Old 06-30-2014, 07:47 PM   #1
Jawnathin
Drives: Toyobaru FRZ
Which shock for C Street?
Considering dabbling in C Street and looking up various options.
Torn between a budget build of Koni Sport Yellows or more expensive MCS setup but had a few quick questions.
I know for both shocks the fronts are easily adjustable without uninstalling the shocks, but what about the rears? Are they easily adjustable as well?
For the MCS, I know they come in a variety of options. Is the Single Adjustable Non-Remote the only C Street legal version they make? Or are the Double Adjustables C Street legal as well? Not so sure I'd want a double adjustable, but just want to understand my options.
Besides that, if anyone has an opinion or commentary to share on the shocks I'd be open to hearing it.
Thanks.
Jawnathin is offline   Reply With Quote
Old 06-30-2014, 08:16 PM   #2
Jawnathin
Of course I find a few answers after posting a thread (which were not easily found before :P)
After doing more research I am led to believe the rear shocks can be adjusted by pulling carpet back in the trunk.
Didn't find confirmation on which MCS is Street/Stock legal, but did see that they need some perches for the OE spring. So with that in mind, it sounds like any setup is Street/Stock legal as long as the perch is used. All a matter of how much $$$$ I would want to spend. Considering the single adjustable set right now.
Feel free to chime in if I've misunderstood something.
Old 06-30-2014, 08:48 PM   #3
bimmer635csi
bimmer635csi's Avatar
Drives: 2013 Cayenne turbo
Check out rule 13.5.A on page 73 of the Rule Book
I'd say that you are allowed to go with more than one adjuster by the rules. However, if you don't know this already, my guess is you are not experienced enough for a double adjusting damper. It isn't as easy as a single adjuster and can cause bigger problems having to tune 2 things.
My suggestion would be to go with a single adjuster just because it is simpler. Especially for a National level autocross, you won't have the time to think and adjust multiple things, so eliminating options is generally a good thing for a rushed format like that. Road racing allows much more time to analyze and think things through, so if you have the pockets to afford some test sessions, then the double adjusters might be better.
Just my 2 cents though. Others will probably disagree, but we each have opinions.
bimmer635csi is offline   Reply With Quote
Old 06-30-2014, 09:50 PM   #4
Jawnathin
Thanks.
For clarity, I know DAs themselves are stock legal, the question was whether the DA MCS is stock eligible since everyone seems to be consider only the SAs. For example, Stranoparts only advertises the SA setup, so I wasn't sure if there was something about these specific DAs which would make them ineligible.
Anyway, not trying to be rude, but don't worry about my experience or background. The topic is about shocks, not about me.
Old 06-30-2014, 11:05 PM   #5
48Spoons
Drives: Ultramarine FR-S
Adjusting the rears isn't too bad. You just have to undo the clip to the stuff covering the of the trunk and pull them back. Though as a warning if you remove the carpet and the other trunk floor cover, there are a few very convenient places for those clips to fall somewhere deep into the car never to be seen again. Ask me how I know
48Spoons is offline   Reply With Quote
The Following User Says Thank You to 48Spoons For This Useful Post:
Jawnathin (07-02-2014)
Old 06-30-2014, 11:43 PM   #6
xwd
I would call Strano or MCS to make sure they still have the right shocks available which are the stock length. They revised the DA non-remote setup at some point to make the body/shaft shorter so people could lower the car more and its not legal. The SA and remote DA setup I believe are still available, and they do make a lower perch for the stock springs. The perch threads onto the body but must be at the exact same position as stock.
I have a set of the DA remotes if you have any questions.
A few people have had issues with the Koni inserts leaking, Bilstein is probably a better option if you are looking for a cheaper option.
The Following User Says Thank You to xwd For This Useful Post:
Old 07-02-2014, 05:37 PM   #7
Jawnathin
Thanks for the tips, I'll be careful. My old RX8 required the shock to be removed for adjustment. I never bothered with it because it was such a pain. Glad to see its a bit easier on these cars.
