Old 08-08-2014, 12:28 AM   #43
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Originally Posted by Target70 View Post
no hate, just curiosity. noise doesn't really register on my radar, so I honestly couldn't figure why you would get a header.
Because rumbles register on my radar.
B-R-Z is offline   Reply With Quote
The Following User Says Thank You to B-R-Z For This Useful Post:
DriftinFRS (08-09-2014)
Old 08-08-2014, 12:51 AM   #44
steve99
Drives: FT86
Originally Posted by B-R-Z View Post
No tune and no plans to at least until warranty is expired... it just isn't with it to me to spend $500+ on 10hp. The cel can be fixed other ways, and hopefully this ecu correction that I read about on the forums Idk how legit it is
If you concerned about effecting you warantee then don't get headers or mess with the cats or o2 sensor positions. The dealer will spot that in about 10 seconds, and as soon as you do any of that your putting your engine warante at risk.
Old 08-08-2014, 02:35 PM   #45
B-R-Z
B-R-Z's Avatar
To an extent yes. I think they can more easily deny claims and deny many more things if the ECU is flashed versus just replacing the header.
Old 08-08-2014, 05:26 PM   #46
steve99
Drives: FT86
with a flash
A. they have got to find it, unlikely unless the pull your ROM and Analise the actual hex code they wont know, as the calid in techstream will be the same as a stock calid for a tuned ROM.
B. If you have the ability to flash back to 100% stock ROM then their is sod all chance of them finding anything and even if they find the mythical flash counter (which I have yet to find in techstream) then all they have is a stock ROM and no proof anything else was in there.
Unlike hardware mods which are in plain sight and difficult/time consuming to swap out for service.
Old 08-08-2014, 07:23 PM   #47
B-R-Z
B-R-Z's Avatar
I already own the header and not spending $500+ on a tune. I'll be using a catalytic converter of some sort to get it right.
Old 08-08-2014, 08:00 PM   #48
Akari
Drives: 2013 DGM BRZ
I've used the anti-fouler trick a few times before on different vehicles with much success. $3 fixes are my favorite.
Having a bung welded after your second cat, extending the wiring and hoping it works seems much, much more difficult/expensive.
Akari is offline   Reply With Quote
Old 08-08-2014, 08:02 PM   #49
B-R-Z
B-R-Z's Avatar
See post #28 and #30
Old 08-08-2014, 08:04 PM   #50
Akari
See post #28
Like I said, this seems like the much more difficult and expensive route. I could have this fixed in <5 minutes with a $3 part.
Old 08-08-2014, 08:09 PM   #51
B-R-Z
B-R-Z's Avatar
But is your fix messing up your a/f ratio being it's not a true cat?
Old 08-08-2014, 08:13 PM   #52
Akari
No? Only the first O2 sensor is used for that making these adjustments. Taking readings from the second O2 sensor after a cat to try to adjust A/F doesn't even make sense.
The second O2 sensor is literally only there to ensure your cat is working, this reading is not used for any engine management purposes.
Old 08-08-2014, 08:29 PM   #53
B-R-Z
B-R-Z's Avatar
Now that I think about it, that makes sense. Thx bud
Though, I already bought the bung and o2 sensor extension cable. So as long as the welding the bung is cheap that will be my cheapest route at this point.
Old 08-08-2014, 08:39 PM   #54
Akari
Let us know how that goes, I'm curious if the secondary cat is enough(I'm thinking the primary may work better as it's operating at a better temperature). You may also run into the problem that you can't get the second O2 sensor hot enough in that section of pipe but it's worth a shot.
As far as getting a bung welded in it's usually $10-20 depending on if on the car or not.
Old 08-08-2014, 09:19 PM   #55
B-R-Z
B-R-Z's Avatar
Another member has done this with success for 5k+ miles
Old 08-08-2014, 09:25 PM   #56
s2d4
s2d4's Avatar
Lol finally....
Btw, there will be a delay since you are placing it further back. Just because some moron done it for 5K miles doesn't mean he knows what he is doing.
Newbie! randomthoughts CANADA 2 07-14-2014 02:41 PM
header newbie anthonyravenfrs Engine, Exhaust, Transmission 24 01-24-2014 11:54 AM
please help a newbie :) abling2 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 05-17-2013 11:59 AM
Header/Cat delete - first mod - info me MindtheGap Engine, Exhaust, Transmission 45 06-03-2012 08:32 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
