| Software Tuning Discuss all software tuning topics. |
#183 |
Drives: Raven FR-S 6M
@shiv I started getting P0170 CELs when idling today so I flashed back to stock. My exhaust has been backfiring and has been louder the last couple days so I checked my gaskets and made sure my OFH was wasn't leaky. I had to replace the gasket at the OP/FP. Now this P0170 code leads me to suspect that I have a bad MAF sensor and my fuel trims are getting messed up.
“The World is Flat”
[||•]=(86)=[•||] |
#184 | |
Drives: FT86
check for vacuum leaks especially gasket at maf sensor and clamp at throttlebody and vacuum hoses on intake manifold sound tube ect if oiled filter chech and clean maf sensor |
#185 |
I have a TRD intake and did take the MAF sensor out and gave it a good shot with connector cleaner. I will check clamps and hoses tomorrow. I was going to take in to the dealership but now I think I will avoid the frustration and expense and fix it myself.
“The World is Flat”
[||•]=(86)=[•||] |
#186 |
Just got my OFT, trying to upload the new beta map. Not sure what map I'm supposed to use
700C, 900C, A00C, A01C, B00C, B01C, 700D, 900D, A00D, A01D, B00D and B01D What's the difference between these files? |
#187 |
Well I went through this entire thread and didn't find a answer
What's the difference from the older version and this 'new' beta one. I'm using e85 EL currently with zero issues. Is it a difference that I should really make the upgrade or just continue what I'm using now. Thanks. |
#188 | |
| The Following User Says Thank You to Brinks For This Useful Post: | xxBrun0xx (07-28-2014) |
#189 |
Maximum puntential
Drives: 2013 DGM BRZ 6MT LTD
You need to hook the tablet up to your car and read the stock ROM to know what version you have before you know which version to upload to the tablet. Have you done that yet?
| The Following User Says Thank You to YMAA For This Useful Post: | lucid215 (07-28-2014) |
#190 |
Thanks. My car is on jacks right now for multiple reasons, I was just messing around with the OFM trying to preload the files. I'll hook it up tomorrow. I'm still curious why their are so many different version for the same software. I know it changes for 6mt-Auto but does it change for all the different trim levels depending on what type of electronics are available?
#191 | |
| The Following User Says Thank You to phrosty For This Useful Post: | Brinks (07-28-2014) |
#192 | |
If you want to see, just open up both ROMS in the RomRaider software and view the differences. It's hard to give a placebo based on idle speed, pedal mapping, etc during WOT pulls. I haven't checked, but I would suspect the 93 octane tunes have similar differences in mapping as the e85 tunes, just not as drastic. More spark advance to go with the increased detonation resistance.
#193 |
Drives: Sci FR-S, Fer F355, Toy Highlander
Will using the Sport button mess up the ECU re-learning after flashing the ROM? I was uncertain as to the affects of using the Sport button after the OTS tune is flashed. I was under the impression that the Sport button initiates some sort of throttle remapping.
#194 |
Drives: Whiteout FR-S
Curious to see the difference between the 91 1.59 Stg 1 tune and this updated 93 tune. I've been running 93 octane since original flash. Will be trying this later today!
2013 Ford Focus St
2013 Scion FR-S 2007 Honda Civic Si 2003 Acura RSX Type-S 1998 Ford Escort ZX2 |
#195 | |
#196 |
Tire Destroyer
Drives: Firestorm+snail
downloaded 93oct A00c from beta 2.01, and launch control is active, how to I activate flat-foot shift? I tried it (shifting while on the accelerator without lifting fore shift) and it just revved to the limiter. How do I activate it?
| OpenFlash Tablet v1.42b maps now available | Shiv@Openflash | Software Tuning | 159 | 09-13-2016 01:29 AM |
| Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download | Shiv@Openflash | Software Tuning | 354 | 02-08-2015 06:23 PM |
| OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted | Shiv@Openflash | Software Tuning | 142 | 07-22-2014 11:21 PM |
| Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) | Shiv@Openflash | Software Tuning | 255 | 02-15-2014 05:43 AM |
| OpenFlash Tablet Stage 1 v1.2 maps available for download | Shiv@Openflash | Software Tuning | 31 | 10-31-2013 09:45 PM |
