Old 07-28-2014, 06:30 AM   #15
midnight23
dying bird under the hood
Drives: 2013 SWP Limited BRZ
Originally Posted by B-R-Z View Post
I hope someone makes\sells these one day. The stock fender trim is so cheesy looking. I might try to buy a set of these to try this on instead of potentially ruining the originals in my fenders.
I don't care so much to vent my engine bay, but I'd like to have actual vents in the fender trim instead of solid plastic. Kia Optima: 1 Subaru BRZ: 0 in this department.
it's a pretty penny but prova makes something like this.
Build Thread
Instagram
Old 07-29-2014, 02:50 PM   #16
MemphisR
Memphis
MemphisR's Avatar
Drives: 1989 MR2 S/C, 2014 Scion FR-S
Is there any scratching on the paint due to the mesh sitting up against the fender or is there still a bit of room between the mesh and the fender?
"It's ok... It's not structural."- Mikey
MemphisR is offline   Reply With Quote
Old 07-29-2014, 07:20 PM   #17
Gunman
Drives: 2019 Mazda Miata RF
Originally Posted by BadBRZ View Post
I like, buuuuut .. Unless the area around the vent is a low pressure zone, nothing will bent out of that area...
Could add some ducting, and use them to vent the front wheelhouses, and gain some downforce
Old 07-30-2014, 05:14 AM   #18
troek
troek's Avatar
Drives: 2012 Toyota 86
Does the hood seal that area off when its closed? Seems like it might
troek is offline   Reply With Quote
Old 07-30-2014, 06:16 AM   #19
steve99
Drives: FT86
Mob called PROVA make vented fender trims for brz/86 google prova brz vent , not cheap though
Old 07-30-2014, 06:19 AM   #20
steve99
Drives: FT86
easy cheap venting for engine bay , unclip the black plastic piece at rear of underside of bonett on drivers side , for me anyway
The Following 2 Users Say Thank You to steve99 For This Useful Post:
86ft.lb (07-31-2014), troek (07-30-2014)
Old 07-30-2014, 06:25 PM   #21
troek
troek's Avatar
hmm ill have to look into that for track days in the heat.
Old 07-30-2014, 07:23 PM   #22
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
I want to do this and use an air speed meter, that you can find on amazon for as little as $15:
to see how much venting it does at speed. All It should take is to put it under the hood infront of the fender vent. Start recording it with a camera with time stamp, then drive different test of: 20, 30, 40, 50, etc. mph. and log the time and speed. Then compare it to the video and see how much air if any it flows, and what your underhood temps are. Then it would only take a minute to tape over the vents, and go back out and log a base measurement to compare to, or vice versa.
Phantom ESC, OFH, OFT, K&N Drop in
Target70 is offline   Reply With Quote
Old 07-30-2014, 08:42 PM   #23
Gunman
A camera, and yarn tufts will work too
The Following User Says Thank You to Gunman For This Useful Post:
DAEMANO (01-29-2016)
Old 07-30-2014, 09:51 PM   #24
Target70
Target70's Avatar
true, that would tell you if you have flow, if not how much of it.
I would like to make a panel with gills, that way the leading edge of each louver would provide a low pressure zone behind it to help suck out the heat.
Old 07-30-2014, 10:59 PM   #25
zkv476
zkv476's Avatar
Drives: 2014 SWP BRZ, MT
I'll get some yarn and a GoPro and figure this out sometime :p. I remember seeing a CFD simulation of the car but someone pointed out that the lines were showing velocity and not pressure areas so it wasn't very useful.
zkv476 is offline   Reply With Quote
Old 07-31-2014, 01:16 AM   #26
Target70
Target70's Avatar
cool thanks.
I figure that even if that area is high pressure, It can't be higher than the pressure in front of the radiator, so even if it isn't drawn out, the heat should get pushed out.
Old 07-31-2014, 06:19 PM   #27
bimmer635csi
bimmer635csi's Avatar
Drives: 2013 Cayenne turbo
Flow-vis is useful also. The big guys use it. It is just messy.
bimmer635csi is offline   Reply With Quote
Old 07-31-2014, 06:44 PM   #28
Kuros
Drives: 2014 FRS Raven. 2011 sti red (gone)
hmmmm. I may have to try this.
anyone run into any real problems with this?
Kuros is offline   Reply With Quote
Want to trade my white Frs fender vents for Brz fender vents White0utFrs Exterior Parts (Aero, Lighting, Etc.) 0 09-23-2013 03:17 AM
Want to trade my BRZ fender vents for you FRS fender vents, or buy FRS vents outright ill roller Exterior Parts (Aero, Lighting, Etc.) 6 09-22-2013 10:49 PM
WTB BRZ galaxy blue fender vents or trade w my FRS UM blue side vents BlueLeader Exterior Parts (Aero, Lighting, Etc.) 0 03-18-2013 02:55 PM
Functional front fender vents JohnATL Cosmetic Modification (Interior/Exterior/Lighting) 10 01-25-2013 11:58 AM
Want to Trade: My Whiteout FRS Fender Vents for the SWP BRZ fender vents DC-FRS Exterior Parts (Aero, Lighting, Etc.) 15 11-01-2012 11:41 PM
