Old 08-09-2014, 08:19 PM   #5153
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Originally Posted by sickmint79 View Post
how much heat are we talking about? can it be reduced other ways (vented hood?) i just checked and the tracks i go to don't have e85 very close and i'm not a big fan of having to store/bring gas or live my life around which gas stations i'm allowed to go to.
Not terribly more than roots, expect intake temps approaching 70+c with a 70mm pulley on a road course. That in itself doesn't cost hp, but the amount of timing retard you need to sustain a high compression block slows things down big time.
With e85 you don't need to retard much timing (hardly at all) for high IATs, so for that reason it works well in the track.
Vented hood and other things won't help much here. In the early days miata folks even tried water jackets...didn't help enough to warrant it.
Doesn't mean you can't run it. It will still make more torque down low and 200+ hp up top, but it won't be the 220-240 you'd see on the dyno.
Xero-Limit is offline   Reply With Quote
The Following User Says Thank You to Xero-Limit For This Useful Post:
DeliciousTuning (08-10-2014)
Old 08-09-2014, 08:23 PM   #5154
MINOCIN
MINOCIN's Avatar
Drives: Asphalt 2013 FR-S
Originally Posted by CK_Bladesmith View Post
Don't forget about that awesome twin screw whine!
This! I love the whine from this kit
Makes getting on the freeway so much more fun.
I also won't disagree with anyone who says that there are better options out there for the track or big hp numbers. I would say that this kit feels most at home on the freeway. Rarely do I ever have to downshift to 5th anymore to pass anyone. I actually enjoyed downshifting before when I was stock, but it only helped a little bit at freeway speeds.
I would say this kit definitely makes daily driving more effortless (less involved maybe?). It'll make you lazy in that you don't have to shift gears as much on the freeway, just keep it in 6th. Some may like that, some might not. I'm still not sure how I feel about it, but I do know that I love having the ability to easily pass now when I want to.
GFR - aka my build thread
"They don't think it be like it is, but it do." -Oscar Gamble
MINOCIN is offline   Reply With Quote
Old 08-09-2014, 08:27 PM   #5155
alexisfire02
Drives: 2013 Pearl White FRS
Originally Posted by sam69 View Post
Do you have a build thread for your car and the 335 alexisfire ?
No
alexisfire02 is offline   Reply With Quote
Old 08-10-2014, 11:17 AM   #5156
TONYpepperon1
TONYpepperon1's Avatar
Drives: 2013 CBS BRZ
Originally Posted by moto-mike View Post
Otherwise it is a fully reliable setup, and you have to use it for what it is--a great street setup with a moderate increase. If you do track time you'll want the oil cooler and radiator. But you won't do too much track time on the stock kit on pump gas. Too much heat builds up lap after lap.
I guess the question I have here is, is it worth the money. It only looks like a 40 hp gain but it will cost around 5 grand for it. Im genuinely curious on your opinion because I don't know how much a 40 hp gain feels like. Will the car feel significantly faster? Are any potential issues (engine bombing, parts breaking) worth that gain? I'm just trying to get some insight to help justify it.
TONYpepperon1 is offline   Reply With Quote
Old 08-10-2014, 01:33 PM   #5157
sato
sato's Avatar
Drives: Dodge Patitas
Remember, it's not only the hp increase that is most noticeable, but rather the torque gains across the RPM band (especially in the torque dip region).
sato is offline   Reply With Quote
The Following User Says Thank You to sato For This Useful Post:
Ubersuber (08-10-2014)
Old 08-10-2014, 03:15 PM   #5158
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
Only 40hp? remember we are talking WHP. on the 75mm pulley on 93oct i went from 160whp to 230whp.
230rwhp/184ftlb on 98RON/93AKI
Build thread
Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can
Khorne is offline   Reply With Quote
The Following 3 Users Say Thank You to Khorne For This Useful Post:
CK_Bladesmith (08-10-2014), TONYpepperon1 (08-10-2014), Xero-Limit (08-10-2014)
Old 08-10-2014, 05:21 PM   #5159
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
A 10% power boost is easily noticeable and feels good. 40% from down low is a huge deal in everyday driving. If that's worth it is up to you.
