Drives: toyota gt86 firestorm red
please help a newbie :)
Im planning to buy work emotions cr kai 18x9.5 +38 offset w/ 255/35/18 tires on them. what lowering springs would be the best for me without having to roll my fenders or not having a rubbing issues on any fenders, and not have to adjust my camber please let me know. and by the way how are the tpms sensor gonna work now if I buy/install these sets of wheels? do i have to get customize sensor? or what? thanks
Avelino |
Drives: 2013 Scion FR-S (manual)
buy the wheels first if you are sure the offset is what you want. Then figure out how low you want to go. Some will let you go insanely low but will limit the amount of travel you have. Others, like the RSR Blacki, and Buddy Club, will let you get pretty low and still have the full suspension range. These can range from 1300 up to 2300. Good luck.
Customize the piss out of it and call it yours!
Drives: RB v1 FRS
you won't get rubbing from lowering springs because they won't lower you very much I would think.
You might if you lower your car a lot with coilovers. I'v maxed out my FA coilovers in the rear and have gone lower in the front and still no rubbing whatsoever, however the tires you want are wider than my setup. also, my opinion is that lowering springs is a waste of money. spring for coilovers (pun intended) |
AutoX-10/10ths every run
RaceCompEngineering springs with Whiteline camber bolts will work nice with those wheels.
Drives: Black BRZ
so 18x9.5 +38 wont rub, on slight spring drop. i think i read that +38 will clear the spring and strut. but does it poke up front?
| Newbie set-up for Sebring, Help! | maj75 | Tracking / Autocross / HPDE / Drifting | 40 | 04-16-2013 10:44 AM |
| FR-S newbie to Mod needs advices!! | newkid185 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 08-09-2012 06:39 AM |
| question about frs for a newbie | enjoi23 | Scion FR-S / Toyota 86 GT86 General Forum | 18 | 08-04-2012 05:42 PM |
| Newbie | KiRiMa | Scion FR-S / Toyota 86 GT86 General Forum | 10 | 01-07-2010 05:39 AM |
