#99 | |
SLO NO MO
Anyway, I think we've thoroughly derailed the OP's original thread, and we keep going back to the warranty discussion that I thought we drove away from already ![]() Should probably create a new thread to discuss relocation of O2 sensor. |
#100 |
I love peanut butter
Drives: 2013 SWP BRZ Limited
It hasn't been my experience, I've never done this before. I'm just speculating like the rest of the people commenting in this thread. What have you experienced in Illinois and New York related to this topic?
I think our discussion is relevant to the OPs question. Last edited by B-R-Z; 08-10-2014 at 06:26 PM. |
#101 | |
SLO NO MO
On a previous car with exhaust modifications that included removal of the stock cat, no problems were encountered for at least two years. Suddenly, I was getting cylinder misfire codes and when the car was brought in, the dealer took one look at the aftermarket headers and the tampered emissions system and decided right then and there that there was nothing they could do under warranty. Even after installing the stock exhaust system, the misfire was still there. Could I have pursued this further with the manufacturer and argued the whole Magnuson Moss warranty act? Possibly - would it have been worth it? I don't know. Eventually had another (non dealer) mechanic look into it and the problem was with a bad ignition wire. Could that have been caused by tampering with the emissions system? I doubt it. |
#102 |
Go-Kart Enthusiast
Drives: Toyota Scion FRS
People who replace their headers and don't get a retune should review data logs. Review a log with a header/no tune to header/ w tune. Observe your AFR and tell me if you still think getting a header with no tune to support the change is a safe idea. IMO either you get a tune with your header or you don't get a header at all.
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels |
#103 | |
And with your issue that's your fault for accepting the dealers bail-out saying the exhaust was the cause. @Boofneenee give us some details I'm all ears |
#104 | |
SLO NO MO
I see this discussion going nowhere, so I wish you all the best, I'll be moving on now. |
#105 | |
We obviously have different opinions on it, so no bother in arguing any further. Last edited by B-R-Z; 08-10-2014 at 09:09 PM. |
#106 |
Opinions and facts are two different things......
You really need to do some research on this. Boofneenee is correct and there are data logs that prove it too. The stock tune also knocks like crazy and headers only make the issue worse with lean conditions but anyway, you are right. Keep up the good work.
#107 |
Re: Header info for a newbie
You're the expert, show and explain these logs to me.
And I'm not saying that a tune can't improve performance or correct things. My argument that you are SOL if a dealer discovers a tune and you are there trying to get a blown motor fixed. |
#108 |
I am hardly an expert, just ain't a complete noob that is all.
I'll leave your request to the real experts as I simply do not have a high enough tolerance to do so.
#109 |
Go-Kart Enthusiast
A catless header without a tune is not healthy for the engine. You are realling leaning things out which increases temperatures and increases chances of knock. You can get one and avoid tuning because you want to avoid voiding your warranty or you can do what is healthy for the engine. Not to mention your car will run like shit without a tune and headers. Your choice.
BRZ their are plenty logs out there for you to review if you want to educate yourself. The best approach is to compare a solid, quality tune to one with no tune and only headers. Compare the afr's and other variables.
FRS
#110 |
Go-Kart Enthusiast
And stop with the " a tune has the potential of being much more dangerous" crap. Let's assume for the sake of this annoying argument the op would be getting a quality tune from a reputable company.
FRS
#111 | ||
I know, I know, I am dumb and my motor will run terrible without a tune. Last edited by B-R-Z; 08-11-2014 at 06:43 PM. |
#112 | |
Drives: '13 BRZ Ltd
| Newbie! | randomthoughts | CANADA | 2 | 07-14-2014 01:41 PM |
| header newbie | anthonyravenfrs | Engine, Exhaust, Transmission | 24 | 01-24-2014 10:54 AM |
| please help a newbie :) | abling2 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 05-17-2013 10:59 AM |
| Header/Cat delete - first mod - info me | MindtheGap | Engine, Exhaust, Transmission | 45 | 06-03-2012 07:32 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) — General Topics | 0 | 05-24-2012 10:09 PM |
