Old 08-01-2014, 01:43 PM   #6931
shif7i7down
Erected Member
Drives: frs
Originally Posted by fenton View Post
I've talked to Rob this week a couple times as we are testing something. Right now he is redoing his instructions and investigating some recent failures. Once he is done those two things he will start pushing out more kits. He really needs to make the install fool proof because even small mistakes can result in electrical shorts or wires getting melted.
When i hear you say stuff like "we are testing something"
I can't help but think that you're testing some new mods.
shif7i7down is offline   Reply With Quote
The Following 6 Users Say Thank You to shif7i7down For This Useful Post:
Blu-by-U (08-01-2014), DAEMANO (08-01-2014), fenton (08-01-2014), Gums (08-02-2014), l0aded (08-01-2014), Sojhinn (08-01-2014)
Old 08-01-2014, 07:37 PM   #6932
silent runner
Drives: 93'Camry, 82'Corolla, 76' Celica
Originally Posted by DAEMANO View Post
Wait, I'm confused. Is this still for the Camry from Hades or another make/model?
I think the Camry from "Hades", your refering to is that one that makes over 1000whp, based out of Toronto, Canada. Mine is another emerald green Camry, with a prototype Phantom ESC kit (with installation hard wardware designed by me), running around in Fenton and Rob's back-yard. This one would probably just shake you guys (running the ESC) up a bit, as it might hang far better than it should, with your FRS/BRZ's. If you don't have the ESC, watch out, it might just walk all over you!
silent runner is offline   Reply With Quote
The Following User Says Thank You to silent runner For This Useful Post:
Old 08-01-2014, 07:38 PM   #6933
fenton
I think he was asking because you mentioned something about Mazda.
fenton is offline   Reply With Quote
The Following User Says Thank You to fenton For This Useful Post:
Old 08-01-2014, 07:50 PM   #6934
silent runner
Got ya. I scavenged wrecking yards for pieces to build my prototype install with. Found a handy piece off of a Mazdaspeed 3. It has been so reliable that I've just kept it in place, and not replaced it with full out silicone "Frozen Boost" pieces yet. If your not expecting it, my little old Camry is, a little bit of a "bad" old girl to run into though.
Old 08-01-2014, 10:13 PM   #6935
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
OK. So I got one and its on the car as of 30 minutes ago. The humidity is horrible, the tune is fresh the batteries are being reconditioned yet my jaw hurts from a smile plastered on my face. Am I dreaming or is this for real?
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
The Following 8 Users Say Thank You to Boofneenee For This Useful Post:
DAEMANO (08-01-2014), enwave (08-02-2014), fenton (08-01-2014), Gums (08-02-2014), MagicBobert (08-02-2014), nlowell (08-01-2014), robwbright (08-03-2014), WRB5titch (08-04-2014)
Old 08-01-2014, 10:17 PM   #6936
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
you have been trying to decide about as long as I have been waiting to order and you still got one before me... Well at least another happy customer only confirms my choice. Hope you enjoy it.
Phantom ESC, OFH, OFT, K&N Drop in
Target70 is offline   Reply With Quote
The Following 2 Users Say Thank You to Target70 For This Useful Post:
Boofneenee (08-01-2014), DAEMANO (08-01-2014)
Old 08-01-2014, 10:19 PM   #6937
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Welcome aboard. And a huge told you so to you sir.
Installed Mods:
The Following 4 Users Say Thank You to Sojhinn For This Useful Post:
Boofneenee (08-01-2014), DAEMANO (08-01-2014), robwbright (08-03-2014), WRB5titch (08-04-2014)
Old 08-02-2014, 12:47 AM   #6938
Gums
Drives: SWP BRZ
This sums up my experience perfectly
Gums is offline   Reply With Quote
The Following User Says Thank You to Gums For This Useful Post:
keen as (08-03-2014)
Old 08-02-2014, 12:49 AM   #6939
MmmHamSandwich
You know you want it.
MmmHamSandwich's Avatar
Drives: '13 FR-S
I have a point of confusion I am hoping kit owners can answer.
I hear people repeatedly state this kit "only makes boost at WOT." This makes no sense to me, as an FI setup that only engages the moment you hit full throttle would exhibit unsafe drivability. Is this truly how the kit operates or are these just uninformed people repeating the same banter over and over?
Can someone elaborate on when/how this kit engages boost. I assume it is in fact modifiable according to the tuning. The way people talk about it however, make it sound like an on off switch and not progressive like, say, every well tuned FI solution in existence. Are there really people who have it set up in such a fashion, and do they realize the hazards it presents?
The Following User _________ Stay_Puft(09-13-2014)
Says Thank You to
MmmHamSandwich For
This Useful Post:
MmmHamSandwich is offline   Reply With Quote
The Following User Says Thank You to MmmHamSandwich For This Useful Post:
Chad86 (08-02-2014)
Old 08-02-2014, 01:05 AM   #6940
enwave
That headunit though...
enwave's Avatar
Drives: 2013 Subaru BRZ Limited SSM
Full throttle Electric Supercharger Build Thread
5psi of boost is hardly dangerous, unless you are an idiot. It is engaged by a mechanical switch bolted behind the throttle pedal. It does take about a half second to a second to ramp up, but it is more or less on/off. Every user of the system has it set up that way.
2013 BRZ Limited SSM 6AT
Phantom ESC 1.5Dump + E85 + OFH + Q300
Eibach Pro-Kit + Michelin PSS (stock size)
enwave is offline   Reply With Quote
Old 08-02-2014, 01:10 AM   #6941
Urmyson
It's uses a switch on the gas pedal. It works very well, when you floor it the car moves. Where before you just made a lot of engine noise and didn't go anywhere to fast. At least thats how it feels to me.
Urmyson is offline   Reply With Quote
Old 08-02-2014, 01:20 AM   #6942
MmmHamSandwich
Drives: '13 FR-S
Glad y'all are having a blast with it. Unfortunately it sounds like it's not what I'm looking for.
Says Thank You to
MmmHamSandwich For
This Useful Post:
Chad86 (08-02-2014)
Old 08-02-2014, 01:52 AM   #6943
fenton
You are right. It is not progressive but it is also not intrusive. It basically feels like you have a bigger engine when you engage WOT.
It feels just like a low spooling turbo in that sense.
Many people have raised this concern but all those that have used the system can attest to its linear acceleration and smooth onset of boost.
Old 08-02-2014, 02:44 AM   #6944
DAEMANO
Time Traveller
@MmmHamSandwich
How does it feel?
<80% Throttle = Like a NA car + e85, header & tune
>80% Throttle = Like a FI car with short boost lag (~500ms)
Corner Entry = <80% Throttle (NA car)
Corner Steady State = <80% Throttle (NA car)
Corner Exit = Rolling on to throttle while unwinding steering wheel (NA car transitioning to FI car)
Straight = >80% Throttle (FI car)
It's not complicated.
The Following User Says Thank You to DAEMANO For This Useful Post:
Blu-by-U (08-02-2014)
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
