Old 10-12-2012, 10:14 PM   #1
stealth1
Drives: f150
A FR-S with star spec is about as fast as a (fill in the blank)_____ at the track?
I've been reading up on this car and everyone has good things to say. But I want to know how fast a stock FR-S is with good tires compared to other stock cars with comparable tires? Whats a comparable car? Are the laptimes comparable to a miata? An S2000? A WRX? etc... Is it one of the slowest cars around the track or does it do decent compared to the average trackday cars? Does it get any respect at the track or would I be the guy getting in everyones way?
stealth1 is offline   Reply With Quote
Old 10-12-2012, 10:28 PM   #2
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
Sccabrz192 is offline   Reply With Quote
Old 10-12-2012, 10:41 PM   #3
enigma
Drives: Asphalt 86
I've never felt like track days were about "respect," myself. If you're out there giving it the good old college try and are listening to instructor's feedback and working to improve, it doesn't really matter what you're driving imho.
As far as getting in the way... if you learn to drive the thing, I highly doubt you'll be anyone's pylon.
enigma is offline   Reply With Quote
Old 10-12-2012, 11:12 PM   #4
CSG David
CSG David's Avatar
FRS/BRZ is quite a capable car even with just EHP tires and track brake pads/fluid. You can refer to the videos we posted at www.youtube.com/counterspacegarage
Old 10-13-2012, 08:11 AM   #5
bugeye_fever
Drives: 02 WRX, 09 Mini Cooper, BRZ pending
OP, whats your skill level? Have you been to a track day before? If you go to a track day and pay attention to the rules, listen to your instructor, and pay attention to the other cars when your out on track, you'll get respect regardless of the car your driving.
bugeye_fever is offline   Reply With Quote
Old 10-13-2012, 10:57 PM   #6
stealth1
Drives: f150
All my car racing has been in the dirt, baja 500 baja 1000 etc. Never been to a trackday but I am thinking about buying this car and occasionally doing a track day for fun. Since I ve never been to a track day and know very little about trackdays, I thought it would be good to ask what level this car is at before I go out and buy one and find out it's not what I expected.
Old 10-13-2012, 11:15 PM   #7
stealth1
Drives: f150
Thanks for the videos and and feedback, maybe I used the wrong wording. Instead of saying, does this car get any respect, I should have said, does this car do miata laptimes or better? I've been reading this forum and all the posts are positive, at this point from what I've read, I think this is the perfect car for me. I just want to make sure that I'm not expecting too much. If the laptimes are somewhere between a miata and s2000 I'll be happy.
Old 10-15-2012, 12:20 PM   #8
Mark Slide Squad
Mark Slide Squad's Avatar
Drives: 2013 Whiteout FR-S 6MT, S14 Kouki
To simply answer your question, I did a track day several weeks ago in a bone stock FR-S and I was keeping up with a modified S2000, and I was faster than a Miata. But as previously mentioned, the driver is a factor in the car too. The track is a big factor as well. If it's a high speed track, the S2000 will have a slight advantage with it's power. On a tight, slow course, the lightweight and short wheelbase Miata will probably have the upper hand. I recently picked up some 17x9 +35 Enkei RPF1's and I plan on putting some Dunlop Direzza Star Specs on it and expect to knock at least 4 seconds off my lap time, which would be lapping faster than the modified S2000 that I ran against. Driver's actual results may vary The stock tires don't hold up on the track that well at all if you are driving all out. All four tires were chunking. If you want to track your car, I highly suggest better tires, track brake pads, and some "crash bolts" that will give you some more negative camber in front so that the sidewall of the tire doesn't roll so much and get destroyed, and it will improve turn-in and reduce understeer.
Mark Slide Squad is offline   Reply With Quote
Old 10-15-2012, 02:31 PM   #9
SOneThreeCoupe
Drives: 1992 Nissan 240SX
From what I've read and what Emilio @ 949 Racing and momofoolio on TrackHQ have said, the FR-S can run with S2000s in the corners.
That said, I would recommend crash bolts before you go out on track; the stock camber settings will destroy your tread shoulders.
Edit: Mark beat me to it, but might as well reiterate.
PS- If you're planning on driving Horsethief or Streets of Willow, PM me and I can give you some pointers on line as well as links to some of my videos.
SOneThreeCoupe is offline   Reply With Quote
Old 10-15-2012, 03:51 PM   #10
No car quite has the specs of a FRS, but it slots in right between the (NC) miata and s2k.
