go_a_way1
Old 07-26-2014, 12:19 AM   #6791
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Originally Posted by KAOS View Post
Perhaps my idea was a bit too simple. The 1-10v controller would have a mechanical means of interpreting what the petal position is. Based on this position the same apparatus would send a 1-10v signal to the controller that would basicly act as an interrupt between the phantom power supply and the dc motor. It would allow whatever the neccessary voltage to charge the motor. But, the phantom has its on controls that would conflict. If I remember correctly, it activates 100% at 70% throttle and recharges when not in use. Doesn't seem like a terribly complicated work around but, without having one right in front of me I'm most likely just talking out my Ass. Good luck to you guys though. Also, I'll be doing something like the phantom only nothing like the phantom (no electric motor). I hope to start fabrication in the next month or so. My end goal is to have a reliable means of boost capable of directly competing with tradition superchargers and turbos for around the same price as the phantom. It would be similar to the phantom in that is going to be a zero lag system but that's about it. Again, not building an electric supercharger or stealing anyone's idea. I believe mine is going to be the first of its kind. So if that sounds interesting, keep your eyes peeled.
Sounds interesting to watch. Let us know when you start the build thread.
Installed Mods:
Old 07-26-2014, 02:09 AM   #6792
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
turbocharger, only instead of exhaust gasses, you power it with a compressed air tank right ?
I know, it's so crazy it just might work.
Target70 is offline   Reply With Quote
Old 07-26-2014, 08:19 AM   #6793
VR46
are you Jeff Vader?
VR46's Avatar
Drives: Black BRZ Limited
Originally Posted by enwave View Post
Sure hope not. He did say AT would come close after MT, so I hope it hits soon!
Ahh, OK, I must have missed that then.
VR46 is offline   Reply With Quote
Old 07-26-2014, 11:02 AM   #6794
WNDSRFR
Drives: FR-S,GTI
Oh No
HELP
My ESC just quit working.
I just put some new E85 into the tank and went for a ride. I noticed that the power was down so I thought maybe a bad batch? But then I noticed the voltage meter stays at 28.7.
So I went home and first I checked the switch by engaging it with key on motor off. Listen for the blower. Nothing.
Next with the motor running I suck on the DR tube and nothing.
All the wiring looks good and the fan on the charger/controller is running.
Anybody have any ideas?
Is there a fuse I can check? I don't remember.
Does anyone know how I can check the switch for continuity?
Please help. It sucks driving around without boost.
Old 07-26-2014, 11:32 AM   #6795
shif7i7down
Erected Member
Drives: frs
Got a question; what's a good/safe volt meter reading? Mines been steadily claiming these pass few days and is now at 29v when fully charged.
It's it something i should worry about? Should I turn the system off to stop charging the batteries when it reach that high?
shif7i7down is offline   Reply With Quote
Old 07-26-2014, 11:33 AM   #6796
raven1231
Originally Posted by WNDSRFR View Post
Oh No
HELP
Pm rob. I had the sane symptoms when I had a faulty controller
WNDSRFR (07-26-2014)
Old 07-26-2014, 11:35 AM   #6797
shif7i7down
Erected Member
Drives: frs
Oh No
HELP
Just pm Rob he'll take care of you, excellent customer service.
Edit; dang raven is fast, beat me to it
The Following 2 Users Say Thank You to shif7i7down For This Useful Post:
raven1231 (07-26-2014), WNDSRFR (07-26-2014)
Old 07-26-2014, 11:41 AM   #6798
WNDSRFR
Drives: FR-S,GTI
Will do.
In the meantime is it ok to run the car with the ESC E85 tune?
Or should I load the E85 non ESC tune?
And should I remove the compressor or just leave it in place?
I also have no drag reduction.
Old 07-26-2014, 12:01 PM   #6799
DAEMANO
Time Traveller
29 seems high, but just a tad. PM Rob, he will assist right away.
Old 07-26-2014, 12:23 PM   #6800
enwave
That headunit though...
enwave's Avatar
Drives: 2013 Subaru BRZ Limited SSM
Full throttle Electric Supercharger Build Thread
Will do.
Another thing to check -- make sure you haven't snagged the black wire that runs through the firewall. If the copper in that wire is exposed, the controller will refuse to start even if the voltmeter is on. I actually had that issue where it never dumped voltage like you're having -- I was a little too aggressive in my routing the first time around and caught it on a corner, which I didn't notice until the wire was rubbed through nearly completely. After repairing the wire myself, I was back up with no problems.
Just another thing to check -- but Rob will help you diagnose it the best. He has been great through a couple of hiccups I've had.
2013 BRZ Limited SSM 6AT
Phantom ESC 1.5Dump + E85 + OFH + Q300
Eibach Pro-Kit + Michelin PSS (stock size)
enwave is offline   Reply With Quote
The Following 2 Users Say Thank You to enwave For This Useful Post:
DAEMANO (07-26-2014), WNDSRFR (07-26-2014)
Old 07-26-2014, 12:39 PM   #6801
Winjr
Drives: 2013 Subaru BRZ Premium
Oh No
HELP
I had these same symptoms once, too. Unlike Raven's faulty controller, my problem was simpler - at the five pin connector that connects the throttle switch to the controller, the black wire had pulled away. Barely noticeable.
Winjr is offline   Reply With Quote
The Following 2 Users Say Thank You to Winjr For This Useful Post:
Old 07-26-2014, 12:40 PM   #6802
Sojhinn
Sojhinn's Avatar
Seems like an easy check.
Installed Mods:
Old 07-26-2014, 12:42 PM   #6803
Winjr
Mine regularly settles in at 28.8 and has occasionally hit 28.9. When I've seen it at 28.9 I always hope for just one more tenth, so I can see 29 lol.
Old 07-26-2014, 12:49 PM   #6804
WNDSRFR
Drives: FR-S,GTI
Thanks guys. I'll check both of those things before I bother Rob.
As far as the wire routing goes, when I did the install the harness touched the exhaust manifold and melted. I'll check that first.
Does anybody know if the compressor motor is locked without power or does it spin freely? The reason I ask is because even without the ESC the car runs great. It's just that full throttle is the same as half throttle.
The Following User Says Thank You to WNDSRFR For This Useful Post:
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 05:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 07:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 08:07 AM
