Old 08-05-2014, 11:28 AM   #337
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Dammit - sorry guys, that was me, missed an extra space in the table name when I pulled the definition together.
All you need to do is change "Transient Ignition Retard" to "Transient Ignition Retard " - the correct table definition is already in the 32bitbase section.
Td-d is offline   Reply With Quote
The Following 4 Users Say Thank You to Td-d For This Useful Post:
s2d4 (08-05-2014), Shiv@Openflash (08-05-2014), steve99 (08-05-2014), vynervt (08-05-2014)
Old 08-05-2014, 11:40 AM   #338
Td-d
I've just checked - the cranking fuel and misfire tables are also errors. That's what happens when you try and push these defs out late into the night!
I'll fix, and re-upload to github so Shiv can redistribute.
The Following 2 Users Say Thank You to Td-d For This Useful Post:
Old 08-05-2014, 11:48 AM   #339
Td-d
Alright, done - corrected definition up on Github. I'm sure Shiv will update and repost on the OFT site asap.
The Following User Says Thank You to Td-d For This Useful Post:
Old 08-05-2014, 12:19 PM   #340
vynervt
Drives: GT-86
@Td-d, Thank you for the contribution.
vynervt is offline   Reply With Quote
Old 08-05-2014, 12:36 PM   #341
Roarke
Drives: Subaru Brz 2014
Any news when it will support EU cars? @Shiv@Openflash , thank you for any info
Roarke is offline   Reply With Quote
Old 08-05-2014, 02:31 PM   #342
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Thanks mate. As always, your contributions are appreciated. The error in D00C definition file should have only had an effect on the cranking enrichment values.
New v2.03 maps are now available HERE
8/05/14
v2.03b
-Revised ZA1D00C XML that fixes minor definition errors.
-Revised Stage 2 E85 UEL D00C and Stage 2 E85 EL D00C files with corrected cranking enrichment values
Cheers,
Shiv
Shiv@Openflash is offline   Reply With Quote
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
vynervt (08-06-2014)
Old 08-07-2014, 03:13 PM   #343
Migero86
Migero86's Avatar
Drives: 2015 Trailhawk
Question.... I saw a post earlier about a noise in the 4000 rpm -> 5000 rpm range using this new tune.
I also PM'd @Shiv@Openflash about it since I am experiencing the same thing from my car.
It was stated that this could be harmonic resonance from the intake. My curious and cautious side needs to ask... How would it be explained that this tune causes the noise to appear while the previous tune does not?
What has changed since 1.59 that would cause this exact occurrence... I think I am going to go back to 1.59, my car was silent on the 1.59 tune, however on this tune, it sounds like a can of marbles being shaken in that rev range under acceleration.
Migero86 is offline   Reply With Quote
Old 08-07-2014, 04:13 PM   #344
steve99
Drives: FT86
The cam timing has been changed the noise should be reduced in V2xx tunes as compared to V1.5x tunes, you can see changes if you compare rom's in romraider.
Old 08-07-2014, 04:19 PM   #345
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
I hope I get to hear that sound soon too
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 08-07-2014, 05:27 PM   #346
Migero86
Migero86's Avatar
Originally Posted by Shiv@Openflash View Post
Edit (8/5/14): 8/05/14
v2.03b Released
Where does one find this file? I checked the website and I don't see the link, still the old 2.0 link is there.
Old 08-07-2014, 05:38 PM   #347
steve99
Drives: FT86
http://openflashtablet.com/Automotiv...ads/index.html
ok here
hold down "control" key and click "refresh" on page in case you browser has chached old page
Migero86 (08-07-2014)
Old 08-07-2014, 05:40 PM   #348
Migero86
Migero86's Avatar
^^ Thank you Kindly!!
Old 08-07-2014, 07:06 PM   #349
DC2R
Drives: 2014 Scion FR-S
8/05/14
v2.03b
Cheers,
Shiv
Sorry if obvious but this doesn't affect B01C tunes right?
Sent from my SM-N900T using Tapatalk
DC2R is offline   Reply With Quote
Old 08-07-2014, 07:31 PM   #350
Mad1723
Mad1723's Avatar
Drives: Asphalt FR-S
ok here
It should be Shift-F5 to force refresh on Chrome
Mad1723 is offline   Reply With Quote
The Following User Says Thank You to Mad1723 For This Useful Post:
steve99 (08-07-2014)
OpenFlash Tablet v1.42b maps now available Shiv@Openflash Software Tuning 159 09-13-2016 12:29 AM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 05:23 PM
OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted Shiv@Openflash Software Tuning 142 07-22-2014 10:21 PM
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) Shiv@Openflash Software Tuning 255 02-15-2014 04:43 AM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