Thanks. I spoke to Sam yesterday afternoon and we settled upon the Koni SAs. Wish it was a more straight forward installation where I won't have to cut up my shocks, but for SAs this was the way to go. He really liked the MCS DAs but they were a bit rich for me. I am really envious of your set, haha. Thanks again.
Old 07-03-2014, 06:45 AM   #8
Rexpelagi
Drives: 2013 Subaru BRZ
Konis from Sam are the way to go. :-)
Most people in the CStreet thread are running those and if you look through the last few pages I have my setups there somewhere.
-John L.
2011 BMW M3 - 57 FS
2007 Ford SGT - 57 FS
2013 Subaru BRZ - Sold
Rexpelagi is offline   Reply With Quote
Old 07-03-2014, 08:32 AM   #9
mla163
Overthinking it
Drives: BRZ in CS
I just ordered a set of Konis myself from Stranoparts.com.
I asked Sam about the other options. Bilstein makes a shock, but it is not adjustable, which defeats the purpose. MCS is pretty baller, but won't make much of a difference for the additional few thousand dollars.
mla163 is offline   Reply With Quote
Old 07-03-2014, 09:01 AM   #10
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
a shock's main attribute is valving, both compression and rebound, which translates in how it controls your car's oscillations.
adjustability is a feature, but it should never be the selling point
when you choose to upgrade a shock you are choosing between the valving of that particular manufacturer.
so no, a non adjustable bilstein does not "defeat the purpose" because even though it doesn't adjust it still offers a different feel because it is valved differently. It is also a monotube, which generally yields better control at the OTS level.
part of the reason though why everyone defaults to just one brand is because all these dampers follow the same philosophy... basic compression characteristics, high rebound. So it's like having a strict burger diet... if you're only gonna be eating burgers, then going to McFucks isn't all that bad and there really isn't a need to buy the fancy stuff.
but the real upgrade comes when you get to chew on a nice juicy steak, but that means custom valved from the start...
Old 07-03-2014, 09:45 AM   #11
chucky12012
Drives: 2013 Asphalt Scion FR-S
As 7thgear said, the Bilsteins are not adjustable, but it's a really nice shock out of the box for the money. I'm running them and the car is very competitive. I always figure that with adjustments comes the introduction of user error in some cases.
chucky12012 is offline   Reply With Quote
Old 07-03-2014, 11:00 AM   #12
DylanFRS
Lost in Kansas
DylanFRS's Avatar
Drives: 2013 Scion FRS (Raven)
Did you have them valved to a certain spec or just off the shelf valving?
DylanFRS is offline   Reply With Quote
Old 07-03-2014, 11:25 AM   #13
markw
Drives: 2014 FR-S
Off the shelf valving for a specific application is usually very good from Bilstein, I know their R&D guys and it's amazing what they do with just shocks. You can't go wrong with them. I'll be looking at the B6's (HD) shocks if/when I replace mine. I've got a set of Koni's on my STC civic and they leak from the adjuster.
markw is offline   Reply With Quote
Old 07-03-2014, 12:46 PM   #14
chucky12012
I'm running off the shelf valving.
Megan Racing Coilovers - Street / Track / EZ STREET - Starting at $699 Shipped GuerillaRacing Brakes, Suspension, Chassis 149 05-12-2015 05:53 PM
Evasive Street BRZ Breaks 1:59 Stock Motor and Street Tires Buttonwillow CW13 Video Evasive Motorsports Tracking / Autocross / HPDE / Drifting 31 07-02-2014 01:43 PM
Megan Racing Street vs EZ Street g0lden Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 04-14-2013 06:50 PM
Cusco Street Zero-A & Street Spec A Coilovers - In Stock And Ready To Ship Enjuku Racing Brakes, Suspension, Chassis 0 09-12-2012 05:12 PM
