#225 | |
The Stig's German cousin
The pedal dance already kills your EBD. My personal opinion is that it pushes the brake balance a little bit to the rear compared to when EBD is active, and/or (perhaps more accurately) the EBD doesn't take action to keep the rear from coming around under braking. I wouldn't call it imbalanced, but you will need to manage that balance without any help. I would be more concerned about a pulled ABS fuse putting the car into some kind of limp mode, although I think our ECU designers were kind to us about that. Haven't tested though - since I have to live with it, my mission has been to change my driving style to avoid ABS. |
#226 | |
VSC/TC EBD ABS Hardware (your actual brakes) Each time you go up a layer, it builds on what the layer(s) below offer - Stability control works because EBD can modulate brake power individually to each wheel, and EBD can do that because there's an ABS system that can tell EBD if it brakes too hard on a wheel. Pushing the traction control button for five seconds disables the top layer. Pedal dance disables the top two layers. |
#227 | |
The stock system is a slightly rear biased, but not horribly so. IMO, it's good for trail braking
#228 | |
Drives: 2013 BRZ Ltd. MT
A rearward bias would mean the rears would lock up first, before the fronts, yes? In that case, threshold (and beyond) braking, downhill in the wet, without ABS, for instance, would lead to the car swapping ends in a heartbeat. Is this correct? If so, then one MUST have functioning ABS, short of modifying the car and installing a brake proportioning system. If the above is correct, then pulling the ABS fuse would be disastrous, a crash on the way to happening. Either that, or I'm confused. A minimalist Caterham 7 looks increasingly attractive to this old boy.
#229 |
Drives: 2013 FRS Asphalt
After this weekend I am now a full fan of the pedal dance. I normally brake in a straight line so ice mode does not happen often. I had a co-driver who is used to trail braking and with the hawk plus pads up front and factory in the rear it was going into ice mode. We have events back to back this weekend so I was able to get about 15 runs testing it. With the pedal dance done straight line braking was even better. pedal dance for the win.
2013 Scion FR-S AT Picked up 5/30/2012
#230 |
Overthinking it
Drives: BRZ in CS
I used this to fix a WTF spin at an autocross yesterday. I spun on the first run without pedal dance and was fine on the next few with the pedal dance.
I DID get ice mode with the pedal dance activated. |
#231 |
Drives: '13 Whiteout FR-S
Took the FR-S out for her maiden autocross on the road course and had no issues with threshold breaking after using the Pedal Dance.
#232 |
Drives: 2022 BRZ Limited
I couldn't do it even after letting the car fully warmed up between sessions. I have followed the same exact procedure but it didn't work for some reason.. I was trying at the last couple event and it only worked once :/
#233 |
Drives: 2016 FR-S
I found you have to be quite quick in completing the sequence after starting the car.
#234 |
I remember someone mentioned that he let the car idle for a while, interesting
#235 | |
Drives: 2005 Toyota Camry
warm car Restart car (with parking brake on + foot on brake pedal) Rev engine if RPMs don't drop immediately (rev 2-3 times to get RPMs to drop) with foot on brake, pump parking brake 3 times, then brake pedal 3x, etc... after the 3rd sequence the procedure is complete The RPMs do have to drop for this to happen. That's the only way you can verify, since it's the ECU's way of saying "engine's warm, no need for fast idle" -alex |
#236 | |
#237 |
Drives: 2012 Toyota 86
just to lay out all out clearly: you get approx 30 seconds after the car starts to complete this. car must be fully warmed up, it dosnt work for me until water temps are around 190. shut the car off and restart it, pull e brake 3 times, leave it up on the 3rd pull. pump brake pedal 3 times, keep it pressed on 3rd pump, pull e brake 3 times, leaving it up once again, press brake pedal 2 more times.
#238 |
Drives: 2013 Firestorm 6MT FR-S
subbbbbbbbbbbbbbed
| Where to buy "heel/toe" shaped gas pedal? | dookie11 | Scion FR-S / Toyota 86 GT86 General Forum | 56 | 01-22-2019 11:24 AM |
| Which Markets have "GT86" and "Toyota" badges on trunk? | Tanuki | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-10-2013 05:23 PM |
| Anyone else try running "square" tires on "staggered" wheels? | hamlet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 12-19-2012 12:59 PM |
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
| Dyno testing and "drivetrain loss" | serialk11r | Other Vehicles & General Automotive Discussions | 5 | 11-03-2011 08:55 AM |
