Old 07-22-2014, 12:31 PM   #1
mike the snake
adjustable valve for clutch for launching?
I'm wondering if I can install an adjustable valve on the clutch hydraulic line so I can dump the clutch and have it engage a bit more slowly?
I figure it won't affect my pushing the clutch in, but when I launch, when I dump the clutch hard, it will engage the clutch a little more slowly and smoothly.
Trying to save my axles.
Old 07-22-2014, 12:44 PM   #2
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
don't dump?
what you're describing is possible by the actuation of your left and right foot...
http://www.ft86club.com/forums/showthread.php?t=69812
you can also just get new axles...
Old 07-22-2014, 06:15 PM   #3
mike the snake
Thanks for the info, but I already know those two things.
I was hoping to get an answer to my question.
I want to be able to release the clutch quickly and have it engage consistently and smoothly, and I'd like to be able to try and dial that in.
I know a lot of cars have something similar in stock form.
I would think this would let me launch safely from a stop without shocking my axles. Im exploring options before buying beefy axles.
Originally Posted by 7thgear View Post
don't dump?
Old 07-22-2014, 06:22 PM   #4
orangeblue
Drives: Whiteout
Go look around on BMW forums regarding CDV (clutch delay valve). Great idea in theory, in practice not so much.
orangeblue is offline   Reply With Quote
Old 07-22-2014, 06:31 PM   #5
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
I installed a needle valve on my Minibusa so I could floor the gas peddle, side step the clutch, and it wold take a half a second to bleed down giving me a nice smooth launch. But this would also effect every gear change which may not work for you. I have a sequential gear box with full paddle shift on the Minibusa so once I got rolling I no longer used the clutch.
Lunatic is offline   Reply With Quote
The Following User Says Thank You to Lunatic For This Useful Post:
jcw99 (05-29-2016)
Old 07-22-2014, 06:36 PM   #6
mike the snake
Thanks! My old BMW 135i had one of those valves.
I'm wondering if there's an adjustable needle valve or something I can install that would let me adjust the speed of the actuation.
I don't want to sidestep the clutch, just set my launch control to a certain RPM, then be able to dump the clutch and get a smooth launch without breaking axles.
I'm at around 300whp/225torque with big tires (PSS 265's) and I'm spinning them in 1st and 2nd.
I know better axles is better, but I don't plan on drag racing that much, if I could install an adjustable valve and launch consistently, then I'd try that first.
Old 07-22-2014, 06:39 PM   #7
mike the snake
That's exactly what I'm looking for.
Good point about it affecting every gear, I hadn't thought about that.
In my head, it might still work, because the settings would be just a little slower than of a full dump.
Where did you find the needle valve?
Clutch Delay Valve? ashtray Engine, Exhaust, Transmission 72 11-18-2015 12:10 PM
Clutch Delay Valve? Figo Engine, Exhaust, Transmission 14 03-01-2014 11:38 PM
How bad is neutral drop rev launching on the tranny (AT)? BlueDubbinTDI Engine, Exhaust, Transmission 11 10-22-2013 10:39 PM
Launching your FT-86 TheCoach Scion FR-S / Toyota 86 GT86 General Forum 31 08-28-2012 12:20 AM
launching your 86 in second gear whyreeto AUSTRALIA 16 08-21-2012 01:10 AM
