Old 07-30-2014, 04:16 PM   #1
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
The 2nd Official Shock Dyno Thread
Shoutout to @GTM_Challenge for starting this discussion (Link to Thread), @RaceComp_Engineering and @Dave-ROR for the contributions in their monster thread.
There's alot of great information scattered throughout the Interballz about dampers and shock dyno data. I'm hoping to consolidate things for the 86 community.
First off... the terms: damper, dashpot, shock absorber, shock, dampeners, etc are all the same thing. They are transducers that convert one form of energy to another. Movement (velocity) is turned into heat. They can be compared to an electrical resistor, friction, or a nozzle (fluid flow through a small orifice).
Good reference material:
Link to OptimumG's Technical Papers (highly recommended)
Link to Westfield Guide
Link to Roehrig Dynos
Link to Penske troubleshooting
Link to Penske Double Adjustable Manual
Link to Tein's guide
*insert more stuff here*
Things we care about:
Natural frequency
This is the frequency at which a spring-mass system will vibrate/resonate at from a step input. Looks like this:
You can calculate it using this:
where
k = spring rate (in kg/s^2)
m = sprung mass (in kg)
pi = tasty
Generally,
  • 0.5 - 1.2 Hz for passenger cars
  • 1.2 - 1.8 Hz for sportscars
  • 1.8 - 3.0 Hz for modified sportscars
  • 3.0 - 5.0+ Hz for aero-dominated cars
Our OEM natural frequencies are:
Front = 1.37 Hz
Rear = 1.33 Hz
Damped Natural Frequency
When you introduce a damper, it affects the system. You move from this governing equation of motion:
to this:
The first term describes the acceleration and forces. The second term describes the damping and loss terms. The third term describes the spring and restorative terms.
The terms can be connected back to real parameters:
where
w_o = natural frequency (in radians)
and
where
zeta = damping ratio (unitless)
c = damping coefficient (in kg/s)
Damping Ratio
Many theory guys will tell you that zeta = 0.707 is the best, and I tend to agree. Many tuners will tell you zeta = 0.65, which is just fine too. You want to choose a value that has the right mix of rise time, settling time, overshoot, and steady-state bias. Unless your suspension is ridiculously overdamped, you probably won't have steady-state bias. Rise time is important, but not the most relevant to the discussion right now. Let's focus on settling time and overshoot (which are related).
Settling time is the amount of time it takes for a system to recover from a step change. Generally, we talk about 95% settling time which means you won't see any more deviations beyond (0.95, 1.05). Overshoot is relatively simple topic.
Here's what a few different values look like:
For zeta = 0.5, you can estimate the 95% settling time to be ~5, and the overshoot to be 15%.
General suggestions:
low speed (< 2 [Front] or 1.56 [Rear] in/sec) compression = 0.66
high speed (> 2 [Front] or 1.56 [Rear] in/sec) compression = 0.33
low speed (< 2 [Front] or 1.56 [Rear] in/sec) rebound = 0.75
high speed (> 2 [Front] or 1.56 [Rear] in/sec) rebound = 1.50
As you can guess, this means we'll be soft during speed bumps, well-controlled during normal humps in the road, and sluggish when going over potholes.
Google Doc that I'm attempting to fill with shock data: LINK to Google Doc
List of Shock Dyno Data:
OEM SHOWA:
RaceComp Engineering Tarmac T2:
Front
Rear
KW Clubsport:
Front
Rear
Fortune Auto 500 series:
Ohlins DFV:
Front
Rear
ISC N1:
OEM Springs:
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
The Following 13 Users Say Thank You to Shankenstein For This Useful Post:
akahenry (07-31-2014), AlphaMotorsports.ca (07-31-2014), Creole (08-01-2014), DarkSunrise (11-15-2015), Fastbrew (08-01-2014), fstlane (07-31-2014), GotBRZ1691 (07-31-2014), Jyn (03-11-2020), Sleepless (08-01-2014), solidONE (07-31-2014), Turdinator (07-31-2014), Wepeel (08-04-2014), Yoniyama (03-14-2020)
Old 07-30-2014, 06:01 PM   #2
ZDan
ZDan's Avatar
Drives: '23 BRZ
Natural frequency
  • 0.5 - 1.5 Hz For passenger cars
  • 1.5 - 2.0 Hz for sportscars
Our OEM natural frequencies are ~1.8 Hz (front) and ~2.1 Hz (rear).
I'm getting much lower natural frequencies for BRZ.
Front spring rate is 156 lb/in = 27328 N/m
Front motion ratio is ~0.95
Front wheel rate is 27328 N/m * 0.95^2 = 24663 N/m
Front weight is ~2915 lb *.54 = 1574 lb.
Weight on one front wheel = 787 lb. = 357 kg
Unsprung mass ~55 lb. = 25 kg
Sprung mass at one front corner ~357 kg - 25 kg = 332 kg
f = 1/2pi * sqrt(k/m) = 1/2pi * sqrt(24663 N/m / 332kg) = 1.37 Hz
Going through the rear using 198 lb/in spring rate, 0.75 motion ratio, and 280kg sprung mass at one rear corner, I get 1.33 Hz for the rear.
