Old 07-29-2014, 07:46 PM   #29
CSG Mike
CSG Mike's Avatar
Originally Posted by Sleepless View Post
Same... Got a track day coming on the 5th and new Ohlins to test/log/analyze
PM'd you your tracking.
Sleepless (07-29-2014)
Old 07-29-2014, 10:17 PM   #30
86ft.lb
86ft.lb's Avatar
Drives: orange fr-s MT
I love my solo DL. The ability to log rpm, brake pressure, throttle position, steering angle, wheel speed on 10-20Hz rate is priceless.
While reviewing my run, I noticed that air temp is lower than expected. I cross-checked temperature reading with techstream today and found that coolant , ambient air, and intake air temp is ~18F lower. Can someone check and see if there is the same discrepancy? If so, I can contact the company and ask them to fix scaling or offset factor.
86ft.lb is offline   Reply With Quote
Old 07-29-2014, 11:01 PM   #31
bimmer635csi
bimmer635csi's Avatar
Drives: 2013 Cayenne turbo
You're on the right track. Zero F is -17.77777 (aka -18) deg C.
bimmer635csi is offline   Reply With Quote
Old 07-30-2014, 12:18 AM   #32
bimmer635csi
Does increasing the number of channels being recorded reduce the frequency of data?
For example, if I record 1 channel, I might get data at 10 Hz, but if I record 10 channels, I might only get data a 1 Hz.
Old 07-30-2014, 10:49 AM   #33
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
Hopefully, you'll find that you are able to choose the rate at which you sample the channels you're logging, as some data require fast sample rates and others are fine at the slowest rate. Examples: RPM at 10 samples per second and oil temperature at 1 sample per second. That will give you the data you need without filling your logger's memory with unnecessary data.
dradernh is offline   Reply With Quote
Old 07-30-2014, 11:11 AM   #34
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
No, the frequency stays the same. The only thing that increases is the log size.
More channels at higher frequencies will fill up your memory card faster.
Frequency limits are set by the sensor.
I do not believe (ie, I assume) that the ECU interface, cable, or the datalogging unit (at least the AIM product) are not bottlenecks in this situation.
The Following User Says Thank You to 7thgear For This Useful Post:
CSG Mike (07-31-2014)
Old 07-31-2014, 06:07 PM   #35
CSG Mike
CSG Mike's Avatar
Nope, only the file size gets bigger. The AIM has a lot of built-in memory though, so you won't run out of space if you're clearing it out regularly.
If you max out all the channels, you're collecting something around a thousand data points per second.
whataboutbob (08-04-2014)
Old 07-31-2014, 08:12 PM   #36
D K
Stig's dark passenger
How is the steering angle achieved?
Sensor or diff of front wheel speeds?
D
D K is offline   Reply With Quote
Old 07-31-2014, 10:08 PM   #37
bimmer635csi
D
It should be sensor.
Old 07-31-2014, 11:30 PM   #38
CSG Mike
CSG Mike's Avatar
D
Steering angle sensor. It's independent of the front wheel speed sensors.
Old 08-04-2014, 03:32 PM   #39
mkivsoopra
I used my new AiM Solo DL this weekend at Thunderhill. Wow, so much data to crunch afterwards! There was one time where I spun... upon reviewing the data, I saw that I lifted in the corner, causing the rear end to come around. GPS timing was within 0.2 seconds of the AMB setup at the track.
I can also confirm that water temps read LOW by about 18F. AiM Solo DL was showing 212-215F water temps, which I thought was ok.... until I noticed the stock temp needle on its way to H at one point. Yes, it was really 230F+. I changed it to read Celcius, but it's still off. @CSG Mike ?
Saturday was too hot.. I think I blew the DI seals.
mkivsoopra is offline   Reply With Quote
The Following 5 Users Say Thank You to mkivsoopra For This Useful Post:
86ft.lb (08-04-2014), ddeflyer (08-04-2014), juliog (08-04-2014), RehabJeff86 (08-04-2014), whataboutbob (08-04-2014)
Old 08-04-2014, 03:54 PM   #40
ddeflyer
We should all do a data log exchange and see where we win and where we fail!
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next!
ddeflyer is offline   Reply With Quote
The Following User Says Thank You to ddeflyer For This Useful Post:
CSG Mike (08-04-2014)
Old 08-04-2014, 03:54 PM   #41
86ft.lb
86ft.lb's Avatar
Thanks for confirming. I contacted AIM and got reply that there is 10C(=18F) offset added at unknown time with unknown reason. I got patch file for the analysis software, but didn't bother to test it. I will just add 10C in my head until new software is released. BTW, I am very impressed by the prompt support from AIM.
The Following 3 Users Say Thank You to 86ft.lb For This Useful Post:
CSG Mike (08-04-2014), mkivsoopra (08-04-2014), RehabJeff86 (08-04-2014)
Old 08-04-2014, 04:00 PM   #42
mkivsoopra
Ooh, so they know there's an issue. Is it just a patch for the analysis software or more than that? I depend on the actual unit to tell me the real time temps (turbo car... generating lots of heat). I guess I'll contact AiM too. BTW 10C != 18F
The Following User Says Thank You to mkivsoopra For This Useful Post:
Solo 1 kombatlion SOUTH AMERICA / CARRIBEANS 6 03-20-2015 05:01 AM
2014 SCCA Solo Nationals/Pro Solo Finale thread edj Tracking / Autocross / HPDE / Drifting 206 09-19-2014 12:34 PM
N.J. Pro Solo Simmons Tracking / Autocross / HPDE / Drifting 20 03-11-2013 06:32 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 09:08 AM
