looks like it has to be a different intake manifold.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 10-29-2013, 11:51 AM   #14
tahoward
tahoward's Avatar
Drives: Firestorm FR-S
Could you spin this charger at a lower rate than the 210 and benefit from lower temps at the same boost level?
Not sure if it works that way and doubt many people would get a larger blower for those reasons.
Can't wait to see what this thing does on a prepped engine.
I do not see why the intake manifold has to be different; the outlet wedge should be the same size and the bolt pattern looks to be the same on both images.
tahoward is offline   Reply With Quote
Abbey Motorsport Sprintex SC updated Dyno plots Mark@Abbey m/s Forced Induction 49 02-15-2017 11:13 PM
Khorne's - AUDM Red 86 GTS Sprintex Khorne Member's Car Journals 53 08-31-2014 09:44 AM
Sprintex or Vortech, which setup has more potential? Turbowned Forced Induction 328 09-14-2013 11:09 AM
Abbey Motorpsort GT86 Sprintex installation Mark@Abbey m/s Forced Induction 18 09-07-2013 04:11 AM
Sprintex Supercharger Sneak Peak!!! invisage Forced Induction 52 03-03-2013 06:11 AM