2 Hz is pretty unheard of for "normal" stock street cars. Very stiff for a production car. My FD on 13kg front 11kg rear springs is at 2 Hz (1.96F/2.03R), and it's *way* stiffer than a BRZ!
Old 07-30-2014, 10:55 PM   #3
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Damping Ratio
where
c = ideal damper piston speed
k = spring rate
m = sprung mass
What's a good target though?
Many theory guys will tell you 0.707, since it limits the overshoot to 10%. Many tuners will tell you 0.65, which is fine.
so Zeta is critical damping im assuming. Upon quick search on google, it seems that the frequency list for road cars vs sports cars and race cars varies between both @ZDan's findings and @Shankenstein's findings.
Fairly good reference article: http://www.rqriley.com/suspensn.htm
Old 07-30-2014, 11:03 PM   #4
Racecomp Engineering
Off the top of my head, I think those natural frequencies are quite high. I've had a few beers but they're not that high stock. More like 1.3 to 1.5 ish.
I'll try to contribute some...umm...later.
- Andy
The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post:
cdrazic93 (07-31-2014), gramicci101 (07-31-2014), wparsons (07-31-2014)
Old 07-31-2014, 03:19 AM   #5
ZDan
ZDan's Avatar
Drives: '23 BRZ
Damping Ratio
where
k = spring rate
m = sprung mass
c is not "ideal damper piston speed". c is damping in units of force per velocity. In SI units, Newtons over meter-per-second, or N/(m/s), often shown as N-s/m. For shocks c is not constant, as shown in the plots c is ideally higher for low shock speeds and lower for higher speeds, continuing to decline with velocity. A shock with a constant c would just be a straight line starting at zero and increasing linearly with velocity.
Old 07-31-2014, 05:48 AM   #6
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Ahem... dampeners...
subed.
Old 07-31-2014, 07:19 AM   #7
ZDan
ZDan's Avatar
Drives: '23 BRZ
Ahem, they are most certainly NOT "dampeners"!
The Following 3 Users Say Thank You to ZDan For This Useful Post:
cdrazic93 (07-31-2014), DocWalt (08-07-2020), solidONE (07-31-2014)
Old 07-31-2014, 09:21 AM   #8
Shankenstein
Frosty Carrot
As usual, my posts are full of errors... just to keep everyone on their toes. Those values were borrowed from another thread, and the guidelines were from the Westfield guide.
Guilty as charged. No excuse, Drill Sargent!
From the suspension modeling thread, I've copy-pasta'd this:
Front (FR-S) = 1.24 Hz
Front (BRZ) = 1.43 Hz
Rear (FR-S) = 1.54 Hz
Rear (BRZ) = 1.47 Hz
It's not exactly your 1.37 & 1.33 Hz values, but we're atleast away from the 2.1 Hz value before (Doet!).
Old 07-31-2014, 09:45 AM   #9
ZDan
ZDan's Avatar
Drives: '23 BRZ
Those numbers are also too high. Looks like they incorrectly multiplied the spring rates by the motion ratios to get the wheel rates. You have to multiply spring rate by the SQUARE of the motion ratio to get the wheel rate.
Old 07-31-2014, 10:28 AM   #10
subed.
Get out.
jk.
- Andy
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
Old 07-31-2014, 11:14 AM   #11
Malt
Drives: 2015 WRX
subed.
http://grammarist.com/usage/dampen-damper-dampener/
They mean essentially the same thing in this instance.
@Racecomp Engineering : Do you have the T2 charts available to add to this thread?
Malt is offline   Reply With Quote
The Following User Says Thank You to Malt For This Useful Post:
Old 07-31-2014, 11:26 AM   #12
Yes, I will add those and the T0 charts later today.
- Andy
The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post:
AlphaMotorsports.ca (07-31-2014), Malt (07-31-2014)
Old 07-31-2014, 01:23 PM   #13
Shankenstein
Frosty Carrot
Main post updated. Some errors fixed, and hopefully it flows better.
Old 07-31-2014, 03:32 PM   #14
ZDan
ZDan's Avatar
Drives: '23 BRZ
Forgive me as I continue to nit-pick!
Confusing way to do the units.
Spring rate is more logically done in units of force per distance rather than kg/s^2. Pounds per inch (lb/in) or Newtons per meter (N/m). Coilover springs are often rated in "kilograms per millimeter", but it's important to note that that is kilograms-FORCE per millimeter (kgf/mm). 1kgf = 9.81N.
So you take spring rate in kgf/mm and multiply by 9810 to get the rate in N/m, which works in the equations.
Ditto for the damping. Newtons per meter-per-second, N/(m/s) or N-s/m makes more sense to use than kg/s.
In both cases, the units are actually the same if you swap N for kg-m/s^2, it's just a question of presenting them in a context that makes sense or not.
FI Dyno thread swift996 Forced Induction 285 04-07-2026 05:18 PM
NA FR-S/BRZ Dyno Thread myEFispissed Engine, Exhaust, Transmission 11 09-02-2023 09:28 PM
Stock FR-S/BRZ shock dyno & stock FR-S spring dyno xwd Tracking / Autocross / HPDE / Drifting 16 08-07-2014 09:04 PM
