Drives: 2013 Asphalt FR-S
Header info for a newbie
So I'm interested in getting an aftermarket header for my frs but I have a few questions.
My first concern is that when I look up headers for my frs they say that they are for off-road use only. Why is this? Will I risk the chance of getting pulled over and ticketed because of an aftermarket header? Also, are there any concerns with the reliability of aftermarket headers? Will I have to worry about anything breaking down? I'd ultimately like to get a header and an open flash tablet to increase my horsepower. Are there any other problems that could come with installing an aftermarket header? Thanks! |
SLO NO MO
The primary catalytic converter for our car is in the header. Federal regulations prevent any alterations to the factory emissions control system, of which the catalytic converter is a part of.
To that end, any aftermarket header can only be sold for off-road use. Will you get pulled over for it? Probably not. Will you fail a state emissions inspection? Possible. Depends on your state and testing facility, as well as luck of the draw sometimes. Reliability - it's not a moving part, so the worst that could happen is you have an exhaust leak somewhere. Either an ill-fitting flange, or a crack in a weld, for example. Won't stop your car from operating, but could lead to additional noise, as well as exhaust/heat escaping from a part of your exhaust system it's not supposed to. |
#3 | |
Drives: 2014 Subaru BRZ Limited 6smt
I believe it says "for off road use only" for headers that are catless, therefor making your vehicle unable to pass an emissions test. The car comes stock with two and altering it down to one effects the final product coming out the exhaust tips. It is most likely there because the item was designed for track use and the company does not want to get sued. This is my theory anyways, hopefully someone can back me up. There should be no reliability issues with an aftermarket header if you buy from a reputable brand. I would strongly recommend digging through the forum for user reviews and dynos. If longevity is a concern of yours, you can a ceramic coating for the header. I will be in the same market as you shortly. Headers and OFT once I move to my new house and rent goes down substantially. Have you considered the OFT and the OFH together? I am consider the OFH, the JDL, or the Nameless. Havent made up my mind yet
Yeah that's exactly what I'm considering. I think an increase of roughly 20hp is pretty decent for around $1000. I just don't want to do it if it were to cause problems down the road. I also don't like noises that aren't supposed to be there. I'm rather OCD about random noises...
#6 | ||
Drives: 2013 BRZ Limited WRB
#7 | |
Your exhaust will sounds bit louder I would imagine. Are you planning on any other exhaust mods? |
SLO NO MO
Drives: '18 STi
Chances of you getting pulled over with a catless system is extremely unlikely unless you're driving like an asshole and your car sounds like a Harley. Generally speaking, you won't get pulled over.
Again like a member said above, companies use the "for - off road use" because it's federally illegal to sell exhaust components without cats for the street. Plus companies can get sued if they forget to put the "for off road use only" if they're selling an aftermarket exhaust component. Yes, get the OFT + your header of choice (anything but Borla and cheap brands). You'll love it! |
#10 |
#11 |
Drives: n/a
As far as emissions go for catless headers, if all they do for emissions testing is plug into your OBDII port and pull data will they be able to tell you've changed out the header? Anyone live in an emission-testing zone and having issues? My county doesn't do emissions testing, but it's always possible that I'll move to a county that does. I know some vehicles require an O2 sensor replacement to "trick" the ECU so you don't throw any codes with a catless header, but haven't seen anything about this for the BRZ.
#12 |
I am also interested in what happens once I need to get an emmissions test. Is there an easy way to pass it with an ofh is installed?
#13 |
I love peanut butter
Drives: 2013 SWP BRZ Limited
You can place the o2 sensors around the secondary cat when the primary cat is removed with the stock header. From what I've been told this is enough to make the ecu think the primary cat is still there.
So you will need an o2 sensor bung with cap and an o2 extension wire. You have the bung welded into your front pipe after the secondary cat and place your after-cat sensor there. Your before cat sensor goes where you would normally put the after cat sensor. You plug up where you would normally put the before cat sensor. I installed my catless uel header this past weekend and have yet to throw a cel. I will be doing this sensor relocation this weekend. |
#14 | |
Drives: Slow...
| Newbie! | randomthoughts | CANADA | 2 | 07-14-2014 01:41 PM |
| header newbie | anthonyravenfrs | Engine, Exhaust, Transmission | 24 | 01-24-2014 10:54 AM |
| please help a newbie :) | abling2 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 05-17-2013 10:59 AM |
| Header/Cat delete - first mod - info me | MindtheGap | Engine, Exhaust, Transmission | 45 | 06-03-2012 07:32 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) — General Topics | 0 | 05-24-2012 10:09 PM |
