Old 07-25-2014, 10:02 AM   #1471
WNDSRFR
Drives: FR-S,GTI
You can see the dyno plots in the Phantom thread.
Shiv's testing says 225 WHP and 200 Lbs of torque.
But it doesn't really FEEL like it because it is so smooth. It feels just like a rotary engine.
Old 07-25-2014, 10:11 AM   #1472
qoncept
qoncept's Avatar
Originally Posted by Shiv@Openflash View Post
With the OFT maps, we implement a soft rev limiter reducing the hysteresis of the standard hard rev limiter while also implementing a ignition retard just before the rev limit cut point. This includes changing the RPM breakpoints a little as well. The idea is to introduce a torque loss just ~50RPM shy of the rev limit value. So that instead of whacking against it, it slows down and gently bumps against it.
Does this show any kind of performance benefit or is it just a better "feel" ? Like, am I going to lose any less time at an autox if I bounce off the soft limiter vs stock?
qoncept is offline   Reply With Quote
Old 07-25-2014, 10:40 AM   #1473
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Drives: 2018 BRZ Ts - CWP
I will go back to the thread and do some poking around. Thank you. I am glad its smooth. I have had several breakneck cars in my past, to include a 400+hp BRZ that got destroyed unfortunately. However, with this build I am looking to keep things much more balanced. I am past my need to have crazy power, well at least on this vehicle anyways. I appreciate you sharing your info.
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS
DD/4WD - Colorado ZR2 Bison - Mallett Supercharger
brzaapi is offline   Reply With Quote
Old 07-25-2014, 10:47 AM   #1474
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
I just ordered this today and have a few questions.
When loading a new MAP is the new rev-limiter loaded automatically also?
Can the rev-limiter rpm be changed?
Can the radiator fan on temp be changed?
Lunatic is offline   Reply With Quote
Old 07-25-2014, 10:57 AM   #1475
mmmcambelsoup
mmmcambelsoup's Avatar
Drives: FR-S 10 series
So pumped for the new e85 maps today. Any rough estimates on the whp gains from the new maps @Shiv@Openflash?
mmmcambelsoup is offline   Reply With Quote
Old 07-25-2014, 11:11 AM   #1476
jprice130
AutoX Nut
Drives: 2020 Toyota Supra
I know you asked this of Shiv, but I'll jump in for him so he can concentrate on getting the V2.0 maps loaded on their website!
The stock tune runs fairly aggressive timing all the way up to the 7450 RPM rev-limit, so your engine is still trying to make some decent power until you hit the limit and have to wait for the 350 RPM drop to 7100.
As Shiv explained earlier, the OFT tunes still run a decent amount of timing up to 7450 RPMs, but the rev-limiter is expanded to 7600 RPMs and the ignition timing ramps down nicely between 7450 and 7600. The OFT tunes will still get great performance up to 7450 RPMs like the stock tune, but you'll get a gentle decrease in timing after 7450 RPMs as you approach the 7600 limit.
It's definitely way better than stock and will be faster on the AutoX course since you will have a higher top-speed per gear and will be bouncing between 7550 and 7600 RPMs as opposed to 7100 and 7450 RPMs.
jprice130 is offline   Reply With Quote
Old 07-25-2014, 11:13 AM   #1477
lucid215
v2.0 maps to be released tomorrow for USDM cars
-96 new map files (32 for 91oct, 32 for 93oct and 32 for E85)!
-12 new XMLs
-All 6MT maps equipped with Launch Control and No Lift Shift
-All maps based on newest B01C and B01D factory software
Whooza!!!
hopefully they are on the site by the time i get home
lucid215 is offline   Reply With Quote
Old 07-25-2014, 11:21 AM   #1478
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
It's definitely way better than stock and will be faster on the AutoX course since you will have a higher top-speed per gear and will be bouncing between 7550 and 7600 RPMs as opposed to 7100 and 7450 RPMs. The decrease in timing as you approach the 7600 limit will be easier on your engine as well.