Old 10-15-2012, 04:43 PM   #11
icemang17
Drives: Scion FR-S/ Subaru BRZ
this is a highly subjective ?? since the driver accounts for about 98% of a cars performance on a road course..... I am a novice racer and my conservative lap times at my home track put me near the back of the pack in a spec miata race.....but thats bone stock with the crap tires.....I think on Star Specs I could put down a decent mid pack spec miata time.....
My best lap at Thunderhill is a 2:18 over the top.....Spec miatas can turn 2:08, but those are the very best cars and drivers.... I think I could get my FRS into the low 2:10 range pretty easy on better tires....
icemang17 is offline   Reply With Quote
Old 10-15-2012, 04:56 PM   #12
celica73
Drives: '13 BRZ / '11 Outback / '06 Tundra
I'd say on a shorter/tighter track it is about as fast as a similarly equipped Miata. On a track with longer straights, the BRZ's aero advantage should make a difference.
The BRZ isn't a fast car on the race track, I've had mine there and while it was brilliant in the corners, it felt like I could have gotten out and run faster on the straights.
The consumables are pretty cheap, and if it turns out to be reliable then it will be a great track car.
celica73 is offline   Reply With Quote
Old 10-15-2012, 05:20 PM   #13
Here's my feedback; I drive the CSG BRZ, and own a s2k as my personal car. I also have a lot of miata friends, and have a decent amount of seat time in miatas of various levels of prep.
First off, a few assumptions:
- For the sake of discussin in this specific post, we are assuming that all cars have drivers of equal skill.
- A spec miata is slightly slower than a S2k on square street (255 RS3) tires, roughly 2-4 seconds depending on track. No other mods on the S2k.
- The NC is the fastest "stock" miata. The NC is generally 2-6 seconds slower than a spec miata on square street tires (255 RS3)
Now, contrary to popular belief, my testing with the BRZ has shown that the BRZ actually excels in the mid to high speed tracks. The BRZ's aerodynamics really shine, allowing the car to pick up faster than it's 200hp would convey, and the car is exceptionally stable at speed.
I actually believe the BRZ's biggest weakness (on stock suspension) is low speed, tight tracks. With the combination of understeer (suspension tuning from the factory), inability to force rotation with the rear (when driven at the limit of tire grip), and relatively low power, the BRZ struggles with tracks where the majority of turns are under 60 mph. You have to just manage the understeer and carefully decide if you want to power out of a turn or minimize distance traveled, or maximize entry speed.
The FR-S, is a bit more neutral handling, but still understeers at the limit of grip. However, unlike the BRZ, you can readily upset the balance of the car, and put the FRS into oversteer mode, whereas sudden/rough input or trail braking, or clutch kicks won't do anything to the BRZ's understeer unless you upset the car so much that you're going WAY slower than you should.
Here are my relative rankings; FRS is not included as I don't have enough seat time to accurately gauge the car. Remember, this is strictly my opinion:
Stock S2k vs stock BRZ vs Stock NC Miata (stock everything, including tires)
High speed track: S2k >>>> BRZ >>>> Miata
Low speed track: S2k >>>>>> BRZ >> Miata
Modded: (intake, exhaust, ECU tune, cheap coilovers, wheels, street tires)
High speed track: S2k >> BRZ >>>> Miata
Low speed track: S2k > BRZ >>> Miata
Track modded (speculation on the BRZ): (full bolt-ons, r-comps, good coilovers, splitter, wing)
High speed track: BRZ > S2k >>>> Miata
Low speed track: S2k = BRZ >> Miata
Unlimited budget builds (100% speculation on my part):
High speed track: BRZ >>>> S2k >>>> Miata
Old 10-15-2012, 11:50 PM   #14
stealth1
Drives: f150
Now thats what I was looking for. Someone who has actually tracked the car giving an honest opinion about how the car does compared to other similar cars. Great info, exactly what I was looking for. Thanks, keep the posts going, I really appreciate everyone taking the time to respond. I'm learning alot.
Dunlop Star Spec anyone do yet ? rikdrt1 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 34 03-15-2013 07:29 AM
Algebra: BRZ + 555 = _____ Draco-REX BRZ First-Gen (2012+) — General Topics 7 10-09-2012 11:59 AM
Yokohama ADVAN Neova AD08 vs. DUNLOP DIREZZA Star Spec z1 gmookher Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 09-13-2012 10:18 AM
Aug Fast Track out. feldy Tracking / Autocross / HPDE / Drifting 27 09-12-2012 09:03 AM
