Old 07-13-2014, 04:22 AM   #1
jibai
Drives: frs
Spec D headlight HID Install instructions/wiring?
I have a set of Spec D Headlights and HIDs. I'm wondering if anyone has pictures or install instructions for the HIDs? I've searched and haven't been able to come up with anything.
jibai is offline   Reply With Quote
Old 07-13-2014, 06:27 AM   #2
Chen
Regional Moderator
Chen's Avatar
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
Wondering the same thing.
Chen is offline   Reply With Quote
Old 07-13-2014, 08:59 AM   #3
FRSNewb
FRSNewb's Avatar
I bought Spec D headlights and a Morimoto HID kit for my car and did the entire install myself based on separate YouTube videos on how to install Spec D headlights and how to install the Morimoto HID kit and sort of just combined the two together and did the entire install; took longer than it should have but thats due to my inexperience.
Just follow the step-by-step process in the videos and install should go okay. I bought an HID kit with D2-S Bulbs which meant I had to do some modification to the bulb housing on the Spec-D headlights so the wiring harness could fit properly (basically I had to cut out part of the black plastic housing).
If you have any specific questions, feel free to ask and I'll do my best to answer!
1993 Mazda MX-3 - *SCRAPPED* / 1999 Plymouth Neon - *WRECKED* / 2000 Chrysler Neon - sold / 2006 Honda CR-V - sold / 2019 Chevrolet Colorado - All Year Round Vehicle / 2013 Scion FR-S - Summer Car
FRSNewb is offline   Reply With Quote
The Following User Says Thank You to FRSNewb For This Useful Post:
jibai (07-21-2014)
Old 07-21-2014, 07:51 PM   #4
jibai
Drives: frs
Thanks. I followed those instructions and just completed the install. Took about 2hrs. It was the wiring of the HID to the headlight that I didn't get. Those videos did help!
The Following User Says Thank You to jibai For This Useful Post:
FRSNewb (07-22-2014)
Old 07-22-2014, 09:45 AM   #5
FRSNewb
FRSNewb's Avatar
Glad to hear! If you haven't already noticed, you'll soon realize that the term 'you get what you pay for' REALLY applies when it comes to these lights
jibai (07-22-2014)
Old 07-22-2014, 12:54 PM   #6
ToyotaBoy
Drives: 2013 FRS Hot Laval
speedfactory videos
Dunno if this helps, they have installation video for the Spec D.
http://www.ft86speedfactory.com/spec...-frs-1522.html
As for the HID, in the video, the host shows you where to drill a hole at the back of the bulb cover for the HID wires.
My HID package came with a rubber cover. Just make sure the hole you drill is the right size (or just a bit smaller) so moister doesn't go in.
ToyotaBoy is offline   Reply With Quote
The Following User Says Thank You to ToyotaBoy For This Useful Post:
jibai (07-22-2014)
Old 07-22-2014, 08:52 PM   #7
jibai
Drives: frs
What issues are you noticing or having?
Old 07-23-2014, 09:38 AM   #8
FRSNewb
FRSNewb's Avatar
Only issue I've had thus far is the one turning signal working intermittently, however that could be due to a lose connection (I really don't want to go through the hassle of ripping my bumper off again to check)....other than that everything has been working great!
Old 04-04-2015, 03:05 PM   #9
FyeaFRS
Drives: 1992 Nissan Skyline GTS-t Type-M
I just returned the morimoto d2s I had bought because I'm not about to cut up the housing just to make it fit. Will keep looking for other options.
FyeaFRS is offline   Reply With Quote
Old 04-05-2015, 03:38 PM   #10
Chen
Regional Moderator
Chen's Avatar
I think I picked up h3 bulbs and tbey worked.
BRZ Headlight pin/wiring diagram 2SeeKU Electronics | Audio | NAV | Infotainment 12 06-28-2020 03:17 AM
headlight wiring question Lydin Cosmetic Modification (Interior/Exterior/Lighting) 0 04-11-2014 11:02 PM
BRZ/FRS Footwell Illumination Install Instructions Stierzy34 Cosmetic Modification (Interior/Exterior/Lighting) 4 09-06-2013 05:09 PM
Instructions to install OEM mudguards? eddieEndo DIY (Do-It-Yourself) Guides 7 02-13-2013 05:18 PM
So is there a DIY yet for BRZ headlight wiring for the FR-S? seven Cosmetic Modification (Interior/Exterior/Lighting) 4 11-25-2012 10:24 PM
