Old 04-19-2012, 10:02 PM   #211
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Well, looks like the cat in the manifold is the primary cat.
Found this in another thread (ignore the red arrow):
The downstream O2 sensor is immediately after the first cat. The second cat is completely un-monitored. So moving the primary downstream will require extending the second O2.
EDIT: Yay! Looks like those stupid little tips are removable. It's a little ricey, but it seems we can replace them with something bigger to fill out the bumper cutouts.
Old 04-19-2012, 10:54 PM   #212
MtnDrvr86
Drives: 2002 honda civic ex
Yes! Walmart exhaust tips here I come! hahaha or not...
MtnDrvr86 is offline   Reply With Quote
Old 04-20-2012, 03:50 AM   #213
Gardus@Supersprint
Drives: Clio TCE
I think we could use the room for the 2nd cat for the headers and place the sports cats even more downstream.
I need to see if the pre-cat sensor wire is long enough for the header design I have in mind, it would be a hassel to extend both the cables.
I see there is a resonator on the centre section...guess this car really tends to drone.
If all the components have flanges how it looks like in that drawing a modular system will be easy to make, with no cut in the stock one.
Depending on the room available around the rear diff we could put a Y-pipe where the centre silencer is and use two separate mufflers with longitudinal piping, but that would mean an axle back won't be available.
To answer Grip Ronin about the stock system:
Design of the header and the sequential cats id because of the gas regulations.
The centre silencer (or resonator) is to avoid drone.
The rear box is designed to be cheap. The silencer is a not a straight flow one, the pipe ends and inside there are some chambers, then the two pipes start again to reach the endpipes. Is a common design on 4 pots cars with twin exits, for example the VW Golf GTI.
Gardus@Supersprint is offline   Reply With Quote
Old 04-20-2012, 08:21 AM   #214
Draco-REX
Corner Junkie
Draco-REX's Avatar
I've heard that a transverse muffler like that also helps to cut down on drone.
Old 04-20-2012, 10:15 AM   #215
Gardus@Supersprint
Drives: Clio TCE
Yes, that's true, especially with chamber mufflers.
Old 04-20-2012, 10:26 AM   #216
wcbjr
Drives: 2006 Subaru LGT
Originally Posted by Subaruwrxfan View Post
Yep, this is what I did with my Legacy GT when I went with a catless up-pipe.
Or remove the CEL with a reflash.
wcbjr is offline   Reply With Quote
Old 04-20-2012, 04:19 PM   #217
AJ PwR
AJ PwR's Avatar
Drives: R35 R56 CZ4A ZC6
Send a message via ICQ to AJ PwR Send a message via AIM to AJ PwR Send a message via MSN to AJ PwR
That doesn't look very good, why so many welds, you can make that with just one bent pipe and it'll be lighter and stronger. The problem with NA engines, especialy 4 pots in small cars, it's they tend to drone. A transversally mounted mufflers helps, and doesn't really affect the power much. I've seen that HKS went for a helmotz resonator on its louder system. We use it sometimes but it's heavy. As the market will be floaded with catback exhausts coming from the same factories in taiwan and china, we'll concentrate in making the best header+cat kit we can.
There are many welds because they can't do mandrel bending and I don't think there's other reason for it.
I have this diagram too. The secondary cat can be totally deleted but I think it's good to be resonated or else the exhaust will drone.
AJ PwR is offline   Reply With Quote
Old 04-21-2012, 01:05 AM   #218
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
i cant imagine a Helmholtz res not having an effect on performance
Grip Ronin is offline   Reply With Quote
Old 04-21-2012, 01:52 AM   #219
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Imagine harder.
old greg is offline   Reply With Quote
Old 04-21-2012, 05:00 PM   #220
Grip Ronin
The Mechanic
Grip Ronin's Avatar
lol it doesn't effect the flow? i mean its offers a passage for the fumes that is just a dead end
IG-Joey_Soul
Progress Thread Ported billet 20G
Old 04-21-2012, 06:20 PM   #221
Droopy
FWES racer, R FT drifter
Droopy's Avatar
Drives: BMW, Chevy, Soon to be FR-S
ok why cant you collect the two exhausts on the right together and the left side together then all 4 just before the cat? wouldnt that increase flow and be less restrictive? and delete the 2nd cat altogether or create a resontating chamber there
EDIT: or would the angles be to sharp?
Droopy is offline   Reply With Quote
Old 04-21-2012, 06:31 PM   #222
Dimman
Kuruma Otaku
Dimman's Avatar
Has to do with firing order and scavenging.
Because titanium.
Old 04-21-2012, 06:34 PM   #223
Droopy
Droopy's Avatar
ok thanks
Old 04-22-2012, 11:41 AM   #224
StuttterButtter
Yes i have a stutter
StuttterButtter's Avatar
Drives: 94 Acura Integra
Any one know if RS-R will have a Exhaust coming out (or any other products) for the FR-S or BRZ. I have one of the Exmag's (not the GT2 Version) now and a friend has one on his 06 Evo and i love the sound. Very quiet in low RPM's but sounds great in high.
StuttterButtter is offline   Reply With Quote
Aftermarket battery speed-wiz Scion FR-S / Toyota 86 GT86 General Forum 59 08-07-2012 11:23 PM
BRZ Aftermarket Sources brzmaybe BRZ First-Gen (2012+) — General Topics 50 01-02-2012 09:57 PM
Aftermarket wheels? Levi Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-06-2011 07:19 AM
What Aftermarket parts would you like to see for the FT86/FRS mkivalex Scion FR-S / Toyota 86 GT86 General Forum 78 11-14-2011 10:50 AM
