Old 07-26-2014, 03:14 PM   #113
steve99
Drives: FT86
Originally Posted by ScionFrsFan View Post
These maps are ok for autos? lol
As long as you use the "D" version and not the "C" version, yes
the OFT won't let you use the wrong one
Old 07-26-2014, 04:59 PM   #114
euroshowoff
euroshowoff's Avatar
Drives: 2015 Tacoma
disregard.
"Bah Weep Granah Weep Nini Bong"
Old: 2013 Arengto FR-S
Current: 2015 Tacoma/2020 Sequoia Pro
Future: 2022 CWP Limited Est Delivery 06/22
euroshowoff is offline   Reply With Quote
Old 07-26-2014, 05:19 PM   #115
DC2R
Drives: 2014 Scion FR-S
feel power difference on stage 2UEL 93.
Stalled a couple times letting clutch out. Will see if it self fixes. Thanks Shiv for all that you do!
Sent from my GT-N5110 using Tapatalk
DC2R is offline   Reply With Quote
The Following User Says Thank You to DC2R For This Useful Post:
Shiv@Openflash (07-26-2014)
Old 07-26-2014, 05:55 PM   #116
edeekeos
edeekeos's Avatar
Drives: 2014 Pearl BRZ Limited
Ok, who's on the b01c stg2 EL e85 map. I'm having some SERIOUS issues with it. Fuel trims are through the roof, AFR is dangerously lean, and it is running TERRIBLE. I am going to try the 1.59 map just to rule out the fuel, but something is way out of wack. Rom Raider is showing a ton of null variables in the various fuel sections of the 2.0 map..
| OFT & Stg2 e85 Tune | Perrin Intake Tube & High Flow Filter | Perrin Lightweight Crank Pully |
| Tomei UEL Header/Overpipe | HFC/Perrin Catback | Tom's Tails | Enkei RPF1's | RS*R SuperDowns |
edeekeos is offline   Reply With Quote
Old 07-26-2014, 06:09 PM   #117
Aerok
It's Korea backwards.
Aerok's Avatar
Drives: 2014 FR-S Whiteout
Updated to Stage 1 93.
Revs so much smoother than before. Didn't really notice any power increase but so much more refined.
I love it.
Aerok is offline   Reply With Quote
The Following User Says Thank You to Aerok For This Useful Post:
Old 07-26-2014, 06:09 PM   #118
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
I'm looking at that map now and it looks fine. Are you sure you are using the new XML files provided in the download folder?
Shiv@Openflash is offline   Reply With Quote
Old 07-26-2014, 06:36 PM   #119
edeekeos
edeekeos's Avatar
Yeah I got the new xmls loaded into rr, as well as removed the old ones. The different xmls would explain the discrepancies between the two, however, I tried reflashing the 2.0 tune, and everything is still WAY out of whack. The can feels fine below 4k but asa soon as it gets past that, it's dogs down like mad, and runs lean as hell. Sitting here waiting for the old 1.59 to flash, I'll report back asa I try it out.
Old 07-26-2014, 06:44 PM   #120
MstrSHAKE
MstrSHAKE's Avatar
Drives: 2014 SWP BRZ
Gonna have to do this ASAP
MstrSHAKE is offline   Reply With Quote
Old 07-26-2014, 06:45 PM   #121
edeekeos
edeekeos's Avatar
Ok the 2.0 EL E85 B01C tune clearly has some issues. 1.59 feels like it's supposed to, zero issues whatsoever. Without giving it a whole lot of learning time, my FT was well below 4's, and AFR is right at 11.8-9 under WOT.
Old 07-26-2014, 06:57 PM   #122
Shiv@Openflash
Drives: 2013 FRS
The E85 maps have been run by beta testers for a few weeks now. No other reports of such a problem. A brief glimpse of the mapping data itself shows no issues either as it is identical to the Stage 2.0 EL A01C file that I compared it to. Are you sure you are letting the car idle for 60 seconds after the flash and before touching the accelerator. It almost sounds like you are driving off to early before VVT does it self diagnostic and enables. But maybe others can chime in with their experience with the E85 maps.
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
edeekeos (07-26-2014)
Old 07-26-2014, 07:01 PM   #123
edeekeos
edeekeos's Avatar
Yeah, I did everything as should. I just went back to the 1.59 map using the identical methods, and it is perfectly fine. Not sure whats up. I will re-download the maps, and flash again, and see whats up. Thanks for the quick responses!
Old 07-26-2014, 07:35 PM   #124
ScionFrsFan
Running the new el stage 2 e85 map and the engine doesn't sound so good starting up? Anyone notice a sound difference?
ScionFrsFan
ScionFrsFan is offline   Reply With Quote
Old 07-26-2014, 07:45 PM   #125
Shiv@Openflash
Drives: 2013 FRS
No problem. I'll also test it in our frs later tonight. It's currently running e85 so easy test to do
Old 07-26-2014, 07:54 PM   #126
edeekeos
edeekeos's Avatar
Wonderful. Thanks so much!
OpenFlash Tablet v1.42b maps now available Shiv@Openflash Software Tuning 159 09-13-2016 12:29 AM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 05:23 PM
OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted Shiv@Openflash Software Tuning 142 07-22-2014 10:21 PM
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) Shiv@Openflash Software Tuning 255 02-15-2014 04:43 AM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
