#30 |
Drives: orange fr-s MT
I love my solo DL. The ability to log rpm, brake pressure, throttle position, steering angle, wheel speed on 10-20Hz rate is priceless.
While reviewing my run, I noticed that air temp is lower than expected. I cross-checked temperature reading with techstream today and found that coolant , ambient air, and intake air temp is ~18F lower. Can someone check and see if there is the same discrepancy? If so, I can contact the company and ask them to fix scaling or offset factor. |
#31 | |
Drives: 2013 Cayenne turbo
Chris
Track, Autocross & Daily Driver build thread - SOLD Another A&DD for my VW GTI - SOLD And finally, my YouTube channel Last edited by bimmer635csi; 07-29-2014 at 11:41 PM. |
#32 |
Does increasing the number of channels being recorded reduce the frequency of data?
For example, if I record 1 channel, I might get data at 10 Hz, but if I record 10 channels, I might only get data a 1 Hz.
Chris
Track, Autocross & Daily Driver build thread - SOLD Another A&DD for my VW GTI - SOLD And finally, my YouTube channel |
#33 |
Drives: Used to Drive:Grand-Am GS #54 E36M3
Hopefully, you'll find that you are able to choose the rate at which you sample the channels you're logging, as some data require fast sample rates and others are fine at the slowest rate. Examples: RPM at 10 samples per second and oil temperature at 1 sample per second. That will give you the data you need without filling your logger's memory with unnecessary data.
#34 | |
i'm sorry, what?
Drives: Canada
No, the frequency stays the same. The only thing that increases is the log size. More channels at higher frequencies will fill up your memory card faster. Frequency limits are set by the sensor. I do not believe (ie, I assume) that the ECU interface, cable, or the datalogging unit (at least the AIM product) are not bottlenecks in this situation.
| The Following User Says Thank You to 7thgear For This Useful Post: | CSG Mike (07-31-2014) |
#35 | |
If you max out all the channels, you're collecting something around a thousand data points per second. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | whataboutbob (08-04-2014) |
#36 |
Stig's dark passenger
How is the steering angle achieved?
Sensor or diff of front wheel speeds? D |
#37 |
It should be sensor.
Chris
#38 |
#39 | ||
I used my new AiM Solo DL this weekend at Thunderhill. Wow, so much data to crunch afterwards! There was one time where I spun... upon reviewing the data, I saw that I lifted in the corner, causing the rear end to come around.
GPS timing was within 0.2 seconds of the AMB setup at the track. Quote:
I can also confirm that water temps read LOW by about 18F. AiM Solo DL was showing 212-215F water temps, which I thought was ok.... until I noticed the stock temp needle on its way to H at one point. Yes, it was really 230F+. I changed it to read Celcius, but it's still off. @CSG Mike ? Saturday was too hot.. I think I blew the DI seals.
| The Following 5 Users Say Thank You to mkivsoopra For This Useful Post: | 86ft.lb (08-04-2014), ddeflyer (08-04-2014), juliog (08-04-2014), RehabJeff86 (08-04-2014), whataboutbob (08-04-2014) |
#40 | |
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next! |
| The Following User Says Thank You to ddeflyer For This Useful Post: | CSG Mike (08-04-2014) |
#41 | |
| The Following 3 Users Say Thank You to 86ft.lb For This Useful Post: |
#42 | |
| The Following User Says Thank You to mkivsoopra For This Useful Post: | RehabJeff86 (08-04-2014) |
| Solo 1 | kombatlion | SOUTH AMERICA / CARRIBEANS | 6 | 03-20-2015 04:01 AM |
| 2014 SCCA Solo Nationals/Pro Solo Finale thread | edj | Tracking / Autocross / HPDE / Drifting | 206 | 09-19-2014 11:34 AM |
| N.J. Pro Solo | Simmons | Tracking / Autocross / HPDE / Drifting | 20 | 03-11-2013 05:32 PM |
| 2013 Preliminary SCCA SOLO and PRO SOLO National Schedule | Scooby South | Tracking / Autocross / HPDE / Drifting | 13 | 12-05-2012 08:08 AM |
