#155 | |
Drives: 2020 BRZ PP
| The Following User Says Thank You to Griever423 For This Useful Post: | CSG Mike (08-06-2014) |
#156 | |
#157 | |
#158 |
Drives: 2016 FR-S
While people have different definitions, I like the definitions that says a momentum car has more grip than power and thus requires a line through that maximizes corner speed, while a car that has more power than grip will gives up some corner speed to make the corner a bit sharper, and get on the power ASAP.
So, a momentum car has to optimize its grip, while a non-momentum car has to optimize its power.
| The Following User Says Thank You to Sleepless For This Useful Post: | Kronos (08-06-2014) |
#159 | |
Drives: Asphalt FR-S MT
Took the words right out of my mouth. You just beat me to the post 👍 |
#160 |
Drives: 2012 Toyota 86
Thats a lesson ive learned and seems to work for me at least. I spent so much time playing gran turismo with high hp cars that when i went to the track in real life i found my self taking turns sharper so i could have a straiter exit so i could lay on the throttle but after getting passed in turns by toyota vitzs i started taking a more sweeping line and even though i had to roll onto power more slowly, i dropped as much as 1 second on some sections.
#161 | |
A high horsepower car that slows to 65 mph for a turn is somehow faster than the same high HP car that takes the turn at 70 mph. That never computes. Anyone who uses that definition is probably using it as a crutch. You described the "easy" line (or the novice line). That line uses a traction "oval" rather than the full traction circle. It's hard to use all the available grip, even harder when there is a lot of power on tap. Here's a riddle. How long does it take a Corvette to accelerate from 65 mph to 70 mph? How much distance is covered? How long does it take the same Corvette to accelerate from 70 mph to 70 mph? How much distance is covered? Which Corvette got to 70 mph faster, and in the shortest possible distance? On a slower, tighter turn (take turns 1-2 at VIR as an example) the "HP" line would have me brake deeper in a straight line, and take a later apex, then I get to romp on the throttle, and in doing so, I stay 15-20 feet from proper track out. The "momentum" line has me trailbraking to the apex, then rolling onto the throttle at apex and being mostly full throttle at track out (and it's a nice drop off into the clay if you overshoot). In both cases I've started to apply throttle at the apex. In case #1 I am going slower when I get on the throttle, and I have to cover more ground at the slowest speed. in case #2 I'm already moving faster, I'm still applying throttle (at the same time) and I don't need to travel as far at my minimum velocity. Sounds like a win to me! If you get out of HPDE and into racing, the HP line will also result in you getting passed on the inside. Every. Single. Time. |
| The Following 6 Users Say Thank You to celica73 For This Useful Post: | CSG Mike (08-07-2014), DAEMANO (08-07-2014), DarkSunrise (08-07-2014), ddeflyer (08-07-2014), Kronos (08-07-2014), WillRacer1jz (08-11-2014) |
#162 |
How fast is the GT86 on track?
Let see if I can clear up this misunderstanding in different trains of thought. I definitely see where you are coming from and your points ares valid. Obviously you want to take a high horsepower car or any car around the corner with the most momentum possible.
People like to refer to the GT 86 as a momentum car because subjectively speaking it's chassis could easily handle more power. The chassis is better than the tires and engine that it comes with . Therefore you need to use the chassis as the cars crutch as it's not going to be blasting out of corners. The chassis of this car is it's defining feature. Not the engine and not anything else really. And the term "momentum car" is simply referring to that. That's how I look at it at least But I do agree, if you want to be fast on the track, every car should be a momentum car |
#163 |
All of the points above are valid. You have to balance momentum line with power line, based on the amount of grip and power a given car has.
The question is, are you going for a lap time or racing? If you're racing, are you using a fast lap line to catch up to the person ahead of you or run away from the one behind you, or are you taking a defensive line to prevent a pass? That'll affect line as well. |
#164 | |
Drives: 2016 FR-S
I believe is was agreeing that there is a difference between HP and momentum cars. So, agreed, he "gets it".
The fast way through the corner in a high HP car is to give up a bit at mid corner (still using the full friction circle) in order to tighten the corner to shorten it and get to full power sooner. Effectively, the apex is later than on with a momentum car. It works. I have a Palatov D2 which has 430HP and weighs 1900lbs so it is a great example of an HP car compared to the BRZ. I tried many lines in that car and compared to the BRZ, a later apex is faster. True, but then a defensive line is neither of the two lines I described since both keep you to the outside of the turn at corner entry. If there isn't anyone in the mirrors or are qualifying, then a defensive line is not the fastest, regardless of the type of car.
#165 | |
Some good reading on this subject from a professional race car driver:
2022 BRZ Build 2013 FR-S Build |
#166 |
Drives: Hydra EMS Powered FRS Raven Black
I think this illustrates how capable the FRS/BRZ chassis really is. I had this car no more than a couple days and this is the first time I ever had it on track. This is a Time Attack race and all cars are prepped track cars on slicks, suspensions, plus race brakes, and well my FRS is totally stock except I tossed on my STi race wheels and tires (very heavy).
[ame="https://www.youtube.com/watch?v=ZxAkNUQ24Pk"]Element Tuning FRS/BRZ Whelen USTT 2012 NJ - YouTube[/ame] I would say the chassis is more capable than most drivers are able to extract. With mods the car actually becomes easier to drive. Even on stock with just tires I was able to carry more corner speed than the type of track prepped cars the OP mentions. This type of track is the FRS/BRZs home turf! Tracks with tight turns before a long straight will put a frown on your face however. LOL! Thanks, Phil Grabow |
#167 | |
Drives: 2022 BRZ Limited
| The Following User Says Thank You to glamcem For This Useful Post: | Element Tuning (08-08-2014) |
#168 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Element Tuning (08-08-2014) |
| FS: go fast track tires for your FR-S! | l8apexr | Canada Classifieds | 2 | 10-02-2013 06:28 AM |
| Track Day @ Mid America Motorplex - Fast Fridays | enigma | Rocky Mountains / Great Plains | 1 | 08-24-2013 12:00 AM |
| BRZ in Born To Race Fast Track Trailer | switchlanez | BRZ First-Gen (2012+) — General Topics | 34 | 06-28-2013 07:21 PM |
| A FR-S with star spec is about as fast as a (fill in the blank)_____ at the track? | stealth1 | Tracking / Autocross / HPDE / Drifting | 15 | 10-18-2012 05:46 PM |
| Aug Fast Track out. | feldy | Tracking / Autocross / HPDE / Drifting | 27 | 09-12-2012 09:03 AM |
