Old 05-16-2014, 12:08 PM   #43
DarkSunrise
DarkSunrise's Avatar
Originally Posted by iStanley View Post
My shift into third is usually 80% bad. It feels like a spring launches it into 3rd and feels like it hits something on way there. Also, 4th gear feels the best, after they replaced my transmission of course.
Yep that sounds like my 2-3 shift as well. If I don't wait for the revs to drop between shifts, it feels like it catches hard on something on the way into 3rd.
I find it works best if I hesitate for just a moment to let the revs drop, then go full speed into the 3rd gear gate. If I move it slowly into 3rd, it's worse.
2022 BRZ Build
2013 FR-S Build
Old 05-16-2014, 12:41 PM   #44
PMPB
Drives: BRZ Sport-tech
I'm swapping in Gear 300 this afternoon. I'm at 9700km and last night out of no where I had a horrific grind going into 2nd. 3rd and 5th have always felt very notchy. Reverse and 1st are not easy to engage unless the car is rolling slightly. 2nd only felt slightly grindy last winter when really cold, so I always started from 2nd until I'd driven for about 5minutes and I was always very ginger with it.
PMPB is offline   Reply With Quote
Old 05-16-2014, 12:56 PM   #45
iStanley
They call me Stan
iStanley's Avatar
Drives: Firestorm FR-S
With all these problems with MT I sometimes feel like I should of got and AT
iStanley is offline   Reply With Quote
Old 05-17-2014, 05:14 PM   #46
nyfries
Drives: 14 FRS Whiteout
last night, i have the best experience with my gear shifts. after a long day or work i got back to the car at around 2am. it was 15degrees out and OMFG it was the smoothness shifting i have experiences ever since i got the car. doesn't catches anywhere. no clunk. no notchiness. just buttery smoooooth.
that disappear after a few km… i'm thinking these transmission or the OEM fluid has a optimal operating temp. once its below that temp or above it that when it get notchy and shitty?
nyfries is offline   Reply With Quote
Old 05-17-2014, 05:19 PM   #47
Spicer66
Spicer66's Avatar
Drives: Raven 6 MT
My car has a real nasty grind going 3rd to 4th and its only above 3500 RPM, luckily I work at a Toyota Dealership. All new synchros and a 3rd gear being installed on Tuesday.
FYI all of the parts we needed were on back order, so it appears to be a common issue. Common issues usually end with a TSB. I'm watching for one.
Spicer66 is offline   Reply With Quote
The Following 2 Users Say Thank You to Spicer66 For This Useful Post:
number1Tango (09-12-2014), PMPB (05-17-2014)
Old 05-17-2014, 09:24 PM   #48
BRZ283
BRZ283's Avatar
Drives: 2013 subaru BRZ Limited
Any time I shift from 3rd to 4th at high revs, it grinds badly.
I bought the car used a month ago with 13,000k miles. It was my first manual car. The gears grinded the first week when I had a speed run and thought it was my human error, as well as me getting used to the car. It happened a few times after and its week four of owning it. I took it to the Toyota dealership but for some reason it smoothly shifted every time. The service technician rode with me and he even drove. No dice, no grind. He convinced me that it may be my own fault and that I am just getting used to it. I left thinking that it was my own fault and drove home shifting quickly grind-free. The next day (today), I shifted at high revs to 4th and it grinded. Anyone else having/had this issue?
My gearbox was faulty from the manufacturer and I had warranty work on it at 8k. They said it's to new to open up and fix so they just pulled it and replaced with new gearbox. No problems ever since but it grinder so awful above 5k rpm going from 2nd to 3rd. Almost as if clutch was not in at all!
BRZ283 is offline   Reply With Quote
Old 07-29-2014, 09:56 AM   #49
tennisfreak
Drives: 2018 BMW M240i
This just started happening to my car yesterday. Shifting into 4th gear from any rpms above 4000 now results in a grind.
I have 16.5k miles.
Will be contacting dealer/service center soon.
The Following User Says Thank You to tennisfreak For This Useful Post:
kombatlion (07-29-2014)
Old 07-29-2014, 10:05 AM   #50
kombatlion
Life to short to be slow!
kombatlion's Avatar
Drives: Toyota GT86
I am about to remove the Turbo Kit, all the performance and trade in my FRS if my trans if broken.. it means is a piece of crap and it will be broke again in a couple years I would not go tru this every 2 years. And for me there is no warranty just 2k to get it fix.
Anyone knows the price of a new transmision? is really and update on the parts or is the same trans?
kombatlion is offline   Reply With Quote
Old 07-29-2014, 02:03 PM   #51
iStanley
They call me Stan
iStanley's Avatar
I was under warranty, but the price with labor was around 6k.
Old 07-31-2014, 09:18 PM   #52
GT86King
Drives: 2013 UltraMarine FRS
I bought my car used, got it with 9500 miles, I now have 19k on it and well im getting the same issue going from 3rd to 4th gear, it grinds or make a strange sound.
GT86King is offline   Reply With Quote
Old 08-01-2014, 10:09 AM   #53
tennisfreak
I have found that if I resort to shifting slow when at high speeds then the grind does not happen.
So if I floor it and in 3rd put the clutch in around 7K rpm I need to wait at least 1/2 second before I try to put it into 4th. If I do this there is no grind.
Old 08-01-2014, 10:27 AM   #54
kombatlion
kombatlion's Avatar
Drives: Toyota GT86
Well mine was the clutch, 4 months of use ACt 6 pug, at 360whp so it sucks balls
Old 08-01-2014, 11:15 AM   #55
mike the snake
I think a lot of the grinding and notchy shifting is due to clutch adjustment.
On my car, the clutch was not completely disengaging, and after adjusting the clutch the shifting was improved.
Old 08-01-2014, 12:20 PM   #56
kombatlion
kombatlion's Avatar
Drives: Toyota GT86
How did you adjust?
How would you shift from 4 to 5? qqzj BRZ First-Gen (2012+) — General Topics 37 05-01-2014 08:10 PM
You know what really grinds my gears...... z3ro Off-Topic Lounge [WARNING: NO POLITICS] 7 10-10-2013 01:55 PM
HUD shift up and shift down display question JS86JS Electronics | Audio | NAV | Infotainment 6 05-17-2013 02:54 AM
What really grinds my gears! CircuitJerk Off-Topic Lounge [WARNING: NO POLITICS] 124 04-01-2013 08:45 PM
How do you shift? Carbon420 Scion FR-S / Toyota 86 GT86 General Forum 27 12-30-2012 01:11 PM
