Old 04-29-2014, 02:40 PM   #225
renfield90
The Stig's German cousin
Originally Posted by Porsche View Post
So, would you recommend pulling the ABS fuse, then?
Note: I DISLIKE ABS, and would like to pull the fuse, but I worry about unintended consequences. The loss of EBD concerns me with a possible brake imbalance.
I'd be interested in your thoughts about this, Renfield.
I've spent most of my life driving cars without today's nannies, and the "loss" of them is not a concern to me.
ABS robs me of the life-saving ability to arrest any further change in direction. I WANT to be able to lock 'em up when I need to.
I would be pulling mine already if it weren't illegal in my class. I'd rather wad the car up myself than have the electronics do it for me.
The pedal dance already kills your EBD. My personal opinion is that it pushes the brake balance a little bit to the rear compared to when EBD is active, and/or (perhaps more accurately) the EBD doesn't take action to keep the rear from coming around under braking. I wouldn't call it imbalanced, but you will need to manage that balance without any help.
I would be more concerned about a pulled ABS fuse putting the car into some kind of limp mode, although I think our ECU designers were kind to us about that. Haven't tested though - since I have to live with it, my mission has been to change my driving style to avoid ABS.
Old 04-29-2014, 02:49 PM   #226
renfield90
Originally Posted by fooddude View Post
Question about ice-mode:
Ok..so I read it happens in pedal-dance-mode during super fast pedal to braking and also deep in abs.
But..does ice-mode happen only particularly in pedal-dance-mode?
Or, does/can it happen also in regular non-pedal-dance-mode? Both, or either, vsc/trc on and off?
...in other words..is possible ice-mode a permanent fixture of the car, and can/possibly happen, regardless of what mode/setting or what you deactivate on the car?
If ABS is active, ice mode is possible. Think of this system as layered:
VSC/TC
EBD
ABS
Hardware (your actual brakes)
Each time you go up a layer, it builds on what the layer(s) below offer - Stability control works because EBD can modulate brake power individually to each wheel, and EBD can do that because there's an ABS system that can tell EBD if it brakes too hard on a wheel.
Pushing the traction control button for five seconds disables the top layer.
Pedal dance disables the top two layers.
Old 04-29-2014, 03:14 PM   #227
CSG Mike
CSG Mike's Avatar
VSC/TC
EBD
ABS
You beat me to it.
The stock system is a slightly rear biased, but not horribly so. IMO, it's good for trail braking
Old 04-30-2014, 01:04 AM   #228
Porsche
Drives: 2013 BRZ Ltd. MT
A rearward bias would mean the rears would lock up first, before the fronts, yes?
In that case, threshold (and beyond) braking, downhill in the wet, without ABS, for instance, would lead to the car swapping ends in a heartbeat.
Is this correct?
If so, then one MUST have functioning ABS, short of modifying the car and installing a brake proportioning system.
If the above is correct, then pulling the ABS fuse would be disastrous, a crash on the way to happening.
Either that, or I'm confused.
A minimalist Caterham 7 looks increasingly attractive to this old boy.
Porsche is offline   Reply With Quote
Old 07-21-2014, 01:52 PM   #229
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
After this weekend I am now a full fan of the pedal dance. I normally brake in a straight line so ice mode does not happen often. I had a co-driver who is used to trail braking and with the hawk plus pads up front and factory in the rear it was going into ice mode. We have events back to back this weekend so I was able to get about 15 runs testing it. With the pedal dance done straight line braking was even better. pedal dance for the win.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 07-21-2014, 03:01 PM   #230
mla163
Overthinking it
Drives: BRZ in CS
I used this to fix a WTF spin at an autocross yesterday. I spun on the first run without pedal dance and was fine on the next few with the pedal dance.
I DID get ice mode with the pedal dance activated.
mla163 is offline   Reply With Quote
Old 07-21-2014, 03:51 PM   #231
DaDr00
DaDr00's Avatar
Drives: '13 Whiteout FR-S
Took the FR-S out for her maiden autocross on the road course and had no issues with threshold breaking after using the Pedal Dance.
- '13 Whiteout FR-S
- '95 Toyota T100
NASA Mid South - Chief of T&S
DaDr00 is offline   Reply With Quote
Old 07-21-2014, 08:14 PM   #232
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
I couldn't do it even after letting the car fully warmed up between sessions. I have followed the same exact procedure but it didn't work for some reason.. I was trying at the last couple event and it only worked once :/
glamcem is offline   Reply With Quote
Old 07-21-2014, 08:19 PM   #233
Sleepless
Drives: 2016 FR-S
I found you have to be quite quick in completing the sequence after starting the car.
Sleepless is offline   Reply With Quote
Old 07-21-2014, 09:17 PM   #234
glamcem
glamcem's Avatar
I remember someone mentioned that he let the car idle for a while, interesting
Old 07-21-2014, 09:27 PM   #235
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
What I do:
warm car
Restart car (with parking brake on + foot on brake pedal)
Rev engine if RPMs don't drop immediately (rev 2-3 times to get RPMs to drop)
with foot on brake, pump parking brake 3 times, then brake pedal 3x, etc... after the 3rd sequence the procedure is complete
The RPMs do have to drop for this to happen. That's the only way you can verify, since it's the ECU's way of saying "engine's warm, no need for fast idle"
-alex
Old 07-21-2014, 10:14 PM   #236
glamcem
glamcem's Avatar
Originally Posted by mav1178 View Post
What I do:
warm car
-alex
I will give another shot after driving around a bit..at the track, I remember running the car for about 5 minutes and checking the oil temps too ..maybe I wasn't quick enough but in the video (someone posted earlier) he wasn't really that fast either..
Old 07-21-2014, 11:54 PM   #237
troek
troek's Avatar
Drives: 2012 Toyota 86
just to lay out all out clearly: you get approx 30 seconds after the car starts to complete this. car must be fully warmed up, it dosnt work for me until water temps are around 190. shut the car off and restart it, pull e brake 3 times, leave it up on the 3rd pull. pump brake pedal 3 times, keep it pressed on 3rd pump, pull e brake 3 times, leaving it up once again, press brake pedal 2 more times.
troek is offline   Reply With Quote
Old 08-14-2014, 09:47 PM   #238
chris912
chris912's Avatar
Drives: 2013 Firestorm 6MT FR-S
subbbbbbbbbbbbbbed
chris912 is offline   Reply With Quote
Where to buy "heel/toe" shaped gas pedal? dookie11 Scion FR-S / Toyota 86 GT86 General Forum 56 01-22-2019 11:24 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 05:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
Dyno testing and "drivetrain loss" serialk11r Other Vehicles & General Automotive Discussions 5 11-03-2011 08:55 AM
