Old 08-05-2014, 10:16 AM   #29
Wepeel
Drives: '13 BRZ Ltd
Keep in mind for the rear, since the MR is ~0.78, that the normal wheel speeds that are recommended for low speed / high speed (2 in/sec is the threshold in the first post) needs to be accounted for in the dynos. A wheel speed of 2 in/sec is a rear shock speed of ~1.56 in/sec.
Also - anyone have dynos of KW V3's (non-clubsport)?
Wepeel is offline   Reply With Quote
The Following 2 Users Say Thank You to Wepeel For This Useful Post:
Shankenstein (08-05-2014), solidONE (08-05-2014)
Old 08-05-2014, 12:54 PM   #30
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
Updated for the 1.56 in/sec breakpoint... and the OptimumG link has been added to the list.
Found some shock dyno results from ISC, and that was added.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
Old 08-05-2014, 02:57 PM   #31
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
it says typical AST 4150's although I couldnt find any 86 specific 4150 dynos. not sure if I linked it right, but heres where I found it: http://www.vorshlag.com/forums/showthread.php?t=8192
and some Ohlins TTX25 dyno stuffs:
http://www.ohlinsusa.com/files/files...5%20Dyno_E.pdf
Old 03-11-2020, 01:40 AM   #32
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Dyno shared on another hread.
Originally Posted by M0nk3y View Post
Still a great conversation, I wouldn't mind it.
I think trying to revalve an OEM piston @solidONE to perform the way you want you'll be severely underwhelmed at the end result, just IMO YMMV.
Going back to "it just works" convo. My initial shocks and dyno sheets suggested I had fantastic range on my adjustments, when in reality I actually didn't. Just comes with testing and actually playing around.
Since then, I've revalved the shocks, went with a coated piston to reduce initial nose in for low speed stuff and still can satisfy high speed. Can autocross at 60 mph and can smack a curb at Mid-Ohio at 100 mph and car can go "meh"
I'll attach them for reference, but like a typical whp dyno - everyone's input and application is going to be different from how YOU setup the car
Do you have a dynochart on the previous valving? Very linear curve with a small bump at 2-3 in/sec at lower bleed settings. Was that purpously done?
Intent > Content
Old 04-09-2020, 08:44 PM   #33
solidONE
solidONE's Avatar
Something I've been working on:
2 way with remote digressive canister. Original valving rebound range (valved for big wing rear setup):
Target: (Converting to digressive/digressive valving with reduction of low speed compression damping by half in the main piston valve)
Still working on getting the last shock to come apart. I dont have enough leverage to remove the rod guide. it has 4 x 4.5mm pinholes that is only 2mm deep.. Any MacQuyvers out there with suggestions is much welcomed.
Intent > Content
The Following User Says Thank You to solidONE For This Useful Post:
Racecomp Engineering (04-09-2020)
FI Dyno thread swift996 Forced Induction 285 04-07-2026 05:18 PM
NA FR-S/BRZ Dyno Thread myEFispissed Engine, Exhaust, Transmission 11 09-02-2023 09:28 PM
Stock FR-S/BRZ shock dyno & stock FR-S spring dyno xwd Tracking / Autocross / HPDE / Drifting 16 08-07-2014 09:04 PM
