| View Poll Results: Have you blown your stock motor with boost? | |||
| Yes complete failure needs rebuild |
32 | 5.39% |
| No been boosting and running strong |
188 | 31.65% |
| Nope because I am not boosting my motor |
374 | 62.96% |
| Voters: 594. You may not vote on this poll | |||
#253 | |
Drives: 2016 Subaru WRX
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD |
#254 |
Boosted Member
Drives: 2013 SWP BRZ Limited
Its like raw dogging girls. a lot of bads can happen, but most of us come out ok.
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12 |
#255 |
Automotive Connoisseur
Drives: too many cars
Not to scare people but the cam timing (VVT) failures are a real issue in the FA20 and they are hit and miss. I consider it essentially a silent killer. It happens at random and often without the driver ever knowing its occurring. If you're acute to the issue you can hear it happen in the exhaust note. Most commonly I have found it to be the exhaust cams. The ECU literally looses control of the cams and they can and do float throughout their range out of sync from one another. By the time the CEL is set it has already been doing it for a while. In every instance I have personally worked with, the OCVs have been at fault. Worst part is they all test electrically good so the only way to know is to either know what to listen for ALL the time OR logging the cams always OR toss the cam codes which sadly if that happens it has been already doing it for a while haha. They always have slight deviations but what I am talking about becomes massive deviations haha. To make matters worse Both Toyota and Subaru know about it and there has been zero revisions of any of the suspected components responsible for this sometimes catastrophic issue.
Here is one of them I have logged doing it with NO CEL triggered (eventually it did). Exhaust cam #1 is the floater although exhaust cam #2 was havimg issues as well. THIS ONE = BAD ![]() Here is what they should be doing. This is AFTER me making repairs to an FA20 exhibiting the example I logged above. THIS ONE = GOOD
LSx Powered 86/ASE Master Certified Automotive Technician
#256 | |
NASA SpecE30 Racer
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#257 | |
NASA SpecE30 Racer
- King Tut
#258 |
Boosted Member
So what exactly does the exhaust sound like if the VVT is failing? lately, I've noticed my car sounds more UELish although my header is a EL design. we used BRZedit, so I don't think we messed with the VVT.
#259 |
I saw your pm. I'll get back to you on that shortly.
-2016 Subaru WRX
#260 | |
They become most noticeable when idling but it can be heard just cruising along. Under full load and acceleration it's harder to audibly hear, especially because it can sometimes come and then go very quickly. This can happen both intermittently or constantly. I have to admit this has crossed my mind too but it happens in totally stock cars too so its pretty inconclusive.
#261 | |
Drives: Pile of junk
what exactly is the cause |
#262 |
Guys I am getting blasted with PMs on this subject as I assumed I would but instead of responding to everyone's PMs do you feel this subject should be made as a new thread in the main "Forced Induction" forum? That way I can address everyone's questions as best as I can so that everyone can see the info. I know not everyone checks this particular thread so it may be more beneficial to create a new one. Let me know what you think.........
#263 | |
NASA SpecE30 Racer
- King Tut
#264 | |
Boosted Member
I am going back to my shop to plot some shit. My correction on the AFR while idling, it seems to vary depending on if I have my AC/Fan blowing but it is around 14 and 16. It actually varies a lot. This car does funky things when the heat/cool fans are on. When I turn off the fans, it idles smooth as butter. If the VVT is going out, is that something you can fix with a tune? Or does replacing it fix the issue? It seems like the issue will come back if only replacing the VVT from OEM.. Fucking boost issues.
#265 |
Boosted
Drives: Not a supra....yet
No holes in my block but my heads are most likely toasted or something.
#266 |
Headgaskets
| How much HP can the stock motor handle? | FullTuneZN6 | Engine, Exhaust, Transmission | 34 | 11-16-2017 01:22 AM |
| Full Blown 521hp Stock Motor @ 20psi | FullBlown | Forced Induction | 276 | 08-31-2016 02:05 AM |
| FBM 604Hp 472Tq -- Stock Motor Stage 2 Turbo Kit | FullBlown | Forced Induction | 414 | 07-14-2014 09:52 PM |
| FRS300 Rebuild Has Begun..Blown Motor to Built Monster | FA20Club.com | Forced Induction | 917 | 10-20-2013 06:26 AM |
| Highest HP on stock motor using only 93/94 octane? | hmong337 | Forced Induction | 11 | 09-09-2013 10:53 AM |
