Old 07-30-2014, 04:04 PM   #1
EZWood
BAMF
EZWood's Avatar
variable vane turbos
Why is it that no one has used variable vane turbos for our cars? I'd like t start a discussion on the pros and cons. I have a gt3782v that is currently a giant paperweight. I'm thinking that it would spool relatively early and could avoid excessive egt's with the size of the exhaust housing. What are your thoughts on something like this.
Old 07-30-2014, 04:09 PM   #2
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Use the search button. I already started a thread like this.
Old 07-30-2014, 04:12 PM   #3
EZWood
BAMF
EZWood's Avatar
Search doesn't work well on mobile. Would you be kind enough to provide a link?
Old 07-30-2014, 04:23 PM   #4
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
http://www.ft86club.com/forums/showthread.php?t=57972
Old 07-30-2014, 04:31 PM   #5
blackhawkdown
blackhawkdown's Avatar
Drives: 2012 WRX, 2003 RSX Type S
when people talk about variable vanes i think about turbine engines. the variable vanes in the t701d, uh-60 blackhawk engines, opens up to increase air and power. it is kept close until a certain power percentage is reach (NG). variable vanes in turbine engines change the angle on how the air is sent to the compressor, it uses the anti-ice start bleed valve to control the amount of air going into the compressor and diffuser. an actual design of such a turbo would make it pretty efficient but it would make the turbo pretty big.
Originally Posted by fatoni View Post
saying they wanted to add weight to improve handling is like saying people wear condoms to improve sex.
blackhawkdown is offline   Reply With Quote
The Following User Says Thank You to blackhawkdown For This Useful Post:
thatfilipinoguy (07-30-2014)
Old 07-30-2014, 05:00 PM   #6
EZWood
BAMF
EZWood's Avatar
It doesn't increase the physical size by very much. I would post a pic, but I'd have to resize it.
Old 07-30-2014, 10:20 PM   #7
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
To compress that kind of adjustabikity into a turbo of reasonable size, it gets incredibly complicated very fast. And its a direct coorilation to the price as well. If you already have one like the OP said, then id contact JDL as in the thread i posted they said they were willing to help with a custom setup if i ever wanted to make one.
Old 07-31-2014, 01:16 AM   #8
Poodles
Drives: 2015 Series.Blue
Expensive and overcomplicated when a twin scroll with a quick spool valve would work nearly as good Hell, even Honda knew that...
Old 07-31-2014, 04:54 AM   #9
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I never bothered to figure out what a quick spool valve is, care to enlighten me?
Old 07-31-2014, 05:13 PM   #10
DoomsdayJesus
In Autobahn withdrawl
DoomsdayJesus's Avatar
Drives: 2015 BRZ Limited Man., WRB
It's something you really see far more often on truck turbodiesels. I believe Ram trucks with the Cummins Turbodiesel have them as an option.
DoomsdayJesus is offline   Reply With Quote
Old 08-02-2014, 11:30 PM   #11
Poodles
I'm not sure I can link it as it's not a vendor on these forums. Commonly used on Supras and they come right up in google...
Old 08-03-2014, 07:02 PM   #12
1stGenBRZ86
1stGenBRZ86's Avatar
quick spool valves close off one "scroll" on a twin scroll turbo until a certain boost pressure is reached. This allows you have a very big turbo with a relatively quick onset of boost.
1stGenBRZ86 is offline   Reply With Quote
Continuously Variable Transmission Lexicon101 Other Vehicles & General Automotive Discussions 79 06-26-2015 03:18 AM
STi rear roof vane on BRZ? Zechs21 Cosmetic Modification (Interior/Exterior/Lighting) 6 10-13-2014 02:28 PM
Variable Gemoetry Turbo (VGT) cdrazic93 Forced Induction 29 02-12-2014 11:12 AM
Dealership Accuses Variable Valve Timing (VVT) Ajustment shiro Issues | Warranty | Recalls / TSB 48 12-20-2013 10:03 AM
Rotrak variable supercharger madfast Other Vehicles & General Automotive Discussions 10 01-28-2012 11:14 PM
