Old 07-11-2014, 01:19 AM   #1
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
the launch
GPS Speed
RPM
Throttle
RL wheel speed
RR wheel speed
red car has 235 semi fresh R1Rs
blue car has 225 old Z1s
noteworthy points:
RPM, 5500 vs 3500
Throttle, as you can see the red car did not dump the clutch, I gently engaged while feathering the throttle and managing slip
The Following 7 Users Say Thank You to 7thgear For This Useful Post:
CSG Mike (07-11-2014), Jawnathin (07-11-2014), midnight23 (07-11-2014), R2 (07-12-2014), raul (01-02-2015), renfield90 (07-11-2014), tahdizzle (07-11-2014)
Old 07-11-2014, 06:14 AM   #2
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Did you know that if you press the space bar you get full page. That is, it hides the "measures and laps" column.
Old 07-11-2014, 09:24 AM   #3
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
yes... but it's not something I intended for this presentation. my screen realestate is triple that, I just focused down on the first segment.
i'll make sure to hide them for you next time.
The Following User Says Thank You to 7thgear For This Useful Post:
Old 07-11-2014, 03:04 PM   #4
Jawnathin
Drives: Toyobaru FRZ
Very interesting, especially coming off our discussion in the other thread. Thanks a bunch for posting.
Do you think the difference in acceleration was due to blue car bogging on the launch? Doesn't look like it got any wheel slip to keep the revs up.
Jawnathin is offline   Reply With Quote
Old 07-11-2014, 03:12 PM   #5
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
it was precisely because he bogged down the launch, or more to the point of starting out at a less than optimal RPM
however having started at the perfect RPM, I did have to manage the wheel spin, as you can see in the bottom graph, my wheels started to spike way too much, and I knew this ahead of time, hence the initial feather of the throttle
my buddy had no such problem and was WOT from the start, but because he was under his powerband there was no issue with wheel spin so it was just a gradual acceleration
Old 07-11-2014, 03:29 PM   #6
Jawnathin
Got it, thanks for confirming. Really shows the importance of keeping the revs up.
Now I wonder if a clutch dump vs clutch slip with no bogging is faster.
Old 07-11-2014, 03:49 PM   #7
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
on stock clutch and street tires a dump is probably not worth it
if both were upgraded and you had a few spare axles in the paddock then by all means.
Old 07-11-2014, 03:57 PM   #8
Jawnathin
Agreed, probably why I am wanting to try a different launch now. Wasn't so worried on the stock Primacys, but as I'm getting into something a little stickier, didn't want to blow the diff or snap an axle.
Will try your recommended 5500~rpm clutch slip approach.
Old 07-11-2014, 06:12 PM   #9
Captain Snooze
Drives: Red Herring
Thanks. I think it would present well if you could add rainbows too
Old 07-11-2014, 06:14 PM   #10
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
Captain Snooze (07-11-2014)
Fr-s launch RPM F3dzo Scion FR-S / Toyota 86 GT86 General Forum 14 04-21-2016 08:11 PM
FRS Out run 3.25 BMW from Launch Whitigir FR-S / BRZ vs.... 25 06-06-2013 06:42 PM
BRZ launch in NZ Metabrz BRZ Photos, Videos, Wallpapers, Gallery Forum 15 12-12-2012 09:00 PM
86 Launch in NZ caldine AUSTRALIA 0 09-15-2012 07:06 PM
UK Launch. FT-86 is called GT 86 mrxandthexfactor Scion FR-S / Toyota 86 GT86 General Forum 1 11-27-2011 12:08 AM