For those not yet running the tune, the rev limit is nice but what is really improved as mentioned above is what happens when you hit the limiter.
When stock, as you hit the limiter you get an immediate deceleration, like hitting a wall or a touch of the brakes.
With the OFT limiter I would describe it as "soft" as it just hangs there waiting for you to grab the next gear.
This is a big improvement at the track especially when you're always trying to shift at redline for max speed.
Slick is offline   Reply With Quote
Old 07-25-2014, 11:24 AM   #1479
jprice130
AutoX Nut
All the OFT tunes will have the new rev-limiter that's been described in recent posts, so you will automatically have it once you flash one of the OFT tunes on your car.
You can change the rev-limiter RPM and radiator fan activation temps, but you will need to download and configure RomRaider on your PC to handle that. Once you've done that in RomRaider, then you can copy your edited tune files to your OFT and flash it onto your car.
Old 07-25-2014, 11:43 AM   #1480
jjaisli
jjaisli's Avatar
Drives: 2013 Scion FR-S Firestorm
Sorry if this is a stupid question but will the OFT automatically download the new maps when connected to OpenFlash Manager v.1.10 or do you have to manually download them?
jjaisli is offline   Reply With Quote
Old 07-25-2014, 11:59 AM   #1481
s2d4
s2d4's Avatar
No and yes.
Old 07-25-2014, 12:06 PM   #1482
raven1231
No that is separate. But they will also be released tomorrow. 18 maps (6 for 91oct, 6 for 93oct and 6 for E85).
It's been a BUSY week for us
WOOT! AMAZING AS ALWAYS SHIV
Old 07-25-2014, 01:11 PM   #1483
Antstronaut
So Hot Right Now
Antstronaut's Avatar
Drives: '14 BRZ
Just ordered mine; can't wait to fill her up with corn!!!
Thanks Shiv and everyone at OpenFlash!
Antstronaut is offline   Reply With Quote
Old 07-25-2014, 01:25 PM   #1484
DAEMANO
Time Traveller
Busy week? Dude the last 12 months have been insane! When nose hits grindstone, you put in work man. Just thinking about the last year.
OpenFlashTablet for '86 platform release
Stg 1 Tunes
Stg 2 Tunes
e85 Tunes
OpenFlashHeader UEL for '86 platform release
Stg 2 OFH Tunes
OpenFlashTablet for Phantom ESC
91 & 93 Tunes
e85 with UEL (OFH) Tune
more?
OpenFlashDollars implemented
Loyalty discount for OF product buyers
New website in production
OFT300 Supercharger released
Full Tune package for OFH and OFT
Significant other ACQUIRED
Significant Upgrades to the OFT firmware along the way
Upgraded templates
Logging
More data channels added
Auto-populating tunes
Global ROM support
Custom gauges enabled
Wideband support
OpenFlash Manager client software upgraded through several versions
OFESC (Phantom Supercharger adapted for NC Miata) released
91 & 93 Tunes
more?
OFT for Porsche Cayman/Boxster
...and what in the world are you doing with the Ducati Diavel? Holy crap man, busy is the understatement of the year.
#lolwut, divinecomedy, dopeandcashcabinet, free shiv now, goddamitimissedit, golden cage, i missed the show, looks good, missed the fun, omgbbq, shiv 2016, thefatandthefurriest
Tablet on the dash ! TRD_86 Electronics | Audio | NAV | Infotainment 23 05-16-2015 03:48 AM
Tablet Install ThugNasty Electronics | Audio | NAV | Infotainment 4 04-13-2013 03:15 PM
Blutooth OBD II and a 9.7 tablet.. Scooby South Electronics | Audio | NAV | Infotainment 10 12-16-2012 08:11 PM
7.0 Tablet w/ Torque App Thatruth2001 Northwest 26 11-21-2012 11:53 AM
