View Poll Results: Have you blown your stock motor with boost?
Yes complete failure needs rebuild 32 5.39%
No been boosting and running strong 188 31.65%
Nope because I am not boosting my motor 374 62.96%
Voters: 594. You may not vote on this poll
Old 07-29-2014, 11:00 PM   #253
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
Originally Posted by GotBRZ1691 View Post
That's the numbers as they are now. Sure te percentage is a lot less. I'm not in the financial situation where I could even face a risk of 5% of blown motor. I could pay to set it up right but can't pay to replace a block.
And I'm sure there are people who have done the set up correctly and had a time and support mods and still lost their motor.
I will play when I have the money to pay. Until them playing it safe.
You sir deserve a cookie. Unlike most you tend to understand that blowing a motor can happen taking the FI plunge.
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 07-30-2014, 02:26 AM   #254
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
Its like raw dogging girls. a lot of bads can happen, but most of us come out ok.
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline   Reply With Quote
Old 07-30-2014, 03:06 AM   #255
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
Not to scare people but the cam timing (VVT) failures are a real issue in the FA20 and they are hit and miss. I consider it essentially a silent killer. It happens at random and often without the driver ever knowing its occurring. If you're acute to the issue you can hear it happen in the exhaust note. Most commonly I have found it to be the exhaust cams. The ECU literally looses control of the cams and they can and do float throughout their range out of sync from one another. By the time the CEL is set it has already been doing it for a while. In every instance I have personally worked with, the OCVs have been at fault. Worst part is they all test electrically good so the only way to know is to either know what to listen for ALL the time OR logging the cams always OR toss the cam codes which sadly if that happens it has been already doing it for a while haha. They always have slight deviations but what I am talking about becomes massive deviations haha. To make matters worse Both Toyota and Subaru know about it and there has been zero revisions of any of the suspected components responsible for this sometimes catastrophic issue.
Here is one of them I have logged doing it with NO CEL triggered (eventually it did). Exhaust cam #1 is the floater although exhaust cam #2 was havimg issues as well.
THIS ONE = BAD
Here is what they should be doing. This is AFTER me making repairs to an FA20 exhibiting the example I logged above.
THIS ONE = GOOD
LSx Powered 86/ASE Master Certified Automotive Technician
AZFA20 is offline   Reply With Quote
Old 07-30-2014, 10:10 AM   #256
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by evo4g63 View Post
@King Tut "Boom" add me to the list
Shoot me a PM with the details.
Old 07-30-2014, 10:12 AM   #257
King Tut
NASA SpecE30 Racer
King Tut's Avatar
There is no doubt that this is an issue. I sometimes worry if changes to the VVT maps in EcuTek or going to extremes with the cams are contributing to the failures.
Old 07-30-2014, 11:01 AM   #258
BRZPDX
Boosted Member
BRZPDX's Avatar
So what exactly does the exhaust sound like if the VVT is failing? lately, I've noticed my car sounds more UELish although my header is a EL design. we used BRZedit, so I don't think we messed with the VVT.
Old 07-30-2014, 12:57 PM   #259
evo4g63
evo4g63's Avatar
I saw your pm. I'll get back to you on that shortly.
-2016 Subaru WRX
Old 07-30-2014, 01:56 PM   #260
AZFA20
AZFA20's Avatar
That is essentially exactly what it sounds like when the VVT is out of sync. The further separation from being in sync the more it will sound like a UEL. Not to say this is what is happening in your case but if it were me I would log your cams asap.
They become most noticeable when idling but it can be heard just cruising along. Under full load and acceleration it's harder to audibly hear, especially because it can sometimes come and then go very quickly. This can happen both intermittently or constantly.
I have to admit this has crossed my mind too but it happens in totally stock cars too so its pretty inconclusive.
Old 07-30-2014, 02:06 PM   #261
Frs300
Frs300's Avatar
Drives: Pile of junk
what exactly is the cause
Frs300 is offline   Reply With Quote
Old 07-30-2014, 02:19 PM   #262
AZFA20
AZFA20's Avatar
Guys I am getting blasted with PMs on this subject as I assumed I would but instead of responding to everyone's PMs do you feel this subject should be made as a new thread in the main "Forced Induction" forum? That way I can address everyone's questions as best as I can so that everyone can see the info. I know not everyone checks this particular thread so it may be more beneficial to create a new one. Let me know what you think.........
Old 07-30-2014, 02:32 PM   #263
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I would create one, while it may contribute to blown stock motors, it needs it's one thread.
Old 07-30-2014, 06:11 PM   #264
BRZPDX
Boosted Member
BRZPDX's Avatar
Thanks for the reply, this is concerning. The UEL like sound is only when accelerating from a stop on very low rpm. Cruising, and after the initial acceleration from stop, it sounds like a normal EL.
I am going back to my shop to plot some shit. My correction on the AFR while idling, it seems to vary depending on if I have my AC/Fan blowing but it is around 14 and 16. It actually varies a lot. This car does funky things when the heat/cool fans are on. When I turn off the fans, it idles smooth as butter.
If the VVT is going out, is that something you can fix with a tune? Or does replacing it fix the issue? It seems like the issue will come back if only replacing the VVT from OEM..
Fucking boost issues.
Old 07-31-2014, 10:14 AM   #265
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
No holes in my block but my heads are most likely toasted or something.
Old 07-31-2014, 11:08 AM   #266
Dipstik-sportech
Dipstik-sportech's Avatar
Headgaskets
How much HP can the stock motor handle? FullTuneZN6 Engine, Exhaust, Transmission 34 11-16-2017 01:22 AM
Full Blown 521hp Stock Motor @ 20psi FullBlown Forced Induction 276 08-31-2016 02:05 AM
FBM 604Hp 472Tq -- Stock Motor Stage 2 Turbo Kit FullBlown Forced Induction 414 07-14-2014 09:52 PM
FRS300 Rebuild Has Begun..Blown Motor to Built Monster FA20Club.com Forced Induction 917 10-20-2013 06:26 AM
Highest HP on stock motor using only 93/94 octane? hmong337 Forced Induction 11 09-09-2013 10:53 AM
