Old 08-01-2014, 10:21 PM   #15
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
I'd beg to differ.
Everything is stressed out, there will be odd rates of impact that will wear them out. Same with axles and the diff, they'll be taking odd stresses that they aren't normally use to. Not that his diff will shit out on him anytime soon, this car is meant to see some track work from the factory.
I'm pretty damn sure it's the drifting that damaged the shock. If every morning or night he's doing drifting and it adds up to 9k miles, then it makes complete sense to me.
Sit down and imagine what the rear is going through when your drifting. The constant slippage and grip working back and forth? There's a reason why not many people are buying dirt cheap drift cars and turning them into daily drivers or track toys.
We could sit here all day arguing about this because there is no hard facts on this. Just take it to the dealer and make them change it.
Old 08-02-2014, 09:47 AM   #16
wparsons
wparsons's Avatar
You're missing the fact that the rear shock doesn't support or locate the rear suspension though. The UCA, LCA, trailing link and toe link do ALL the work for keeping the wheel where it should be. The only thing the shock does it dampen vertical movement.
If it was a rear strut where the shock was an integral part of the geometry, then maybe.
Think about exactly what the difference in load to the shock is if the rear is slipping or gripping. It's essentially no different. You'll put more load on the rear shocks going straight on a gravel road than you will drifting on a smooth track.
flickr
Old 08-02-2014, 10:28 AM   #17
Ubersuber
Drives: BRZ Pearl White
The OP is French. I don't think he's drifting the way we would use that term.
A roundabout is very short. He is drifting coming out of the roundabout, so for a second or two each time he drives through one, traffic permitting.
This qualifies as normal driving for these cars.
I agree that drifting a car as it is done for sport (or is it art?) could well pound the bejeezus (technical term) out of the factory shocks but that's not what this guy is doing, probably.
Our winters would pound on the shocks much more than roundabout drifting ever could.
Ubersuber is offline   Reply With Quote
Old 08-02-2014, 02:02 PM   #18
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by Mars2 View Post
How long do your oem shock absorber last?
My rear one after 9000 miles are leaking a lot.
Time to go for coil's
1) Warranty the shocks
2) Get aftermarket coilovers after warranty
If you don't warranty them, you're leaving money on the table.
-alex
Old 08-03-2014, 02:38 PM   #19
liquidsky44
liquidsky44's Avatar
Drives: AVO Turbo Subaru BRZ / Subaru WRX
I'm on oem shocks with Tein S-tech since July'12 until now with about 47000 km and it's still fine. No excuse to go for a new coil yet.
AVO Turbo|Essex AP Sprint Kit|AVO Overpipe|HKS Hi-Power Spec L Catback|Cusco Engine Mounts|Whiteline Bushings|KW Clubsport|Defi Advance ZD|AEM Wideband Failsafe Gauge|Greddy ProFec Boost Controller|Tomei 2Way LSD|AEM Water/Meth Kit|PBM Angle Kit + Kunckles|Flatwell LCA|HKS Oil Cooler|Greddy High Cap. Diff Cooler|Sard ATF Oil Cooler|CSF Radiator|
liquidsky44 is offline   Reply With Quote
Old 04-05-2017, 11:31 PM   #20
Astroboy
Astroboy's Avatar
Drives: None
Did you stick with the same 215-45-17?
Sent from my LG-H820 using Tapatalk
Astroboy is offline   Reply With Quote
Old 04-10-2017, 12:22 PM   #21
liquidsky44
Nope. I was running 225 45 17. This was ages ago. Now running with a KW Clubsport and the ride quality is much better.
The Following User Says Thank You to liquidsky44 For This Useful Post:
Astroboy (04-10-2017)
Old 04-11-2017, 08:05 AM   #22
RFB
RFB's Avatar
Drives: FRS
Stock height, 5 YEARS, (tracking every year) 100,000 KM and were still fine when I swapped to another set of new (2016) stock shocks from someone who bought something expensive.
After putting on the "new" stockers I noticed no difference in handling. My old shocks were still good.
RFB is offline   Reply With Quote
The Following 2 Users Say Thank You to RFB For This Useful Post:
Astroboy (04-11-2017), strat61caster (04-11-2017)
Old 04-11-2017, 11:35 AM   #23
RL_BRZ
Drives: BRZ WRB Pearl Limited Manual
66,000 miles... my Left Rear shock started leaking fluid... need to buy coilover this summer... :-)
RL_BRZ is offline   Reply With Quote
Old 04-11-2017, 12:21 PM   #24
Astroboy
Astroboy's Avatar
Drives: None
Ride qualitu better be better for $2300
Which shock for C Street? Jawnathin Tracking / Autocross / HPDE / Drifting 17 07-05-2014 01:03 PM
shock questions cslntuee Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 04-15-2014 10:40 PM
WTB: Rear OEM Shock taimysho0 Want-To-Buy Requests 2 09-12-2013 11:23 PM
Does your FR-S shock the hell out of you when you get out? ortizwyld Scion FR-S / Toyota 86 GT86 General Forum 58 03-10-2013 11:00 AM