Old 08-10-2014, 08:09 PM   #5160
sickmint79
Drives: bmw
what is advised for track? the twin screw sounded appealing to me but open to other options and advise.
sickmint79 is offline   Reply With Quote
Old 08-10-2014, 10:31 PM   #5161
MINOCIN
MINOCIN's Avatar
I'm sure there are more informed and experienced members in this forum that could better answer that question, but I'll give it a shot anyway. To the best of my knowledge some drawbacks of the twin screw are higher discharge temperatures, low peak power and you will be stranded if your belt breaks. The Rotrex centrifugal type kits I believe are said to have lower discharge temps and provide more power after about 5,000 rpm. The centrifugal type kits can provide more boost up high, which is where you typically should be when racing.
You should probably check out and perhaps try to revive the comparison thread:
http://www.ft86club.com/forums/showthread.php?t=55705
That being said, the Innovate kit is still a lot fun at the track. I'm definitely using it as a crutch right now though. It, along with many other mods, immediately took 2 seconds off my avg lap time at Streets of Willow (SoW) ccw. After I got comfortable with the car I was able to shave off another 1.5 seconds. I know I said this kit is probably best suited for the freeway, but it's still a lot more fun than stock while at the track.
The biggest difference it made for me personally at SoW was that I didn't have to downshift to 2nd anymore. SoW can be pretty difficult when stock if you're a bad driver like me, and a common problem that you might run into is that 2nd gear is not long enough and 3rd gear is not powerful enough. To get anywhere in the stock car you really gotta work for it.
A stock 86 will force you to become a better driver, but if you suck like me and/or are an impatient/slow learner then the extra 40-50 hp from the twin screw will help mask your mistakes. Sure, you wont be diligently honing your driving skills but that's not to say that you wont continue to learn and improve regardless.
I only do about 4-6 track events a year; so while I knew that I wanted to continue to go to the track, it wasn't my biggest priority when choosing a super charger.
The Following User Says Thank You to MINOCIN For This Useful Post:
rs999 (08-11-2014)
Old 08-10-2014, 11:39 PM   #5162
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
I've got a good question for you guys. Has anyone that's intercooled taken off their blower and checked the laminova core?
Any oil buildup baked into the veins of the laminova?
If not what catch can solution are you using and is it catching much oil vapors/mist/blowby??
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 08-11-2014, 07:19 AM   #5163
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
I'm almost positive mine is coated due to what I saw going from stage 1 to 2 - just installed the ADD W1 can, hopefully she catches something!
mikalem is offline   Reply With Quote
Old 08-11-2014, 07:36 AM   #5164
s2d4
s2d4's Avatar
Definitely not! Without turning this into a one kit vs the other thread, I'd much prefer a twin screw over an esc by far. Much more to a whole system then just numbers on a single dyno pull. Efficiency, durability, and power delivery are a big factor here.
I get the delivery part as a preference.
Can you shed some light as to the durability and efficiency points?
Old 08-11-2014, 12:27 PM   #5165
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
Is anyone's fuel trims going crazy with the new tune? I get values in the teens and twentys on both short and long term during normal driving. Wot is 0.00.
2013 BR-Zed, Innovate Powered, Delicious Tuned, Zeltus Cooled. Build Thread
www.GT86Mounts.com
calispec is offline   Reply With Quote
Old 08-11-2014, 04:40 PM   #5166
Calum
That Guy
Drives: 2013 asphalt FRS MT
Make sure ecutek is updated and try again. After you have the tune install and the car running, don't touch anything. Just let the car sit and idle for a few minutes.
If you still get the wonky fuel trims get in touch with your tuner, I'm assuming it's Bill.
The Following User Says Thank You to Calum For This Useful Post:
calispec (08-11-2014)
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
